Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 01-07-2003, 08:38 PM   #1
Corn-Picker
Member#: 8679
2010 The most hated
vehicle on the internets
Question Different types of differentials
I noticed that the STi is advertised as having a "mechanical rear limited slip differential" and the normal WRX has a "viscous rear limited slip differential." What's the difference? I'm guessing the mecanichal one is better and transfers power more quickly when a wheel slip occurs
Corn-Picker is offline
Old 01-07-2003, 08:40 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
http://forums.nasioc.com/forums/show...hreadid=297873
similar question
Im guessing the rear in the STI is the same we seen in the current WRX while the front is some type of torsen.
ciper is offline
Old 01-07-2003, 08:52 PM   #3
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
From what I read, the front one does not use gears and is electronically controlled. So it can't be torsen. The rear one might be torsen like because Torsen is pure mechanical.
Foxbat is offline
Old 01-07-2003, 09:20 PM   #4
johnfelstead
Member#: 856
2005 JDM STi
Exclamation
front diff is a suretrack diff, made by AP racing. Check AP racings website. Rear diff is mechanical rather than viscous, basically in non techy speak its a more violent lockup but gives more traction (still looking for a body shop to invest in ) The centre diff is an electromagnetically controlled mechanical diff giving anything from 65/35 R/F torque split upto 50/50 fully locked.
johnfelstead is offline
Old 01-07-2003, 09:55 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
I always beleived that mechanical meant in contrast to electronic, so in this sense a viscous unit would be mechanical right?
I went to AP Racings site and found no info of the lsd, only brakes and such. I searched the web and found gearboxes with this LSD installed but no information on its function.
Can you help me to find the information?
ciper is offline
Old 01-07-2003, 10:16 PM   #6
XT6Wagon
Member#: 524
04 STi
My guess is that it will have a clutch type rear diff
XT6Wagon is offline
Old 01-07-2003, 11:36 PM   #7
ldivinag
Member#: 13533
04 sti
black???
coming from a 4wd background, a viscous LSD means that there's a fluid inside the diff, what when slippage occurs, the fluid heats up and become more solid so the gears inside will act like a closed diff. not 100% lockup like a spool or my ARB air locker.
on my truck, i have a detroit true-trac LSD (front axle has the TT while the rear has ARB) that uses helical gears to get the 2 sides to work as one.
check out tractech's pdf about the tru-trac. they also list a sure-trac diff too.
http://tractech.com/Products.htm
ldivinag is offline
Old 01-08-2003, 01:15 AM   #8
aspera
Member#: 7879
Are any of you guys finally jealous of us?
Seriously, while your educating us on drivetrain stuff, would a 2.5 litre engine be likely to use different gear ratios in the transmission? also for the differentials?
aspera is offline
Is it true that different types of alchohol make you act different? saltYmirv Off-Topic 60 05-05-2010 06:07 PM
different types of headers = different powerbands... bagwell_five Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 12-06-2005 11:18 PM
Does different types of exhaust steel produce different sounds? Big Turkey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-28-2003 05:48 PM
What type of differentials does the WRC impreza use? Gambit Motorsports 2 03-19-2001 06:40 PM
What type of differential oil should I use WRXwannbe Technical Forum Archive 2 07-26-2000 07:07 AM
