Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 01-06-2003, 10:28 PM   #1
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Default redline? weight? more specific specifications anywhere?
Is there another website ith more info out there? Engine redline, I'm guessin will be around 7000-7500. Hopefully it hasn't gotten much fatter either, but 6 speed, beefier diffs, larger engine, all weight gainers. So if it is 300 hp, and 300 lb-ft, we are lookin at 225 hp and 225 lb-ft to the wheels, if the drivetrain loss is similar. Not that much more impressive than the 2.0 liter, but certainly more low end torque and potential than the 2.0. I'm very excited to hear more about this car!!
96Lconversion is offline
Old 01-06-2003, 10:32 PM   #2
baggedrexondubs
Member#: 31515
Would like to hear more about the suspension points, too..
baggedrexondubs is offline
Old 01-06-2003, 10:44 PM   #3
tolnep
Member#: 18602
2005 Moller Skycar
glow in dark purple
Weight, compression ratio (how much more turbo can be modded in?) important points. I wonder when the physical details will come out...
tolnep is offline
Old 01-06-2003, 10:56 PM   #4
dmitrik4
Member#: 10607
'04 E46 waggin
the issue of CAR magazine w/ the UK spec STi test lists an 8000 rpm redline.
dmitrik4 is offline
Old 01-06-2003, 11:09 PM   #5
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
In the picture of the tach at http://impreza.subaru.com, it looks to me like the redline is at 8000 rpm. The 7000 rpm line is clearly white, and the 8000 rpm line is red. I guess it could be in between the two, but over 7000 rpm for sure.
I'm very curious about the weight, too. I hope it's not too porky, my totally uneducated guess is 3100-3200 lbs.
TheWRX is offline
Old 01-06-2003, 11:10 PM   #6
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Yes, but UK gets the 2.0, not the 2.5. The 2.5 will be exclusive to the US I believe. Even 7000 rpm is rather high for a 2.5 liter 4 cylinder, the Rs redlined at what, 6250?
Old 01-06-2003, 11:14 PM   #7
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
compression ratio
8.25:1 I would guess.
Redline: really, you'll be busy worrying about other things.
Weight: search for other thread on post I made speculating as to the weight.
ANZAC_1915 is offline
Old 01-06-2003, 11:18 PM   #8
tolnep
Member#: 18602
2005 Moller Skycar
glow in dark purple
How did you come up with this figure. Thats sort of a non-standard CR. Usually you see 8, 8.5 etc...
tolnep is offline
Old 01-06-2003, 11:24 PM   #9
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Yeah, I just made it up.
Old 01-06-2003, 11:54 PM   #10
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
Depends, if you plan to use the car for auto-x, it could be very important. With the 6-speed, 2nd gear should have a higher gear ratio than with the WRX 5-speed. Which is mostly a good thing, except that you'll have to shift to 3rd a lot if you can't hit 60+ mph in 2nd.
TheWRX is offline
Old 01-07-2003, 12:29 AM   #11
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
It depends on the final drive ratio too.
Old 01-07-2003, 12:37 AM   #12
WRXcellerate
Member#: 26654
2003 Impreza WRX
I think the weight will be down from the current WRX because even a radio isnt standard on the new STi for "weight savings" so im guessing between 2800-3000 lbs
WRXcellerate is offline
Old 01-07-2003, 12:42 AM   #13
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
No, DCCD and 6MT add weight.
I think I guessed 3260 elsewhere. I believe the truth is that the final weight is not known yet.
Old 01-07-2003, 12:48 AM   #14
XT6Wagon
Member#: 524
04 STi
The 6spd is approx 50lbs more than the 5spd according to what I've heard. Its 180lbs IIRC, and the 94 STi tranny I have was 136lbs w a little fluid in it.
The big thing is will we get the 03 Forester design front structure, as it has hydroformed rails and a few other detail changes which help the 03 forester be 100lbs lighter than the 02 w simmular stuff on board.
So if the Sti cuts 100lbs by switching to the new front end structure and misc stuff, then it should be about the same as the current WRX or 3050-3100. I'd take that figure as a MINIMUM though.
XT6Wagon is offline
Old 01-07-2003, 12:58 AM   #15
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
The GDA Impreza already has the hydroformed front subframe. The Forester picked it up afterwards.
Trust me, it will be heavier than the WRX (otherwise they would have left the radio, rear wiper, seat pass through etc in).
I don't have the specs in front of me, but the DCCD does add weight too. I believe the benefit of it outweighs (ha ha) the weight gain.
Glenn
Old 01-07-2003, 01:03 AM   #16
HOKWRX
Member#: 5469
2004 Impreza
yeah, i also think is going to be heavier then WRX, but prob not alot, because the STi has no stereo and lightweight rear window.
HOKWRX is offline
Old 01-07-2003, 01:17 AM   #17
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
Im guessing the 2.5 is slightly heavier than the 2.0 as well.
My guess is that it will weigh approximately what the JDM and Euro STi weighs.
Around 3150 IIRC? (too lazy to look up)
elgorey is offline
Old 01-07-2003, 01:25 AM   #18
ObsidianRS
Member#: 17042
2004 Impreza WRX STi
Blue/Gold
A review of the MY03 JDM STi (our MY04) they said Subaru lightened the car by 80kg when compared to the MY02. So roughly that's about 100lbs? Of course the STi has heavier componenets that our WRX so they should about even eachother out.
But weight savings was a part of Subaru's redesign of the Impreza body.
ObsidianRS is offline
Old 01-07-2003, 01:26 AM   #19
RA29
Member#: 30598
2000 Lancer Evo 6
Hot Pink
The JDM STi weighs quite a bit more than the JDM WRX.
WRX is 1360kg and STi (6 spd+DCCD) is 1440
So, i think the US STi would be at least 1460 kg (for the 2.5 engine and US bumper crap)
RA29 is offline
Old 01-07-2003, 01:30 AM   #20
zzyzx
Member#: 815
2013 Boss 302 White
2008 S2000 CR ABP
A 2.5 should weigh less than a 2.0. Pistons are much lighter than the block that incases them. We know that the exterior block dimensions are the same on 2.0 and 2.5, therefore we know that there is more material encasing the pistons in a 2.0.
That fact they tried to save weight may have little to do with the actual weight concerns, but rather emissions laws, as was stated by others.
I believe that previous STi models did in fact not weight more than the standard model, but rather less. This is particularly true with the limited models (S202, Type-C, etc)
There's no reason to believe this would change at this point in the game.
3260 is way off, IMO...
- Steve
zzyzx is offline
Old 01-07-2003, 01:31 AM   #21
craig__w
Member#: 5509
Where I come from 80kg is around 196lb. But that's on my planet, yours may be different...
craig__w is offline
Old 01-07-2003, 01:33 AM   #22
ObsidianRS
Member#: 17042
Blue/Gold
Heh. K, thanks! I don't do well on conversions... just know kg > lbs
Old 01-07-2003, 03:39 AM   #23
Andrew Bacon
Member#: 2267
00RS
rutherforddesign.com
Wow, good deduction! I NEVER would have thought of that, and the car's weight is the key unknown that I'm curious about.
Andrew Bacon is offline
Anywhere I can go to get a specific screw? shemoves Off-Topic 26 07-01-2009 03:08 AM
forged pistons = less weight = more response?? Suberman Built Motor Discussion 20 10-10-2006 08:24 PM
Rota Slipstream weight...more Pacobeagle Tire & Wheel 0 07-01-2005 08:20 AM
More Legacy specific forums aburgraff Legacy Forum 10 12-29-2004 06:22 PM
Subaru specific MOMO shift knob weight fourdegrees Interior & Exterior Modification 17 09-27-2004 10:10 AM
