Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 01-07-2003, 04:20 PM   #1
Member#: 24773
2005 WRX STI
Default Intercooler water spray - when to spray?
I've never had a turbo car before. The Sti comes with manual water spray. How do you know when to spray? I believe the EVO comes with auto/manual water spray.
b0red@werk is offline
Old 01-07-2003, 04:25 PM   #2
ChuckG
Member#: 1774
2002 Black WRX Sedan
1993 MR2 T, 1988 MR2 SC
The STi sprayer should be manual/auto as well (auto most likely linked to an intake temperature switch)
The time to use it in manual, is just before you anticipate hard acceleration, the intercooler is just a heat sink, the cooler it is, the more efficient it will work
ChuckG is offline
Old 01-07-2003, 04:59 PM   #3
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Should be? Well, according the specs and press release it's not. It's manual only.
When to give it a spray? Stop lights/signs in the summer.
jblaine is offline
Old 01-07-2003, 05:13 PM   #4
scott_gunn
Member#: 4203
2009 WRX 5spd hatch
Platinum Silver Metallic
A good time would be right before your run at an autocross. Damn heat soak!
scott_gunn is offline
Old 01-07-2003, 05:23 PM   #5
briank
Member#: 3568
2002 WRX EcuTek
Does anyone know how long you can leave the spray on continously until a full tank of water will run out? I think I had heard 15 minutes, but that may have been for the APS water sprayer.
And another question: Do you have to be careful about using hard water in your sprayer? Will it leave deposits on the intercooler?
-BrianK
briank is offline
Old 01-07-2003, 05:24 PM   #6
WRX 2002
Member#: 11211
2004 STi
Rally Blue
Save me using a spray bottle between heats.
I wonder what class it will be in AuotX, if it was a 2 litre theoretically should be in STX but with a 2.5 litre I'm not sure where it would fit in.
Nigel.
WRX 2002 is offline
Old 01-07-2003, 06:27 PM   #7
johnfelstead
Member#: 856
2005 JDM STi
you cant leave it on.
The manual switch is just a push/instant release button. It gives a 5 second burst of water.
I dont understand why they dont fit the auto option, its only a switch and relay. Ah well, you cant have everything.
The manual is designed to allow you to give the car an extra 10 squirts once the auto level sensor has switched off its suppy. I leave mine in auto mode when driving hard and only use manual to give me those last few quirts.
You use it whenever you are loading up the engine on boost to cool the intercooler down. Or when you have been sat stationary at lights and the intercooler is getting heat soak.
johnfelstead is offline
Old 01-07-2003, 07:56 PM   #8
GaryS
Member#: 3541
John, did your car come with auto mode, or did you install it as a mod. How difficult would it be to swap, assuming you could secure the necessary parts?
GaryS is offline
Old 01-07-2003, 08:03 PM   #9
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
take a look at his car. My money says it came that way.
monovich is offline
Old 01-07-2003, 08:30 PM   #10
johnfelstead
Member#: 856
2005 JDM STi
yep, fitted as standard. I would think its gonna be a simple retro fit though. It didnt work at all when i bought the car, the idiot who owned it before me had the plugs in the wrong switches, manual was in auto and vice versa.
alternative to intercooler water spray? YVR Vancouver Impreza Club Forum -- VIC 20 09-05-2011 03:52 AM
Water Injection only.... thoughts on when to spray... AaronWRX UTEC 27 07-21-2006 03:56 PM
me=noob: when to use intercooler spray? Picard Water/Methanol Injection, Nitrous & Intercooler Cooling 9 07-06-2006 10:13 PM
Intercooler water spray - when do you use it? fastwrx STi Forum Archive 7 02-19-2003 07:35 PM
DIY "Intelligent" intercooler water spray rB5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-07-2001 01:06 AM
