Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 01-06-2003, 05:59 PM   #1
gtr
Member#: 4011
2010 WRX STI SE
Default Anybody know the weight? Twin scroll and limited front diff?
I couldn't find this info anywhere. If anybody already has or know please advise.
Everything sounds good so far. Maybe i'll be getting the sti instead.
gtr is offline
Old 01-06-2003, 06:00 PM   #2
Kha0S
Member#: 8808
2011 WRX
DGM 5D
No twin scroll, it appears, but front LSD is a SureTrac.
/Andrew
Kha0S is offline
Old 01-06-2003, 06:02 PM   #3
gtr
Member#: 4011
2010 WRX STI SE
What the heck is a SureTrac
Besides being the front diff.
gtr is offline
Old 01-06-2003, 06:03 PM   #4
KC
Member#: 442
16 SS
00 S2000
Impreza WRX STi employs a new Suretrac® limited-slip front differential and a mechanical limited-slip rear differential. The Suretrac differential is a gearless unit that responds to a torque differential between left and right wheels to increase traction and reduce understeer.
KC is offline
Old 01-06-2003, 06:07 PM   #5
MulletSlayer
Member#: 7044
2015 Crosstek
I read in Evo that the STI with the twin scroll turbo does not produce the same boxer exhaust note that Subaru is known for, so I am glad there is no twin scroll.
Who wants a Scooby that sounds like a Honda.
MulletSlayer is offline
Old 01-06-2003, 06:08 PM   #6
ryball
Member#: 10433
1942 Kettenkrad
WR Blue Pearl
So for us mechani-retards... is that good or bad?
ryball is offline
Old 01-06-2003, 06:12 PM   #7
RafalW
Member#: 8193
2008 WRX STI
I found this:
The Suretrac Diff. is made by AP Racing. The same company as the big
brake
kits and performance clutches.
I have AP's catalogue in front of my and I will tell you what it says;
- Excellent packaging results in a direct replacement for the open
differential.
- Proven durability on road, road simulation and race track.
- Senses torque, does not require prior wheel slip
- Operates in conventional lubricants including ATF.
- Constant performance with respect to speed, torque, and temp.
- ABS compatible
- Supplementary to, and compatible with, electronic traction control
".. The suretrac device itself sustains differential torque across
driven
axles and directs the greatest torque to the tire with the best grip,
offering improved differential action particularly in adverse conditions
with
enhance handling and cornering"
" Suretrac utilizes an arrangement of opposing cams and followers which
enables the device to transmit whatever unequil torque the tire contacts
can
withstand, upto a torque limiting ratio set by the design"
Hope this helps you guys out,
RafalW is offline
Old 01-06-2003, 06:12 PM   #8
MPREZYA
SCIC
Member#: 85
That is good. Consider it like having a posi in the rear and a mechanical (kazz type much stronger than the torsen types) in the rear. It should make for a mean handler that can put the power down big time.
MPREZYA is offline
Old 01-06-2003, 06:15 PM   #9
C-daleRidr
Member#: 18074
2008 Speed3
Please correct me if I am wrong, but I thought that the purpose of the twin scroll was to help the turbo spool up a little quicker, thereby reducing the amount of loss at the low end. Since the 2.5 hits its peak torque at only 4,000 rpm, it would seem as if that problem is taken care of, assuming that the low end between 0 and 4000 rpm is as impressive as it sounds like on paper.
C-daleRidr is offline
Old 01-06-2003, 06:19 PM   #10
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Exclamation
I think the 2.5L will take care of the apparently lack of torque down low.... so really no need for twin-scroll turbo?
kgb is offline
Anybody know the weight to the stock trailing arms Flaroc01 Brakes, Steering & Suspension 10 04-02-2007 11:05 AM
Anybody know the kids that crashed and got killed in their WRX in Montgomery County ? SubyNewbie Mid Atlantic Impreza Club -- MAIC 0 10-23-2002 11:05 AM
Anybody know the weight difference . . . 2.5GT Legacy Forum 5 11-21-2001 12:08 AM
anybody know the diff. between GT and OB springs? sybir Legacy Forum 5 05-01-2001 07:10 PM
Anybody know the turbine type/size and a/r ratio for the Minnam turbocharger? delectron Technical Forum Archive 15 10-05-2000 11:29 AM
