Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 01-06-2003, 05:11 PM   #1
hobbzz
Member#: 24172
04 STI
JBP
Default USDM STI 6-speed into USDM WRX?
First off...I usually don't post these "what do you think it will be like when it gets here" threads that can't be answered but...I'm assuming/hoping this will work(refering to title of thread)? If so could someone expect the price to drop dramatically? A brand new '02-'03 tranny goes for about 1200 to 1800 depending on which dealer you want to rip you off . Would 2k-4k be a good guess?
hobbzz is offline   Reply With Quote
Old 01-06-2003, 05:50 PM   #2
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
The cost of the Tranny itself might be more accessible, but you've still got all of the other issues to sort out. Center Diff, front diff, half shafts, rear end, etc...
Zahnster is offline   Reply With Quote
Old 01-06-2003, 05:53 PM   #3
8Complex
Member#: 922
04 FXT
Red
A brand new manual trans for the dealership is ~$2800. Don't know what numbers you're looking at.
Old 01-06-2003, 07:36 PM   #4
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
A used "junk" 5-spd tranny is around $1500.
If the STI comes in with a 3.54 rear diff like the WRX, it will be a simple drop in mod only needing the tranny, driveshaft and shift linkage.
I do hope the used price gets into the $3000 range. That would be super nice.
Kevin
Red Rocket is offline   Reply With Quote
Old 01-06-2003, 07:44 PM   #5
hobbzz
Member#: 24172
04 STI
JBP
Anyone know what the diffs are?
Old 01-06-2003, 08:15 PM   #6
8Complex
Member#: 922
04 FXT
Red
A decent-condition (usable) used WRX 5MT is anywhere from $1000-1500 in all the junkyards that I can search through.
I was goign to correct you on the differential ratio, however I found the following on RalliSpec's site:
Please note that US-spec. WRX models use a 1.100 transfer drive ratio with a 3.545 rear ratio and 3.900 front. Contact us for pricing on a 1.000 transfer ratio set.
Old 01-06-2003, 09:35 PM   #7
Stefx
Member#: 20615
2003 5sp Wagon WRX
Doesn't the STi MT include a front LSD?
I saw somewhere that the front, center and MT are all included in one component.
That would make the STi tranny much more expensive than that
Stefx is offline   Reply With Quote
Old 01-06-2003, 10:02 PM   #8
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
They are all in one unit. Front Suretrac diff along with the electronic center diff and all the components you need to run it... Brand new you are looking at $5k+ easy, there is a world of difference between the 5MT in the WRX and the 6MT. Right now a brand new one with a viscous center diff is around $6k from SOJ. The DCCD version is obviously more. Then you still need a new ring/pinion for the rear as well as the rear propshaft, shift linkage, etc. I would say if you want to buy a USDM 6-speed NEW you'll spend $7500.
The "Auto" mode would not work since you are undoubtedly missing the wheel sensors and whatnot to make that work. If you do make it work that's more money.
We don't have the same ABS system as the STi, which is designed to work with the DCCD. None of the cars previous to this years STi that had the DCCD had ABS. So ABS is gone.
Phil
Old 01-07-2003, 08:41 PM   #9
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
By "junk" I mean junkyard....
Kevin
Old 01-08-2003, 10:26 AM   #10
8Complex
Member#: 922
04 FXT
Red
Ahhhh, thought you meant junk as in pre-broken. My bad.
Old 01-08-2003, 12:43 PM   #11
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Phil
so to get a sti tranny I would have to install the abs system along with the trany and its assored parts? If so it would be cheeper to get a jap spec sti tranny and throw in us gears... which im assuming are taller or is it shorter? I can never remember...
Old 01-08-2003, 10:51 PM   #12
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
No one knows what the ratios of the US transmission are going to be. I think with the torque of the car it'll use longer ratios than the JDM version, but we'll have to wait and see. The only thing that makes the jap spec one cheaper is you can find used or take off ones. You can also get them without the DCCD, which would let you keep your ABS working normally.
It's a $5k+ proposition any way you look at it.
Phil
Old 01-12-2003, 03:26 AM   #13
aspera
Member#: 7879
USDM STi appears to only come with DCCD. And it appears to be a new version of DCCD, where ABS is used. This version of ABS can apply different brake pressures side-to-side (EBD). The new STi also uses an R180 diff with a temp sensor screwed into the back. That must be needed in case all of the torque is biased to the rear in manual mode...and raced.
On the bright side it appears that it uses a 3.9 final drive ratio. I'm assuming that the rear is 3.54, but I haven't found out.
Also used is fly-by-wire throttle body. It has been suggested that a traction control/yaw control system is being built into place bit by bit.
Maybe the best hope is for an optional non-DCCD 6 speed in either the WRX or STi in years to come.
aspera is offline   Reply With Quote
Master swap list for 04-07 Sti 6 speed into WRX crashtke Transmission (AT/MT) & Driveline 796 04-29-2015 09:11 PM
STi 6 speed into WRX swap clutch options? Bayley Subaru Conversions 13 03-30-2014 02:02 PM
04 STI 6 speed into 03 WRX and vice versa I'm Slow Transmission (AT/MT) & Driveline 14 08-10-2009 07:52 PM
'02 JDM sti 6 speed into '07 wrx auto mbelitsk Subaru Conversions 8 05-07-2009 04:42 PM
How to put a 2007 usdm sti 6 speed into my 2003 WRX InfamousDX Transmission (AT/MT) & Driveline 11 10-27-2007 12:54 AM
