Old 01-05-2003, 11:17 PM   #1
Katch_My_WRX
Visiting NASIOC Timeout
Member#: 25223
2003 Black
EVO aka Shannon
Default dual stage or other?
i have close to $400, and im not sure whether to get the dual stage boost controller or something else. i do know that eventually i'll get the UTEC (maybe within next 6-8 months), rendering the dual stage worthless. can you guys help me out? thanx a lot.
Jim
Katch_My_WRX is offline   Reply With Quote
Old 01-06-2003, 01:18 AM   #2
codean
Member#: 10186
Do not get a dual stage MBC. I had one and they are not worth the money. Just save your money!
codean is offline   Reply With Quote
Old 01-06-2003, 08:06 AM   #3
gifty74
Member#: 16499
2002 Sedona Red WRX
Default save it
yeah, i agree, don't waste your money. you can build yourself a dual stage setup, w/ mbc, pretty cheap (< $75), but i wouldn't spend the >$200 some are charging, it's just not worth it.
gifty74 is offline   Reply With Quote
Old 01-06-2003, 02:19 PM   #4
jrexilius
Member#: 21713
2002 wrx sedan
black
for $400 get an up-pipe and MBC from vishnu ($310 up-pipe kit and $50 MBC) this is best bang for buck.
or get the scoobysport downpipe with CEL fix ($400)
or get better tires.
or get front and rear sway bars and kartboy endlinks (whitelines $300 endlinks $100)
or get whiteline anti-lift kit ($150) and brake pads, fluid, and steel lines ($250)
what are you trying to do, drive the car or drag the car?
jrexilius is offline   Reply With Quote
Old 01-06-2003, 10:36 PM   #5
Katch_My_WRX
Member#: 25223
2003 Black
EVO aka Shannon
wow thanks a lot for the input... much appreciated. now i think im gonna go with the up pipe. a friend of mine gave me his turbo xs standard boost controller for free... i think i might just use that. once again tho, thanx for your help.
Old 01-07-2003, 05:02 PM   #6
thejean
Member#: 17763
This is my suggestion:
1. Gut the stock up-pipe. Cost = Free
2. Get Vishnu's EMI system and PnP Harness. Cost = $350-$400.
Much better than a dual stage setup. However, if you're still interested in a dual-stage setup I have all the parts and may looking to sell them soon...
- Turbo XS HPMBC
- Grainger solenoid
- red illuminated toggle switch (its a nice one)
JC
thejean is offline   Reply With Quote
WTT: 3" Borla Hush catback for 3" Perrin Dual Tip or other medium loudness exhaust Dragula NESIC Private Classifieds 3 04-11-2009 02:39 PM
Looking to buy...Stromung cat back (dual tip) for STi...or other dual tip eshaun Private 'Wanted' Classifieds 1 11-11-2005 05:18 PM
Dual stage or Single MBC ??? 05_ATX_Turbo Baja Forum 12 10-05-2004 06:04 PM
Turbo XS dual-stage manual boost cont. or the standard? bigbird Normally Aspirated with bolt-on Forced Induction Powertrain 0 03-29-2003 03:44 PM
WRX Single stage or dual stage brake booster? Herbie WRX Forum Archive 3 01-26-2001 04:28 PM
Message Board Statistics All times are GMT -4. The time now is 08:38 PM.
