Old 04-23-2001, 05:46 AM   #1
vinman
Member#: 1425
2000 2.5RS
Question O2 sensor recall and intake mods
I just a letter for the recall on O2 sensors and before I bring the car in to the dealer I would like to know if anyone with intake mods has had any problem with dealers for this recall.
vinman is offline   Reply With Quote
Old 04-23-2001, 07:20 AM   #2
Swivel1000
Member#: 1168
2004 Jeep Grand
Cherokee Limited 4x4
Post
It will totally vary on the dealer. Subaru service staff in Evansville at Romain Subaru are complete jerks. But the staff a Bob Rohrman's in Lafayette are VERY cool about it all.
-matt
Swivel1000 is offline   Reply With Quote
Old 04-23-2001, 08:58 AM   #3
M a t t 2
Member#: 5503
2000 Impreza 2.5 RS
BRP
Post
your better off just seeing what happens. If they don't like it, go somewhere else simple.
M a t t 2 is offline   Reply With Quote
Old 04-23-2001, 09:23 AM   #4
Derres Catalano
Member#: 3244
2000 2.5 RS
Silverthorn
Post
Matt2, very bad advice. If the dealership see's that you've made a modification that voids the warranty they can report you to Subaru of America and "blacklist" you. Worse, if you are leasing the car, they can take it away from you. And legally, an intake change could be considered a modification that voids the warranty. Others in the club can attest to their negative experience at certain dealers who won't touch a car that has any modifications.
Best thing to do is just take the intake off and put back on the stock one. That's what I did last week when I took mine in. Better safe than sorry, and it only takes like 5 minutes! Don't worry about an ECU reset until you put the aftermarket intake back on.Text
Derres Catalano is offline   Reply With Quote
Old 04-23-2001, 10:25 AM   #5
nick dickitt
Member#: 4532
Post
I agree with Derres Catalano. This mod only takes a couple of minutes to change around. This will save you a ton of stress from the dealer when they open the hood and see the intake. Change it back to stock, go get your new O2 sensor, get home and put your performance intake back on. Good luck..
nick dickitt is offline   Reply With Quote
Old 04-23-2001, 10:39 AM   #6
popnGEAR
Member#: 4616
1999 2.5RS
RBP
Post
does anyone know if there is a same recall for MY98 RS's? or any recall for it actually.
popnGEAR is offline   Reply With Quote
Old 04-23-2001, 04:38 PM   #7
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Post
popnGEAR, No recalls for the '98 that I know of.
TSB: Front cv shafts inner grease replacement on selected cars.
1.Few with hesitation problem.
2.Many with clutch shudder/chatter.
3.Few with blown head gaskets due to
overheating.
(I only had to deal with the TSB and the clutch problem)
Albert
Albert is offline   Reply With Quote
Old 04-23-2001, 04:48 PM   #8
nick dickitt
Member#: 4532
Post
The point is dealers have the option to refuse service on a warranty or recall item if the vehicle has been altered. Let us know how it goes.
What intake are you using?
Old 04-23-2001, 04:51 PM   #9
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
That's just not true. Unless the product you install (notice I said product, not general class of modification) is on the manufacturers list of excluded modifications, a manufacturer cannot void your warranty unless they can directly attribute the failure to your modification. To do otherwise is a violation of federal law.
As for the original question, Subaru has already accepted liablity for the O2 sensor repolacement. The recall is global and the dealer must replace it regardless of any modifications, even if that mod directly killed the sensor before it died on it's own.
gavin is offline   Reply With Quote
Old 04-23-2001, 05:43 PM   #10
flent
Member#: 4706
2001 2.5rs
silverthorn metalliac
Post
does that recall apply for the 2001 subaru impreza's??
flent is offline   Reply With Quote
Old 04-23-2001, 05:51 PM   #11
Gerry
Member#: 1829
Post
No flent..I was just at the dealer and he said there was no recall on the MY01 cars..Gerry
Gerry is offline   Reply With Quote
Old 04-24-2001, 12:24 AM   #12
vinman
Member#: 1425
2000 2.5RS
Post
Thanks guys, except putting back the stock air intake is not so quick for me. See, I modified the intake to use the stock air box and a cone filter. However to do this I needed to seal the air box, sooooo, being cheap I cut the gasket from the stock air filter. But, since I couldn't get it to stay in place when closing the air box I used some permatex. I could put the air silencer and the stock tubing back but then I would have to drive without and air filter and I don't want to do that. Oh well, guess I'll take my chances. I was just trying to get a heads-up on the situation. Besides, how can an intake mod affect the O2 sensor. Its on recall as is anyway. recalls don;t have anything to do with whether your car is in warranty or not, right?
Old 04-24-2001, 08:38 AM   #13
vinman
Member#: 1425
2000 2.5RS
Post
Nick,
I'm using a modified version of the ganzflow. Instead of running the 3" tube all the way into the fender I cut off the end and installed a K&N cone filter. Additionally I made a heat shield from aluminum, support for the shield and intake tube, and even put an air flow straightening vane in the intake tube just after the filter. I don;t know if the vane has much effect but it only took a little extra effort and I was a little bored that weekend.
Old 04-24-2001, 03:45 PM   #14
popnGEAR
Member#: 4616
1999 2.5RS
RBP
Post
I'm pretty sure i'm a victim of the nasty MY98 hesitation problem, it doens't happen that often but when it does it's really annoying. It happens when i shift to second gear, i might be wrong and it is possible i'm not revving high enough. If my local dealer confirms it tho are they supposed to fix it at no charge?
Old 04-24-2001, 06:08 PM   #15
Derres Catalano
Member#: 3244
2000 2.5 RS
Silverthorn
Post
Gavin, most manufacturers consider any change to the engine to be voiding the warranty. It is mostly subjective, meaning it is based on the opinion of the manufacturer. If they feel that it voids the warranty, then you have nothing to say about it. It is not "against federal law". Simple way to find out is call up a dealership and ask how much it will cost them to install an aftermarket intake. You will be surprised with what you here.
O2 sensor recall - anybody had that done? kgb Vancouver Impreza Club Forum -- VIC 10 05-18-2001 01:25 PM
('93-'01) O2 Sensor Recall subuguy Impreza Forum 25 04-25-2001 12:57 AM
o2 sensor recall- any hassle with Intakes? fuzzbox Normally Aspirated Powertrain 4 04-06-2001 11:00 AM
went in for the O2 sensor recall yesturday and.... joostin420 General Forum Archive 3 04-05-2001 12:19 AM
O2 sensor recall letter Saw Jai Bay Area Impreza Club Forum -- BAIC 105 02-28-2001 09:12 AM
