Old 04-21-2001, 03:18 PM   #1
blue
Member#: 2089
2001 Impreza 2.5RS
Blue Ridge Pearl
Question Q: A'PEXi S-AFC
I have just bought a A'PEXi S-AFC. I went to the site and look at the USA update for sensor and ECU type the site says a 96-98 have a sensor HW-4. And the ECU is a S1. But i have a 2001 rs. When i took the ECU out it says M-3 on it. Does anybody know how to hook it up and how to tune the air flow right? How did you guys wo have a 2000 impreza hook the wires up. I need to know so i can install it. Thanks
[This message has been edited by blue (edited April 21, 2001).]
blue is offline   Reply With Quote
Old 04-21-2001, 05:59 PM   #2
Safir
Member#: 3873
. Paradise is
like Disney with hookers
Post
check forcefed4.com in the turbo RS faq they have a s-afc wiring diagram
Safir is offline   Reply With Quote
Old 04-21-2001, 06:21 PM   #3
blue
Member#: 2089
2001 Impreza 2.5RS
Blue Ridge Pearl
Question
mine is not a turbo is it the same?
Old 04-21-2001, 06:29 PM   #4
Safir
Member#: 3873
. Paradise is
Post
yes, to the best of my knowledge you use the same hook-up points.
Old 04-21-2001, 06:34 PM   #5
blue
Member#: 2089
2001 Impreza 2.5RS
Blue Ridge Pearl
Question
Thanks do you have one also? And if i install it but don't know how to tune it yet can i set the numbers to zero? Will it harm or affect anything? What is the name of the sensor?
Old 04-21-2001, 06:54 PM   #6
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Post
If I remember correctly, on MAP cars on w/ stock fuel injectors, stock fuel pressure riser and stock fuel pump, the SAFC is quite useless. Not sure if you really want to take the hassle of installing it.
GTBGUY is offline   Reply With Quote
Old 04-21-2001, 07:30 PM   #7
NA Impreza
Member#: 4267
1999 rs
white
Post
i'm also planning to get the S-AFC, so i want to know if it does improve performance? i have an air filter and exhaust....i remember reading on SCC that it does help and reduces the lose of power at low RPM range? is this true?
NA Impreza is offline   Reply With Quote
Old 04-21-2001, 07:32 PM   #8
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Post
NA Impreza- It will help on MAF cars (which is what your RS uses for air flow measurements). Also, the SAFC helps if you have larger injectors etc.
It's only for the MAP cars that it doesn't do much.
Old 04-21-2001, 07:47 PM   #9
Safir
Member#: 3873
. Paradise is
Post
the S-AFC is NOT useless on the MAP cars (my00+) true the ecu will learn and correct for any adjustments made a the "low throttle" setting, if you set your high throttle to about 80% you can adjust the a/f ratio. so while the S-AFC is not as useful in the MAP cars as in MAP cars, it is still useful.
Old 04-22-2001, 08:34 PM   #10
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
Here is my installation guide to SAFC on MY01 RS
http://www.geocities.com/matsut_rpi00/safc.html
You need an A/F meter or preferably EGT to tune the SAFC. Without the gauges, don't do it.
tmat3 is offline   Reply With Quote
Old 04-22-2001, 09:37 PM   #11
Remy E. LeBeau
Member#: 4714
Post
I may be dumb , but what does one of those things actually do?? Is it a true upgrade and do you need to have a turbo to have on or can you run one on a NA Powertrain?? I hear they are like 400 bucks, but how much performance do you get??? I want to know!!
Remy E. LeBeau is offline   Reply With Quote
WTB: GReddy e-Manage or A'pexi S-AFC/ITC Soon2BturbodRS Private 'Wanted' Classifieds 1 12-17-2003 01:23 PM
A'PEXi S-AFC II??? arconnell Engine Management & Tuning 2 12-09-2003 05:45 PM
Anyone know the dimensions of the A'PEXi S-AFC? 206WRX_GDA Engine Management & Tuning 0 11-06-2002 02:23 PM
Anyone have a up to date A'PEXI s-afc manual? nitrohuffer Tri-State Area Forum 21 01-22-2002 11:46 AM
A'PEXi S-afc sensor #'s for 01 legacy nitrohuffer Normally Aspirated Powertrain 2 01-18-2002 08:21 AM
