Notices
Old 04-11-2001, 01:00 PM   #1
RallyImprezive
Member#: 5476
2007 WRX UGM
2010 FXT
Post Pulley install question.
I have an auto-tranny, and I can't torque the pulley down because I can't find a way to keep the crank from turning. How do you hold it in place on an auto?
-Andy
RallyImprezive is offline   Reply With Quote
Old 04-11-2001, 01:11 PM   #2
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
put it in drive, and have someone hold the brakes
[This message has been edited by JGard18 (edited April 11, 2001).]
JGard is offline   Reply With Quote
Old 04-11-2001, 01:26 PM   #3
25psi
Member#: 3086
2001 2.5 RS
Cool
I give you that pulley is off.
Put belts on, tightn them up. Jam Power Stearing pulley with something (Screwdriver, chunk of wood, etc). Tightn to your likeing.
Eugene
25psi is offline   Reply With Quote
Old 04-25-2001, 09:29 PM   #4
Mikey B
Member#: 5160
2002 Tahoe
1975 Grady White 20' Boat
Post
You are going to have to stop the pulley from moving from an outside force. Simply putting the car in D, or any other gear in an auto will make no difference cause you need to spin the torque converter up to hold the crank and you can't do that without starting the engine. Another thing other then what 25PSI added is to move the crank via starter, and have the wrench resting on the ground as to tighten the bolt using the starter...Be VERY careful as to not let the engine spin the wrench around and hurt your self/ others.
Good Luck
Mikey B
Mikey B is offline   Reply With Quote
Old 04-27-2001, 12:35 AM   #5
Scooby2
Member#: 2644
Post
Also Don't repeat Don't jam anything in the belts the torque required will snap the belt or at least sterech it out.
Scooby2 is offline   Reply With Quote
Crank Pulley Install question Got Pink? Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 12-26-2004 06:55 AM
Urgent UD pulley install question/help needed hamburger1971 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-18-2004 09:16 PM
pulley install question golfs2good Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-31-2003 04:46 PM
GFB pulley install question. please help! wrx2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-28-2002 03:59 PM
I'm back with more pulley installation questions AustinSTi Normally Aspirated Powertrain 3 02-02-2002 07:02 PM
