Old 01-07-2003, 10:08 PM   #1
Sharky NRK
Member#: 29549
2003 WRX
Default Just checking the numbers
I got the blitz tt w/ boost guage and was trying to check the numbers I am seeing. At idle I am getting about -.6 kPa and in first at WOT I am seeing around .65 kPa or so and in second through fifth I see high .90 kPas. Does this sound about right. I thought I heard somewhere that full boost can only be achieved in third through fifth and it was limited in first and second. thanks in advance.
Sharky NRK is offline   Reply With Quote
Old 01-08-2003, 01:34 PM   #2
Sharky NRK
Member#: 29549
2003 WRX
Nobody can verify these.
Old 01-08-2003, 01:44 PM   #3
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I dunno kPa, but you can convert
Max 100% stock boost in 3rd, 4th, 5th is around 13.5PSI
Yes, boost is limited in 1st and 2nd. It's somewhere around 6-7PSI, but I forget the exact number.
At idle, you should be at around -15PSI.
jblaine is offline   Reply With Quote
Old 01-11-2003, 04:49 AM   #4
Sharky NRK
Member#: 29549
2003 WRX
I hit around 13.5 psi with one spikes occasionally hitting 14 psi or so in 3rd-5th but it doesn't seem to be limited as much in 2nd, I can hit around 10 psi or so in 2nd as compared to around 8 psi in 1st. This is on a bone stock wrx as well.
About to pull the trigger on custom wisecos - check my numbers SomeoneWhoIsntMe Built Motor Discussion 7 02-10-2010 06:07 PM
I just got a number from a girl checking out the WRX. TheKryptKeeper Off-Topic 35 07-14-2006 03:51 PM
Bought a used 02 3 months ago and just checked over the inspection report. zuczek Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-16-2004 11:41 AM
Is there a way to check the number of posts one has posted? volkl23 Newbies & FAQs 10 08-02-2004 04:23 PM
I just checked the trade in value of my car. david2z4 North West Impreza Club Forum -- NWIC 3 08-04-2002 01:15 PM
