Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 01-06-2003, 04:55 PM   #1
newscooby
Member#: 995
2000 MkIV GTi&23 LSV
Red cars PWN me
Default Did I read this correctly??
4-wheel fully independent sport-tuned suspension with inverted front strut
/\ From Nick's post.
Why are just the front struts inverted. Please correct me if I'm wrong, but does the STi everywhere else have inverted struts all the way around??
Is this some sort of cost compromise?? We'll get the stronger inverted struts in front and just retuned WRX dampers in the rear??
Or is this all just a weird dream
mike
newscooby is offline
Old 01-06-2003, 05:01 PM   #2
pio!pio!
Member#: 4190
2008 Impreza WRX STi
fronts AND rears are inverted.. read the speech...i think the press release isn't correct..or the speech isn't correct..
but it makes more sense for all the struts to be inverted
pio!pio! is offline
Old 01-06-2003, 05:05 PM   #3
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
Yes, they are all inverted.
gjhsu is offline
Old 01-06-2003, 11:57 PM   #4
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
The suspension gallery caption says:
New inverted struts in the front and rear for quicker
ANZAC_1915 is offline
Old 01-07-2003, 12:16 AM   #5
RA29
Member#: 30598
2000 Lancer Evo 6
Hot Pink
What's the effect of having "inverted struts"?
Thanks
RA29 is offline
Old 01-07-2003, 12:20 AM   #6
Dickie
Member#: 28721
Location: Surrey, BC, home of cheap rides of *all* kinds.
You can drive upside down.
Alright, alright....
Dickie is offline
Old 01-07-2003, 12:22 AM   #7
'04 STi
Member#: 4863
The inverted strut design was learned thru WRC racing. They flex less under hard cornering allowing the suspension to work the way it was intended.
Bill
'04 STi is offline
Old 01-07-2003, 12:26 AM   #8
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I believe they lower the unsprung weight too.
Old 01-07-2003, 12:27 AM   #9
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default unsprung weight
The classic explanation you will find in any suspension and handling book is that inverted struts reduce unsprung weight. This, of course, improves handling (and ride). It may very well be true that they "flex less under cornering..." too
vvk is offline
Old 01-07-2003, 12:27 AM   #10
Porter
Member#: 486
2004 Forester XT
bug spattered
Actually, to clarify....
The inverted strut setup provides lower unsprung weight by moving the heaviest part of the strut up and connecting it to the body... so the weight of the strut housing doesn't become a drag on the suspension action.
Lower unsprung weight = good.
Porter is offline
Old 01-07-2003, 12:29 AM   #11
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Ok another n00b here.
What is unsprung weight then?
Thanks in advance,
-paK +0
Pakin is offline
Old 01-07-2003, 12:46 AM   #12
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Unsprung weight is any piece of the car not supported by the suspension springs. (i.e. wheels, tires, generally 50% of suspension arm weight, etc.)
Old 01-07-2003, 01:31 AM   #13
RA29
Member#: 30598
2000 Lancer Evo 6
Hot Pink
Ah thanks for the explanation.
I got the inverted front struts too
RA29 is offline
Old 01-07-2003, 01:52 AM   #14
whoobaru
Member#: 12674
2002 Impreza WRX
On motorcycles, inverted forks are actually heavier. The main purpose (on motorcycles) is to reduce flex and control suspension movement. I figured it would be the same for the new STi's struts, but I guess I could be wrong. Anybody know for sure?
whoobaru is offline
Old 01-07-2003, 07:07 AM   #15
Fuzz541
Member#: 4739
On a motorcycle, the fork is the only front suspension member - it has to control vertical suspension movement and inhibit horizontal flex. There is no suspension arm to help locate the front axle, etc. (certain BMWs Bimotas and one-offs excepted, of course). Therefore, the engineers are willing to trade some weight for improved stiffness.
The increased overall dimensions of the fixed sliders on an inverted fork may increase the overall weight. However, I suspect the stanchions (inside sliding part), axle, wheel and brakes on an inverted fork weigh less than the sliders (outside sliding part), axle, wheel and brakes weigh less than those on a standard fork for a given bike.
As an example, the original Honda CBR900RR had a standard fork with a 16" front wheel at a time when all "serious" sport bikes had inverted forks and 17" wheels.
I belive they did this for light overall weight and a quick-steering front end. They have since gone to an inverted fork and 17" wheel, ostensibly for improved stiffness and stability.
I believe the overall weight of the bike has gone down over that time as well, through various design changes to the frame, etc.
Any sportbikers care to jump in here?
Bottom line: I belive the purpose of inverted struts/shocks on a car is to reduce unsprung weight first and any benefit in stiffness is incidental.
Fuzz541 is offline
Old 01-07-2003, 10:16 AM   #16
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
about the unsprung wieght issue... I have the V5 suspension and it was much heavier than the stock struts, and it was still balance biased towards the bottom(if I remember right, ti's been a year and a half since I did the swap), so I don't think it really makes much difference in unsprung weight. Of course, it could be that the V5 is just a heavier design regardless of the inversion, so making it inverted did help unsprung weight, but only in comparison with itself were it not inverted.
Damn, I think I just confused myself with that sentence...
mrbell is offline
Old 01-07-2003, 12:29 PM   #17
mtb_dude
Member#: 12619
02 WRX Wagon
#47 SM w/RA gears
The old saying is 1 pound of unsprung weight is about equal to 4 pounds of sprung weight. So a car with 25 more pounds of unsprung weight (which is not much if you think about it *cough* aftermarket heavy wheels *cough*) feels as heavy as a car with 100 pounds more sprung weight.
I don't think an inverted fork or strut is anywhere near twice the weight, but even if it were, it would still be beneficial to go inverted.
mtb_dude is offline
Old 01-07-2003, 12:37 PM   #18
merlot
Member#: 16935
2012 Volvo S60 T5
2013 VW CC R-Line
Now here's a question. If '02/'03 owners decide to purchase the STi suspension upgrade, will they now offer the inverted struts? Or are there more parts to make this work other than the struts?
MSD
merlot is offline
Old 01-07-2003, 12:50 PM   #19
Retro
Member#: 19733
BLOOO
I wonder who supplies the suspension parts? Would this be an inhouse operation or perhaps rebadged from Bilstein/Koni/whatever?
Retro is offline
Old 01-07-2003, 12:53 PM   #20
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
MSD
I'm pretty sure you already get the inverted struts if you get the suspension upgrade. Inverted struts are nothing new on the STi.
driggity is offline
Old 01-07-2003, 12:57 PM   #21
j y
Member#: 8829
GRB STI
I believe the current STI/SPT suspension upgrade consists of inverted struts already (same struts from the international Impreza WRX STIs).
-Jeff
MSD
j y is offline
Old 01-07-2003, 12:58 PM   #22
mtb_dude
Member#: 12619
02 WRX Wagon
#47 SM w/RA gears
Yup. They LOOK like right-side-up struts, but the internals are all up-side-down.
mtb_dude is offline
Old 01-07-2003, 01:35 PM   #23
merlot
Member#: 16935
2012 Volvo S60 T5
2013 VW CC R-Line
Hmmm. I thought I remember reading somewhere that when they did the face lift, they made changes to the JDM & EDM STi which included inverted struts, along with some engine improvements. Also remember reading an article about a test drive and how the car handled better...
MSD
merlot is offline
Old 01-07-2003, 02:01 PM   #24
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
There are supposedly some differences in the suspension, but the inverted design is not one of them. I don't know what the differences are though. It might just be a difference in the way the valving is done. There's a little bit of info in this thread on scoobynet. http://www.scoobynet.co.uk/bbs/threa...hreadid=164036
driggity is offline
Old 01-07-2003, 02:05 PM   #25
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
KYB has typically done the suspensions for Subaru, tho Bilstein often steps in as well... So it will likely be one of the two, w/ my money on KYB
mrbell is offline
Downpipe mech fix reliability? Does it read AFR correctly when logging/Learning Views MAtwal Engine Management & Tuning 1 03-06-2010 02:13 AM
Am I reading this correctly??? 96WRX North West Impreza Club Forum -- NWIC 3 08-04-2008 09:54 PM
Did I install this rear sway bar correctly? virjose Brakes, Steering & Suspension 11 04-25-2008 09:29 PM
Reading dipstick correctly and amber bulb question Hank3 Newbies & FAQs 4 04-22-2004 11:37 PM
