Old 04-23-2001, 06:35 AM   #1
RacerinLSL
Member#: 1174
2011 Subaru WRX
Post Hesitation:Think it's a valvecover gasket problem
After aquiring a pretty mighty hesitation from 2k up to a little over 4k, I decided to change the spark plugs. The plugs we pulled on the driver side both had oil on them. We changed all four plugs and, well, that made it better for one day. So after closer inspection, the driver side of the motor looks like it has been getting oil on it most likely from the spark plug wells. Has anyone else had a problem with their valve cover gasket? I've got 40,000 miles BTW. I'll be taking it into the dealer tomorrow, but wanted to see if anyone else had a similar problem.
Chad
RacerinLSL is offline   Reply With Quote
Old 04-23-2001, 07:36 AM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
I had some leaking from my valve cover gasket due to a missing washer and improper torque. Torque spec for the valve covers on a 99-01 2.5L SOHC is like 4lb-ft, super light. I didn't think the gasket was a consumable, but it is conceivable that yours needs to be replaced.
Once I replaced the washer and torqued the bolts correctly, my leaking went right away.
ColinL is offline   Reply With Quote
Old 04-23-2001, 07:55 AM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
I didn't notice any performance problems traceable to the valvecover issue, btw. Oil on the outside of the plug shouldn't influence it's performance at all. (Both my plugs on that side did have oil on the insulator above the threads.)
Old 04-23-2001, 08:11 AM   #4
RacerinLSL
Member#: 1174
2011 Subaru WRX
Post
Thanks Colin,
Now that you mention it, oil in the wells doesn't justify oil on the bottom of the plug, which is what I had! Maybe I've got a bigger problem!! Damn. I had a valve cover problem with my 96 GSX and once it was replaced the plugs stopped getting fouled up though.
This will be under warranty no matter what though. I've got a 80,000 mile contract, but hoefully it's nothing big.
Chad
Old 04-23-2001, 02:43 PM   #5
Zeta
Member#: 128
MY04 WRX STi
Black/Silver
Post
I had the valve cover gasket changed on my 98 before 36k. Just recently have been having more oil consumption also, so I will have to do another check.
Zeta is offline   Reply With Quote
Old 04-23-2001, 07:24 PM   #6
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Post
Chad,
I'm sure you have scaned the posts on MY99 hesitation, stemming from the knock sensor.......right.
That is were 99% of my hesitation problem comes from.
AaRoN
bad valvecover gasket moonzie Baja Forum 1 01-27-2010 11:51 AM
Ej207 valvecover gaskets??? wrxwhat Built Motor Discussion 11 10-07-2007 04:13 AM
painting the WRX's OEM side underspoiler - black gasket problem! 955WRX Interior & Exterior Modification 13 03-18-2003 09:37 PM
exhaust gasket problem nateconnella North West Impreza Club Forum -- NWIC 6 02-26-2003 01:50 PM
yep, I think it's a head gasket. ColinL Normally Aspirated Powertrain 16 03-19-2001 08:54 PM
