Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds
Old 01-06-2003, 03:15 PM   #1
OAKOS Automotive
NASIOC Storefront Vendor
Vendor Sales Rating: (156)
Member#: 18261
2002 Impreza WRX w/
V9 Spec-C EJ207
Smile Just In: Denso Iridium Spark Plugs!
These plugs are a direct replacement for the OE plugs. The IK20's are the same heat range as the stock '02+ plugs & the IK22's are one heat range colder.
These plugs are also good for most '90-'01 Subarus, please see Denso's application guide to find the part for your specific year & engine.
Colder plugs are good for modified WRX's that are running increased boost pressure. These are also good for most RS-T's that require colder plugs.
99% of the orders placed before 3PM EST M-F ship the same day!
Here are some pics:
Sincerely,
David Kearney
Oakos Automotive
www.oakos.com
[email protected]
Tel: 248.969.2207
Fax: 248.969.4950
OAKOS Automotive is offline
Old 01-06-2003, 04:35 PM   #2
hpracingwrx
Gone... But not forgotten
Member#: 16772
2003 R6
i miss my rex....
hey dave
is iridium better than platinum? i always thought it was the other way around
i may be interested because i think mine r goin out although i only have 30k moderately modded
hpracingwrx is offline
Old 01-06-2003, 05:59 PM   #3
OAKOS Automotive
Member#: 18261
2002 Impreza WRX w/
V9 Spec-C EJ207
Iridium is better than platinum.
Here is a link to Denso's website.
-Dave
Old 01-06-2003, 09:51 PM   #4
RooK
Member#: 19472
2004 Mercedes C230k
Brilliant Silver
PERFECT timing! I'll be placing my order in the next day or two!
RooK is offline
Old 01-06-2003, 10:07 PM   #5
OAKOS Automotive
Member#: 18261
2002 Impreza WRX w/
V9 Spec-C EJ207
Excellent, I look forward to your order.
-Dave
Old 01-07-2003, 02:59 PM   #6
OAKOS Automotive
Member#: 18261
2002 Impreza WRX w/
V9 Spec-C EJ207
I just added the pics to the original post.
-Dave
Old 01-07-2003, 07:12 PM   #7
hpracingwrx
Member#: 16772
2003 R6
i miss my rex....
alright im in
Old 01-07-2003, 08:05 PM   #8
OAKOS Automotive
Member#: 18261
2002 Impreza WRX w/
V9 Spec-C EJ207
You have a PM.
-Dave
Old 01-08-2003, 01:33 AM   #9
AzSubie
Member#: 19285
2003 Cobra
What's the difference between the IK22 and IK20 Densos? I saw another vendor selling the IK20s for the WRX? I'm thinking about ordering some from you, but I just want to make sure they are the right ones for the WRX.
Thanks,
Pete
AzSubie is offline
Old 01-08-2003, 09:58 AM   #10
latinskllz
Member Sales Rating: (4)
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Default DO you have any for a turbo 2.5RS?
If so, then I'll be placing an order...
Thanks,
Kevin
latinskllz is offline
Old 01-08-2003, 10:42 AM   #11
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
ik22 are colder heat range plugs than ik20 ..
taken from denso site:
HEAT RANGE
The ability of a plug to dissipate heat from the combustion chamber to the cylinder head.
The heat range of a spark plug primarily depends on the length of the insulator nose.
Choosing the correct heat range is very important. Standard vehicles should use the heat range specified by the manufacturer. If your vehicle is not set to standard specifications you may need to change to a spark plug with a different heat range.
Spark Plug temperatures must remain between
450°C-900°C. Cooler temperatures won’t allow the plug to ‘self-clean’ by burning off carbon or oil deposits. This will lead to misfiring and poor acceleration. Hotter temperatures will cause overheating of the plug resulting in power loss, detonation, pre-ignition and possible engine damage.
Heat range numbering systems are different between plug brands. On a DENSO plug the lower the number, the hotter the plug so the higher the number, the colder the plug. Other Japanese companies use the same system, but European or United States companies use a numbering system that reads in the opposite way.
these plugs are what i am putting in when it comes time to get new plugs ..
$48 is a good price .. i think HKS sells these rebranded for $23 each!!
ronaldwrx is offline
Old 01-08-2003, 11:30 AM   #12
WRXGuyInUSA
Member Sales Rating: (3)
Member#: 13967
Bye Bye STI!!!
WOW I gain 7 tenths in the quarter mile!?!??!
WRXGuyInUSA is offline
Old 01-08-2003, 12:05 PM   #13
WeRX
Member#: 3652
1989 Honda Pirate
Type RRRRRR
I am logged in under my personal UN because I am having some slight problems with my Internet connection.
Pete,
Like ronaldwrx said these are one heat range colder than the OE plugs. The IK20's are an equivilant heat range to the stock NGK plugs.
Kevin,
I am not sure which plugs are recommended for a turbo'd 2.5. I will look into it further.
ronaldwrx,
Thanks for answering that for me.
WRXGuyInTulsa,
I wouldn't count on 7 tenths. The plugs they replaced in that test must have been in pretty poor shape to degrade performance to that degree.
David Kearney
Oakos Automotive
WeRX is offline
Old 01-08-2003, 02:35 PM   #14
HongKongBeef
Member Sales Rating: (1)
Member#: 1574
2016 WRX
Red
what is the typical mileage to replace your spark plugs? i heard 30K. thats where i'm at now.. i am interested.
HongKongBeef is offline
Old 01-08-2003, 03:18 PM   #15
WRXGuyInUSA
Member#: 13967
Bye Bye STI!!!
Originally posted by WeRX
WRXGuyInTulsa,
I know... I was being sarcastic
I'd like to see even 2 or 3 tenths...
Old 01-08-2003, 03:42 PM   #16
OAKOS Automotive
Member#: 18261
2002 Impreza WRX w/
V9 Spec-C EJ207
HongKongBeef, Subaru's recommended interval for the EJ20T is 60k miles. This is assuming the vehicle is otherwise stock though.
WRXGuyInTulsa, I figured as much. I was just making sure.
Latinskllz, I haven't found any info yet on the EJ25 plugs. I will keep looking though.
-Dave
Old 01-08-2003, 09:53 PM   #17
DannyGT
Member#: 6281
2002 Impreza WRX
Graphite Pearl - SOLD :(
Where do I order ??
DannyGT is offline
Old 01-09-2003, 12:22 PM   #18
OAKOS Automotive
Member#: 18261
2002 Impreza WRX w/
V9 Spec-C EJ207
Danny, Here is a deep link to the plugs in our online catalog. We offer SSL encrypted secure online ordering on the site and accept Visa, Mastercard, & Amex. If you would prefer to order by phone you can give us a ring at 248.969.2207. Thanks a lot!
http://www.oakos.com/Merchant2/merch...egory_Code=200
-Dave
Old 01-09-2003, 03:10 PM   #19
DannyGT
Member#: 6281
2002 Impreza WRX
Thanks, Im at work right now, so i'll prolly be ordering it later tonight or tomorrow.....thanks
DannyGT is offline
Old 01-09-2003, 04:04 PM   #20
hiro
Member#: 7885
2002 WRX Sedan
I received them today already!! Thanks Dave, that's really fast shipping
I got them for my 30k service, just in time
-Jenny
hiro is offline
Old 01-09-2003, 04:08 PM   #21
OAKOS Automotive
Member#: 18261
2002 Impreza WRX w/
V9 Spec-C EJ207
You are very welcome Jenny!
-Dave
Old 01-09-2003, 09:49 PM   #22
metaline
Member#: 11910
2002 WRX wagon
I just ordered mine for 30K service! Thank you very much!
metaline is offline
Old 01-09-2003, 11:34 PM   #23
OAKOS Automotive
Member#: 18261
2002 Impreza WRX w/
V9 Spec-C EJ207
Thanks a lot for your order! I will send you a shipment confirmation email tomorrow after they are sent out.
-Dave
Old 01-10-2003, 12:33 AM   #24
Brian Broz
Member Sales Rating: (6)
Member#: 13783
2008 2.5i Slow
Sorry for the dumb question,
but Is this 4 for $48.00?
Brian Broz is offline
Old 01-10-2003, 11:20 AM   #25
OAKOS Automotive
Member#: 18261
2002 Impreza WRX w/
V9 Spec-C EJ207
Brian,
Yes, this is for a set of four plugs. I edited the orginal post to make it more clear.
-Dave
Difference just in price or in performance, between NGK and Denso Iridium Spark Plugs SolidSnake Service & Maintenance 10 01-20-2006 11:31 PM
FS: Denso Iridium Spark Plug (IK22 one step colder) bigtahiki Private 'For Sale' Classifieds 1 02-15-2004 06:21 PM
FS: New Denso Iridium spark plugs 1 step colder and used Samco intercooler hoses scoobyhugh Tri-State Area Forum 3 02-02-2004 07:34 AM
FS: Denso Iridium Spark Plugs (IK20) slvrwrx02 Private 'For Sale' Classifieds 0 01-29-2004 01:23 PM
WTG: Denso Iridium spark plugs in HOU. Subergoobr Texas Impreza Club Forum -- TXIC 0 11-10-2002 05:00 PM
