Old 01-06-2003, 12:36 PM   #1
serious
Member#: 22879
Default Turbo crossmember swap ?'s
Hi all, I'm wondering what all needs to be swapped over on the turbo legacy crossmember? I'll be installing a 93 turbo legacy motor in my 96 legacy.
Obviously the crossmember itself but what about the steering rack and ties? Or would i use the 96 rack instead of the 93? If i used the 96 one would i need to swap over all the lines and pump too?
Thanks
Brent
serious is offline   Reply With Quote
Old 01-06-2003, 09:35 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
don't think you would need to swap out the steering rack
Legacy777 is offline   Reply With Quote
Old 01-06-2003, 11:38 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
The pumps are compatible with different racks. The only changes are the "termination" of the lines at the pump side. I run a 97 legacy gt rack in my 90 legacy. Some use a sort of banjo while others use a nut with threads outside. (if that made any sense!)
Old 01-07-2003, 12:17 PM   #4
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
You may not even need to swap the crossmember, make sure it's definitely different enough from the stock one.
The reason i say this is because a friend swapped an EJ22T into his 96 Brighton Impreza, and the x-member was not in the way.
A friend with an RS who was going to turbo it also swapped in a turbo x-member, with nothing else needing to be changed.
Dave
DLC is offline   Reply With Quote
Old 01-08-2003, 01:10 AM   #5
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
dave, i did not understand that, one guy used the x member from his old motor, and the other one used the x member from the turbo car? are you sure that an ej22T going into a 95 96 leg 2.2 will not need the x member from the turbo?
subiekid is offline   Reply With Quote
turbo swap ?'s jeepman6679 Newbies & FAQs 14 12-17-2009 10:43 AM
Turbo Legacy Turbo CROSSMEMBER 150. serious Engine/Power/Exhaust 5 04-07-2009 03:57 PM
Turbo crossmember for my swap? dg_performance Subaru Conversions 1 02-05-2008 12:23 AM
wtb: legacy turbo crossmember, or wrx crossmember, new england area hopefully legacy2003 Private 'Wanted' Classifieds 0 06-21-2005 03:35 AM
Engine Crossmember Swap (NA->Turbo) stimpy Normally Aspirated Powertrain 3 02-07-2001 05:46 PM
