Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 02-22-2001, 10:57 AM   #1
KITTbri
Member#: 2748
1992 WHT SE-Rw/stuff
2.5RS & '01 Mazda MP3
Thumbs down lean condition
Okay need some feed back. I have a 99 that as of late feels a little hitch in 2&3 at about 4k rpm. is the infamous MY99 lean upper end i hear so much about?
if so what is best way to combat this condition short of a s-afc?
KITTbri is offline   Reply With Quote
Old 02-22-2001, 11:16 AM   #2
bratmantlz
Member#: 3231
88 626 Turbo
white
Post
ecu reset??? dunno
bratmantlz is offline   Reply With Quote
Old 02-22-2001, 12:26 PM   #3
rjones
Member#: 1477
2003 wrx wagon
Post
No, you're not experiencing the 'normal' learn problem with the 99 if its at 4k RPM. Lean run oply happens above 5300. Anyhoo, this only hapens with aftermarket intakes-- do you ahve one of these?
It sounds more like you're experiencing the infamous knock sensor hesitation problem. Do a search and you'll see.
I had a hesitation around 3500 for a few days, but a new tank of gas seemed to clear it up *shrug* Try and ecu reset.
rj
rjones is offline   Reply With Quote
Old 02-22-2001, 08:08 PM   #4
Mariano
Member#: 56
Chapter/Region: PRSIC
1999 RS-T (Stage V)
2005 LGT LTD
Have a Nice Day?
1. Reset the ECU
2. Get a Rich/Lean meter installed
3. Install an Apex'i S-AFC
M
Mariano is offline   Reply With Quote
Old 02-23-2001, 01:48 AM   #5
KITTbri
Member#: 2748
Post
no i have stock intake only panel filter.
it did happen after a new tank of gas though... usually buy QT, got Starvin' Marvin' this time. would octane boost help that?
non electronic lean condition cure? jeffg Normally Aspirated Powertrain 3 03-07-2002 01:21 PM
RS-T owners and tuners: Need help with diagnosing lean condition!! Rich L Normally Aspirated with bolt-on Forced Induction Powertrain 19 02-14-2002 10:39 PM
lean condition on 1.8L w/intake & exhaust? RaceCarRiot Normally Aspirated Powertrain 1 01-08-2002 05:38 AM
Cheap way (under $200) to correct lean conditions? Overtime Technical Forum Archive 0 08-29-2000 08:10 PM
