Old 04-23-2001, 05:14 PM   #1
tmr
Member#: 1744
'11 STi
Fuscia
Question Wrapping exhaust?
Anyhow, a pretty stupid question.... I've seen a lot of people wrap their headers w/fibreglass - i'm thinking that this is to keep exhaust gasses up, hence speeding up their flow backwards. Therfore, i'm thinking of maybe wrapping my exhaust to see if there is a diff. I'm currently running a 2.5" catback on an na engine - would wrapping the exhaust alleviate "some" of the backpressure problems due to the large diam. of the exhaust piping? Just a thought, please don't flame me. Also, if i did decide to wrap the exhaust, would there be problems w/ rust due to moisture and debris sandwiched up between the fibre and exhaust? Thanks.
TMR
tmr is offline   Reply With Quote
Old 04-23-2001, 05:59 PM   #2
IowaRS
Member#: 5385
2012 WRX Base
Ice Silver
Post
I don't know about the WRX, but the 2.5RS is pretty much wrapped already down to the cats.
The metal "housing" around the exhaust appears to have insulation inside it between it and the exhaust pipe.
As far as whether or not wrapping the exhaust is helpful, I would say yes. Keeping the gasses at a higher temperature will keep velocity up. How much it helps is a question that only a dyno would answer. Nothing compares to real world testing.
IowaRS is offline   Reply With Quote
Old 04-23-2001, 07:24 PM   #3
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
Wrapping will rot your exhaust. If you're really going to do it, spring for ceramic coating, it's cheaper than a new exhaust.
gavin is offline   Reply With Quote
Old 04-23-2001, 07:36 PM   #4
IowaRS
Member#: 5385
2012 WRX Base
Ice Silver
Post
The only reason the pipe would "rot" would be rusting through. That usually requires moisture. Exhaust tends to get kind of warm and generally evaporates most of the moisture on it. True the wrap will tend to hold the moisture more than without the wrap, but I have wrapped exhaust in the past without any excessive rust problems.
Old 04-23-2001, 08:14 PM   #5
MrHorspwer
Member#: 4063
Post
I have seen regular mild-steel headers rust through over the period of 6 month. These were mild steel and were brand new... not the stainless alloy a new car exhaust is made of. I don't know what it would do to any other material. Personally, I wouldn't go near the stuff based on experience. The benifits don't outweigh the potentional losses.
MrHorspwer is offline   Reply With Quote
Old 04-26-2001, 04:58 PM   #6
pottsie350
Member#: 6110
98 Impreza L
Red
I have GSXR that had wrapped headers on it, they rusted like crazy. I could tell no discernable difference in the power output. I know I'm comparing apples to oranges, but to me it seems the hassle of wrapping them doesn't make up for the slight advantage that would be gained. Just my humble opinion
pottsie350 is offline   Reply With Quote
NJ: Wrapped Exhaust Manifold underpowerd Engine/Power/Exhaust 12 03-15-2008 09:29 PM
Help wrapping exhaust Lexington Mid West Subaru Owners Club Forum -- MWSOC 32 01-29-2007 09:33 PM
Heat wrapping exhaust... txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-28-2005 11:47 AM
What to wrap exhaust with(temporary fix)? joubtt Southern California Impreza Club Forum -- SCIC 2 12-24-2003 05:00 PM
thermo-wrap exhaust manifold or no? ride5000 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-09-2003 11:05 AM
