Old 04-23-2001, 06:00 PM   #1
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
Check your exhaust. Esp, the area next to your rear diff. Check the play of the muffler, swing it side to side.
Revision is offline   Reply With Quote
Old 04-23-2001, 06:10 PM   #2
IowaRS
Member#: 5385
2012 WRX Base
Ice Silver
Post
Please describe the clutch "clunking" when does it happen?
Why not get under there and wiggle everything around and see if any of the mounts are way loose?
Beyond that I have found the source of some wierd sounds by having someone get in the car and simulate the conditions that I was hearing the sound. Letting the clutch out quickly and the like. Be VERY, VERY careful when doing this. Don't put yourself in a position that you could be run over, put the ebrake on hard, and have them press very firmly on the brake when letting the clutch out.
In particular I discovered that by jacking the car up on the side rear diff mounts I ended up bending the plate a little. When the clutch was let out quickly in reverse the cross-bar attached to the diff ended up hitting this mounting plate making a metal on metal noise that was pretty loud.
IowaRS is offline   Reply With Quote
Old 04-24-2001, 12:33 AM   #3
SUBYRS710
Member#: 5186
2000 2.5 RS Coupe
Silverthorn
Post Broken tranny mount?
could anybody tell me the symptoms of a broken tranny mount? i'm hearing a clunking sound when i get on the gas. The clutch pedal is making like a "clunking sound" and it also does it when i go over bumps, even when i'm not in a gear. Anybody have any clues??
SUBYRS710 is offline   Reply With Quote
broken downpipe tab tranny mount antiks Texas Impreza Club Forum -- TXIC 26 03-13-2007 01:10 PM
Characteristics of a broken (or damaged) tranny mount BLACK05WRX Transmission (AT/MT) & Driveline 1 06-12-2005 07:38 AM
I think my tranny mount is broken SoLiDbReAkZ Transmission (AT/MT) & Driveline 2 10-08-2002 04:51 PM
Tranny Mount Broken? jdsimpreza Transmission (AT/MT) & Driveline 4 05-24-2002 10:18 AM
Difference between STI tranny mount and STI WRX RA tranny mount... can any1 explain? MrP0nch0 Brakes, Steering & Suspension 4 11-07-2000 07:19 PM
