#1 |
Member#: 21847
Vehicle:2002 WRX Sedan World Rally Blue STX#555 |
Stainless Steel - Grade 321:
http://www.azom.com/Details.asp?ArticleID=967 Stainless Steel - Grade 304: http://www.azom.com/details.asp?Arti...Grade%2B304%2B Good read and something to think about with the advent of all these 321 stainless steel exhaust components entering the market. Enjoy. chris
#2 |
Member#: 11962
Vehicle:2002 WRX SILVER |
so basically 321 is the better choice for the uppipe and the 304 should be okay for the turboback.
I believe Shiv was the first to use 321 in the uppipe - way to go Shiv. |
#3 |
Member#: 24303
Vehicle:2002 Impreza WRX Black |
What is the temperature inside a WRX uppipe?
Thanks Tuca |
#4 |
Member#: 21713
Vehicle:2002 wrx sedan black |
I think =< 1600F so which is ~850C I think.. so, yeah, its within the specs for 321..
oh yeah.. i think I heard that exhaust temps are ~800F which is ~450C which is also below the 500C limit for 304.. good post fengshui-fu ![]() |
#5 |
Member#: 10821
NESIC
Vehicle:2008 WRB STi |
so what's the metal in the stock uppipe?
#6 |
Member#: 24303
Cast Iron,,But is much Heavier..
Tuca |
#7 |
Member#: 21847
My pleasure. Im considering either the perrin UP or the APS ones, both 321 SS. And even though it is overkill, ill probably get the perrin DP to compliment my UP and crnak pulley and IC hoses. ALL PERRIN!!
chris |
#8 |
Member#: 10821
NESIC
so cast iron is as resistant to really high operating temperatures? anyone know how high?
I just want a baseline to compare the 321 and 304 metals. thanks. |
#9 |
Member#: 24303
Hey,,i Have a scooby sport 304..
is that really bad???I am nervous.. Will it be much much better to jet coat it?? Do you think the 304 is enough? Tuca |
#10 |
Member#: 21847
I wouldnt worry unless you are going for mad power and actually change out your headers. If you do a header swap, then you might want to consider the 321 SS.
chris |
#11 |
Member#: 13831
it doesnt hurt that the perrin up/down pipes look nice either
#12 | |
John Wayne Toilet Paper
Moderator Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
#13 |
Member#: 14043
Vehicle:2002 WRX, ForesterXT support urlocal racerGrL! |
304 is fine for either uppipes or downpipes. Although the gasses reach 1550 degrees the pipe never actually gets that hot.
#14 |
Member#: 11962
The issue is with the number of heating cycles and maintained corrosion resistance and resistance to mechanical fatigue.
#15 |
Member#: 21713
tuca33: jet coating inside and out will be an improvement. I am planning on doing just that even though i will have a 321 steel up-pipe.
| Thread Tools | |
| Display Modes | |
| WTT Stainless Steel 3 Inch Catback For OEM Exhaust | FriedIceCream | TXIC Private Classifieds | 2 | 04-12-2008 06:00 PM |
| Stainless steel vs. aluminum piping | Santa STi | Newbies & FAQs | 5 | 11-03-2006 01:15 AM |
| as seen in wired: Banksy the "Art Terrorist" | Handsdown | Off-Topic | 11 | 07-29-2005 07:30 PM |
| Is the HKS downpipe really stainless steel? | BooStedScooby | Factory 2.0L Turbo Powertrain | 19 | 08-22-2002 01:36 PM |
