Old 01-06-2003, 10:26 PM   #1
mrmcderm
Member#: 25294
2003 LR Infiniti G35
WRB WRX Wagon (Sold)
Default Engine Hesitation
I'm getting a weird engine hesitation around 5k-5.5k rpms in all gears in my '03 wrx wagon and was wondering if it was always there and is normal, or if I should be concerned. The only engine mod I have done is to pull the silencer.
I'm running 93oct from various vendors in central illinois, so maybe it's winter gas causing the ecu to pull timing?
I don't have an OBDII connector, or an auxillary ecu so I haven't been able to pull any codes to see if i'm det'ing or not, but I am not hearing anything.
I suppose 5250rpms is about the top of the stock torque curve, but torque isn't droping off smoothly, it feels like the car just stops accelerating until I shift again.
Anyone else have this kind of hesitation? Is this normal?
tia,
m
mrmcderm is offline   Reply With Quote
Old 01-07-2003, 03:21 PM   #2
mrmcderm
Member#: 25294
bump
Old 01-07-2003, 04:06 PM   #3
Nutter
Member#: 7185
2005 C55 AMG
Brilliant Silver Metallic
I get this from time to time on my 03, but when I Drive-It-Like-I-Stole-It it clears up ! But then I only have 2k miles on the car so I have been easy on it until a few weeks ago.
Nothing to worry about unless you start throughing codes/lighting CE lights.
Nutter is offline   Reply With Quote
Old 01-09-2003, 03:05 PM   #4
mrmcderm
Member#: 25294
I'm not getting a CEL, but I still don't think it is normal which is why I asked about it. Any one else experience this or have any insights?
Old 01-09-2003, 03:24 PM   #5
robtmc
Member#: 23659
Chapter/Region: HIIC
2002 WRX Sport Wagon
Platinum Silver
This post may or may not be applicable. I don't get a hesitation, but my 02 with 91 octane sure feels flat up there at WOT. I started a thread to see if anyone knew if 91 would cause timing to be pulled, but no resolution yet......
http://forums.nasioc.com/forums/show...hreadid=282589
robtmc is offline   Reply With Quote
Old 01-09-2003, 07:03 PM   #6
SubbyRS
Member#: 17193
1991 Legacy RS
does it hesitate beyond 5500rpm? in other words is it a flat spot as opposed to running out of puff....
SubbyRS is offline   Reply With Quote
Old 01-10-2003, 12:10 AM   #7
mrmcderm
Member#: 25294
It really feels it instantly stops pulling...I can let the rpms build up through 6k, but I don't bother...there is a noticible drop in torque at around 5250 and I don't think it was there before. I'm going to try resetting my ECU and see what that does for me.
Old 01-10-2003, 01:37 AM   #8
swan
Member#: 31621
white
Does it feel as if the engine totally cuts out? Could be the ECU detecting overboost and cutting fuel?
swan is offline   Reply With Quote
Old 01-13-2003, 12:55 PM   #9
mrmcderm
Member#: 25294
No, it is definately not cutting fuel...I know what that feels like, and it wouldn't be from overboost...the only thing aftermarket on the car is the boost gauge and it has never gone above 15psi.
Not really sure what the problem is, I suppose I'll just have to get the OBDII kit and software and see if it's pulling timing.
Old 01-13-2003, 08:28 PM   #10
Bardiel
Member#: 11435
2002 Sleeper Impreza
Blackie:)
Default Yup same thing happen to me
Yeah, this also happened to me. I did the grounding mod and it took care of that. Apparently, some of the the WRX models that came out wasn't grounded good enough. So, I bought some 8 gauge wires and ground it in 5 different places in the engine bay and the hesitation is gone....at least I don't feel it anymore.
Bardiel
Bardiel is offline   Reply With Quote
Engine Hesitation and Check Engine Light Bricoleur Outback Forum 2 03-22-2004 08:09 AM
engine hesitation, revisited (no enginemanagement) vile Factory 2.0L Turbo Powertrain 8 02-05-2003 03:16 AM
Engine hesitation at shift? DtownIan Factory 2.0L Turbo Powertrain 1 01-09-2003 06:01 PM
Stupid Engine Hesitation Rags Normally Aspirated Powertrain 12 02-26-2002 09:19 PM
Weird engine hesitation and CEL Impreza25RS Normally Aspirated Powertrain 1 01-08-2002 03:24 AM
Message Board Statistics All times are GMT -4. The time now is 03:21 PM.
