Old 02-22-2001, 10:07 AM   #1
Xscreamer
Member#: 711
1993 Rx7 R1
Yellow
Lightbulb Is it possible to...
I own a MY99 and unfortunaly i have the damn MAS. If you have a S-AFC do you think i would be possible to get rid of the MAS and just use a O2 sensor or something??? Similar to the BLUE WIRE MOD just a little different
~Brandon
Xscreamer is offline   Reply With Quote
Old 02-22-2001, 10:10 AM   #2
DigDug
Member#: 4077
1999 Impreza 2.5RS
Question
Are you saying you want to replace the mass airflow sensor with an EGT? You don't expect to give the ECU exhaust gas temp and have it determine how much air is flowing into the engine, do you?
DigDug is offline   Reply With Quote
Old 02-22-2001, 10:17 AM   #3
Xscreamer
Member#: 711
1993 Rx7 R1
Yellow
Post
No IM tryin to say is it possible to replace the MAS with something a little more reliable, since i have already blown 3 or them...
Old 02-22-2001, 10:20 AM   #4
DigDug
Member#: 4077
1999 Impreza 2.5RS
Smile
Oh, okay. Well, you could go to a MAP sensor, but the only really effective way to do that (that I know of) is to get a TEC-II or similar standalone/parallel ECU. Vishnu sells an NA-oriented kit for like $1800 I think...
Old 02-22-2001, 10:48 AM   #5
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
& 08 Triumph Speed Triple
Post
Has anyone tried to make a HKS VPC work on an Impreza 2.5? It eliminates the MAF on a Supra, i wonder if it would work for us.
Josh
scoobiejosh is offline   Reply With Quote
Old 02-22-2001, 01:04 PM   #6
jeffg
Member#: 2958
2001 WRX (GC8)
Post
MY00 an newer dont have a MAF. They have a MAP. It is a differnt type of sensor. You could theoretically get an ECU from a MY00+ and swap it along with the sensor. Not really sure if that would work or not.
Jeff
jeffg is offline   Reply With Quote
Old 02-22-2001, 01:06 PM   #7
DigDug
Member#: 4077
1999 Impreza 2.5RS
Talking
Sure it would work. If you can find an engine harness adapter, or like soldering wires!
Old 02-22-2001, 01:09 PM   #8
cj917
Member#: 627
MY96 outback wagon
Wink
if we can easily re-program the stock ECU like that, we have no need for any aftermarket piggypack or stand-alone computers, do we?
on the other hand, i don't know if you can replace the whole MAF + MY99 ECU with a MAP + MY00/01 ECU tho
cj917 is offline   Reply With Quote
Old 02-23-2001, 12:40 AM   #9
Xscreamer
Member#: 711
1993 Rx7 R1
Yellow
Post
So do u think we could switch to a MAF from a MY00 and progam it to work through our S-AFC's????
is it possible to be depressed and not know it? WrxWonderWagon Off-Topic 15 05-12-2006 11:32 PM
is it possible to not take it personally, career related vile Off-Topic 10 11-30-2004 04:41 PM
is it possible to change dashlights from green to orange (wrx to sti) M32WRXin3seconds Interior & Exterior Modification 8 12-11-2003 12:36 AM
Tint Ticket... Is it possible to get out of it? zperkins Bay Area Impreza Club Forum -- BAIC 6 08-21-2003 07:47 PM
Is it possible to change from auto to manual? Andrew General Forum Archive 14 05-26-2000 11:18 AM
Message Board Statistics All times are GMT -4. The time now is 05:04 PM.
