#1 |
Member#: 4817
NESIC
Vehicle:2012 STI, '02 WRX '91 MR2, '05 Speed Triple |
Ok... so the WRX gets crummy gas mileage, we all know that. Throw in 25% more displacement and, I'm presuming, more boost, and are we going to be looking at high teens for highway mileage, and 12's for city driving? As it is I get around 23-25 in normal driving, and i might get 30 in solid highway driving.
I know, probably nobody cares, but I think this is a pretty important factor in a new car. ![]() -tim
#2 |
Member#: 23784
Vehicle:2005 M3 Tiag |
good point, but I think the Varable Valve Timing might help that out a bit. And it said something to the effect that this car has a lot better low end performance, which is IMOP what caused some of the milage issues on our cars.
#3 |
Member#: 6074
Vehicle:2002 Impreza WRX Sedona Red Pearl |
But it's got AVCS! Look what VTEC/VVTL-i does for gas mileage.
I predict 31/26 gas mileage! not Last edited by Skyline; 01-06-2003 at 10:21 PM. |
#4 |
Member#: 4496
Vehicle:2009 Forester red |
it does have 6 gears... maybe the ratios and the overdrive 6th will help things out?
#5 |
Member#: 11316
Vehicle:2004 STi E30 325is |
Ha, skyline is very correct. VTEC/VVTL-i destroys a cars gas mileage in cars that have it for performance reasons(not civics or camry's). When i engage VTEC often in my prelude my gas mileage almost gets as *****ty as a Ferrari.
#6 |
Member#: 6074
Well, it is true that if you drive a variable valve timing car like a Grandma, you will improve your gas mileage greatly.
So I suppose if you keep the RPMs under 2000, it'll have good gas mileage. You'll sure be shifting a lot! ![]() |
#7 | |
Member#: 7453
TXIC
Vehicle:2005 Legacy GT Wagon 2006 LJ Rubicon |
As for the 6 speed. Who knows what that will do. I believe the Type RA 6-Speed has the gears so closely spaced that 6th is actually lower than the WRX's 5th. In theory the extra displacement could help out by allowing you to stay out of boost more than with the WRX. Unless you do everything at WOT. |
#8 | |
Member#: 11316
#9 | |
Member#: 10607
Vehicle:'04 magic trianglez 44CS - www.phillyscca.com |
in my 200hp RSX-S, i could go thru a 1/4 tank in one day of autocrossing (6-7 runs)...almost entirely spent above 6k. but i got 30+ mpg (usu. about 32) in highway driving and a steady 26 in fairly aggressive city driving. NO complaints there. (as a comparison, my 130hp Protege has yet to top 30 mpg on the highway and 25 in gentle city driving...not taking it over 4k. but at least it takes regular gas as opposed to premium.) |
#10 |
Member#: 456
NWIC
Vehicle:2008 Forester XT Steel Gray Metallic |
I think it fair to say the STi is not for the gas frugal.
#11 | |
Member#: 3251
NWIC
Vehicle:2009 WRX Hatch DGM |
#12 | |
Member#: 6074
#13 |
Member#: 7621
Get an civic dx if you want good gas mileage?
#14 |
Member#: 18602
Vehicle:2005 Moller Skycar glow in dark purple |
Here's what you dont know yet... final drive, compression ratio, turbo size actual gearing of the 6 speed.. What I find interesting is that the 2.5 puts it out of the rally specs (I think). I bet its designed for the US market for what the US market thinks it wants. I'm guessing that the compression ratio, final drive and gearing make for a car with lots of on-demand torque and decent gas milage as long as you drive it without 'gusto'. I expect it to be a little less raw edged than what people are thinking currently. Until the physical specs come out we wont know (weight, CR, turbo, boost, gearing, final drive..). If it has the same base line as the WRX it will be awesom. Think, its fairly easy to mod a WRX from 227 to 300. Apply the same ratio and the STI goes to 396. If they tighten it up with a higher compression ratio and high final drive it may be a little less appealing at the price. Expect about 35,000 out the door for the 1st year or so. This is car, tax, tag title etc. Maybe a tad more the first 6 months...Unless the economy is still in the doldroms this summer. Then you may be able to pick one up below MSRP if you just play vulture.
#15 | |
Member#: 11316
#16 |
Member#: 24043
Vehicle:2005 Legacy GT Sedan Silver |
I don't think it will get less than 18/24 for city/highway. It may perhaps hit 20 city and as high as 25 or 26 highway if you barely touch the 'happy' pedal. As tolnep stated, there are a lot of factors who don't know much about yet.
#17 |
Member#: 24043
I looked up to see what the JDM-spec STi with EJ20 & Twin Scroll is producing for average fuel economy (mixed city/highway driving) and they average about 24.5mpg and their 250ps WRX model averages about 27.75mpg using the same measurement. I doubt we'll lose any more than 1 mpg, if that to the JDM-spec STi. Remember, we probably are running a little less boost too. I guess we'll all find out on saturday.
#18 | |
Member#: 4817
NESIC
-tim |
#19 | |
Member#: 10607
#20 | |
Member#: 12619
Vehicle:02 WRX Wagon #47 SM w/RA gears |
#21 | |
Member#: 4817
NESIC
#22 | |
Member#: 4190
BAIC
Vehicle:2008 Impreza WRX STi Aspen White |
#23 |
Member#: 4817
NESIC
#24 |
Member#: 23346
Vehicle:02 Silver WRXwagon 07 RAV4 V6 09 Mazdaspeed3 |
At least the gas will be being used for a good and worthy purpose: absolutely flying down back-roads, instead of lumbering to the local Safeways.
As for not causing damage to non-huge vehicles, The STi may be half the weight of an SUV, but in an accident it is quite likely to be travelling at much higher speeds. Purely in terms of energy, a 3500lb STi (or any car) needs to be doing only 42mph to have the same destructive capability as a 7000lb SUV weighing doing 30 mph. Though at least this energy would be directed at a height regular sized vehicles are designed to try and absorb. Remember your physics: Kinetic Energy = 1/2 * mass * velocity^2. As you can tell, I'm bored at work today Cheers Alun |
#25 |
Member#: 4496
honestly people.... if u can afford this car, i'm pretty sure u can afford the gas! you would be more concerned about the stupid grin on your face
| Thread Tools | |
| Display Modes | |
| Bigger Injectors-Worse Gas Mileage or Oxidizing Gas? | Coop1103 | Factory 2.5L Turbo Powertrain | 4 | 11-27-2009 05:55 PM |
| Horrible Gas Mileage/Raw gas smell in cabin | ScoobySnacker | Factory 2.0L Turbo Powertrain | 9 | 12-18-2007 07:14 PM |
| Crappy gas mileage, heat + winter gas? | Psydotek | Southern California Impreza Club Forum -- SCIC | 17 | 02-16-2006 02:41 AM |
| ('93-'01) Double-Clutching, Rev-Matching, and Gas Mileage? | TimStevens | Impreza Forum | 4 | 05-11-2001 10:09 AM |
| Gas mileage with supercharger!! 305 miles to a tank of gas. | ARG | General Forum Archive | 15 | 06-22-2000 12:39 AM |
