Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 01-06-2003, 04:52 PM   #1
Idjiit
Member#: 5310
08 Highlander
95 Miata M
Default How does the American STi announcement effect Pro Rally?
Would have been better for Subaru to release a 2.0 STi in America? If the displacement is limited, it means that teams would have to start out with the non AVCS 2.0 liter WRX's instead of STis...?
Idjiit is offline   Reply With Quote
Old 01-06-2003, 05:16 PM   #2
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
I looked at the specs for the WRC rally car and it still has the 2 liter turbo...
ChrisW is offline   Reply With Quote
Old 01-06-2003, 05:39 PM   #3
Idjiit
Member#: 5310
08 Highlander
95 Miata M
Well, I KNOW it's not going to effect WRC... My question was regarding SCCA Pro Rally (and CARR for that matter). I don't know if their regulations limit displacement to 2.0L like WRC does.
Old 01-06-2003, 07:41 PM   #4
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I talked to Wayne at AV Sports today ordering something and asked him about it. He said they wouldn't be using them, and wouldn't sell them anytime soon. He said the 2.5T engines would require a smaller 34mm restrictor compared to the 40mm they are allowed to run with 2.0L. So chances are you won't see too many (anybody) running a 2.5L engine. It's basically aimed at the street-driving consumer, not at the rally community in NA.
Old 01-07-2003, 10:31 AM   #5
jprowland
Member#: 7298
2008 STI Black
2002 WRX Wagon White
2.5T engines run a 36mm restrictor in Open class under 2003 rules, not 34, since the adjusted displacement is over 4000 cc (2.5L * 1.7 turbo factor = 4.25 L). 4250 cc is still less than the 5100 cc Open class limit. You will probably see STi cars entered into ProRally Open class next year. You can still pump a lot of air through a 36mm hole...
For Production class, the adjusted displ is 2.5 * 1.7(turbo) * 1.3(4wd) * 1.2(4V/cyl) = 6.63L, putting it once again well into the PGT class and running a 32mm restrictor. I believe it'll be THE PGT car to beat, considering the competitiveness of non-turbo 2.5s in the class (with a comparable weight).
The car will have to be homologated before it's legal for Group N.
jprowland is offline   Reply With Quote
Old 01-07-2003, 12:28 PM   #6
Thug
Choke Artist
Member#: 603
Do you really think they will allow this car to run in PGT? If so that's crazy. I cant think of any car that will be able to touch it. The only question for either class are the brakes, which are huge. Those Brembos only fit under 17s. So you'd have to change the brakes.
Thug is offline   Reply With Quote
Old 01-07-2003, 12:30 PM   #7
Kha0S
Member#: 8808
2011 WRX (DGM 5D)
2002 WRX/2003 SVTF
I'm hoping that the SCCA either excludes the 2.5T from PGT or splits into a P# arrangement like CARS, because with PGT containing 1.8L N/A AWD Impreza all the way through a 2.5L Turbo AWD Impreza, it's just getting too broad.
/Andrew
Kha0S is offline   Reply With Quote
Old 01-07-2003, 01:32 PM   #8
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
The old 4-pots and rotors should be a bolt-on affair. You could buy the brakes and a set of wheels for what someone might pay you for the take-offs.
Old 01-07-2003, 01:45 PM   #9
Thug
Choke Artist
Member#: 603
True. But the rear Brembos also require different hubs. So you'd need the other hubs or a $325 adapter.
Old 01-07-2003, 02:24 PM   #10
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I think those would fit with 15" wheels, they look to be the same size as the old 2-pot rears. The car would look a little funny with gold brakes just on the back, but if it's a rally car who cares.
Old 01-07-2003, 03:10 PM   #11
Thug
Choke Artist
Member#: 603
Yeah. I just dont know much that will throw off F/R braking proportions. Dont really want the rear brakes to overkill the fronts.
Old 01-09-2003, 01:43 PM   #12
Mike Anson
Member#: 7915
low altitude barrel
rolls our speciality!
In the rulebook, 10.2.F.7, it states that the cars must weigh 1.05 pounds per adjusted cc. If the STi is 6630 adj. cc then wouldn't it have to weigh 6,961 pounds to be PGT legal? For that matter, shouldn't all PGT WRX's weigh 5,569 pounds (adj displacement = 5304cc)? Am I missing something?
I smell protests.
Mike Anson is offline   Reply With Quote
how does the wrx/sti 2.5 engine hold up? idklol Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 04-02-2010 05:37 PM
How does the oem STI diffuser mount on the 07s? JDMFLCL Newbies & FAQs 7 04-01-2009 08:35 AM
How does my car look when a pro takes the pics.... jetfan8178 Member's Car Gallery 28 05-09-2007 12:11 AM
How does the Eibach Pro Kit Springs rate? Daredevil Brakes, Steering & Suspension 4 03-15-2003 07:14 PM
How does the stock tranny hold up in rally cross say 280whp and 250wlbs? 2002 WRX mrtrex Motorsports 4 07-05-2002 06:25 PM
