Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 01-06-2003, 09:35 PM   #1
liigod
Member#: 30512
01 2.5rs
black
Default what does the sti mean to 2.5 NA motor owners?
So does this mean that our blocks will be compatable with the wrx sti parts? Does this mean that we can turbo our cars with parts from crashed stis? this will be AWESOME if it works!
IM excited to find out...
liigod is offline
Old 01-06-2003, 09:36 PM   #2
tt_ttf
Member#: 4431
MY07 STi and '06 WRX
Urban Grey & WRC Blue
Default Re: what does the sti mean to 2.5 NA motor owners?
I very much doubt it
There is ALOT of changes in that engine to make sure it survives 300hp
tt_ttf is offline
Old 01-06-2003, 09:49 PM   #3
liigod
Member#: 30512
01 2.5rs
black
yea i understand replaced parts, but those could fit right up too? like rods pistons crank ect?
liigod is offline
Old 01-06-2003, 09:53 PM   #4
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
I was thinking the same thing. I hope, I hope, I hope!
HondaH8er is offline
Old 01-06-2003, 09:55 PM   #5
HOKWRX
Member#: 5469
2004 Impreza
The 2.5 STi block has semi-closed deck!!!
HOKWRX is offline
Old 01-06-2003, 10:06 PM   #6
liigod
Member#: 30512
01 2.5rs
black
arent 2.5rs's?
liigod is offline
Old 01-06-2003, 10:29 PM   #7
Ken S
Member#: 1895
05 Leg GT Ltd. W
Wink
Don't forget the DOHC and AVCS as well...
Ken
Ken S is offline
Old 01-06-2003, 10:31 PM   #8
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Bah, engine or drivetrain swap!
garface is offline
Old 01-06-2003, 10:54 PM   #9
Benjamin Tang
Member#: 4496
2009 Forester
red
too bad huh... i guess the only thing the NA 2.5 and this turbo 2.5 is displacement
Benjamin Tang is offline
Old 01-06-2003, 11:21 PM   #10
liigod
Member#: 30512
01 2.5rs
black
Ken
ah but those are just the heads, you can put those on a 2.5rs i hope ::drools::
liigod is offline
Old 01-06-2003, 11:25 PM   #11
HOKWRX
Member#: 5469
2004 Impreza
How are you going to install AVCS? It is almost impossiable and might cost you as much as an STi engine.
HOKWRX is offline
Old 01-06-2003, 11:27 PM   #12
liigod
Member#: 30512
01 2.5rs
black
thats variable valve timeing right?
in the past you can put different heads on blocks for example i know volkswagen dudes who have put the 20 valve 1.8t head on the 8valve 2.0 block cus they are the same block with a different bore ect...
liigod is offline
Old 01-07-2003, 12:12 AM   #13
tt_ttf
Member#: 4431
from what info seems to comming out - forget it
different heads & associated electronics
different block all together - more like the older 2.2 liberty engines than the RS so using the heads would be questionable
different crank, rods, pistons etc
so much that I suspect it would be simpler to buy a new crate engine rather than all the parts.......
tt_ttf is offline
Old 01-07-2003, 12:15 AM   #14
NC2.5RS
Member#: 19313
2007 Scion tC
Black Sand Pearl
Thats why you just go with a full drivetrain swap. Engine and tranny,and ECU. Mmm.... GC8 RS with a 300hp/300 torque engine and a 6 speed. That thing would HAUL. It would cost a pretty penny though.
NC2.5RS is offline
Old 01-07-2003, 12:19 AM   #15
JamesNUTT
Member#: 22736
2001 Impeza RS
I just want the trany to work. That's all I'm worried about. I can build up my motor enough to make me happy. But 2000 on gears for the trany that I have just don't make since.
JamesNUTT is offline
Old 01-07-2003, 12:28 AM   #16
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Regardless of a semi-closed block, I'm willing to bet that you can swap all the internals into an open deck EJ25.
However, I am curious if you can buy a short block (like the EJ22T) for a cheap price. OR, just the new low compression pistons and swap them into the EJ25 block. If so, I might just buy the pistons and swap them into my block.
And about the heads, just swap your heads onto the block and do without the variable valve timing.
Eric
Eric SS is offline
Old 01-07-2003, 03:04 AM   #17
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Cheaper option, just buy a brand spankin new AVCS DOHC EJ25:
http://www.noztune.com.au/engines01.htm
Kostamojen is offline
Old 01-07-2003, 08:53 AM   #18
Crawdads
Member#: 30907
SWP GDB-G
It means that now RS owners can do the engine swap and not have to remove the 2.5RS badges.
twofive pride!
Crawdads is offline
What can I use off a 2.5 NA legacy motor? bigolrig Newbies & FAQs 7 06-02-2009 03:41 PM
2.5 STi rods and 2.5 NA rods. Way to tell? ebeck Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-21-2005 03:29 AM
how much HP/torque can U get from a 2.5 NA motor JC_595 Normally Aspirated Powertrain 23 05-26-2005 12:55 PM
Want to buy 2.5 NA motor mafiamotorsports Private 'Wanted' Classifieds 0 11-07-2004 07:00 PM
Stupid Question. A 17x7.5 with a ET48. What does the ET mean? 2.2gotboost Tire & Wheel 4 03-01-2004 05:14 AM
