Old 01-07-2003, 10:37 PM   #1
jsmithjr732
Member#: 20272
2007 SWP STI
Default Hard time shifting into 4th and 5th
I just got my car back from Irvine Subaru where I had the 5th gear synchro replaced (grinding). Now, it's difficult to shift into 4th and 5th gear. I'm not getting any grinding sounds, however, I have to put significantly more force to get it into 4th or 5th.
Has anyone had this problem before? Or perhaps know what this is?
jsmithjr732 is offline   Reply With Quote
Old 01-07-2003, 11:09 PM   #2
jsmithjr732
Member#: 20272
2007 SWP STI
Default Anyone?
I just got in my car and started shifting--with the car on and off. Now I can hear a slight metallic sound when the clutch is out. When I shut the car off, I can hear it for a 1/2 second or so. I checked the tranny fluid level--kind of hard to see it, but it looks to be low, almost dry!
I'm shaking a little bit since I drove nearly 100 miles already. Since it's dark, I'm going to check again with some new batteries in the flashlight.
Anyone experience this before???
Old 01-07-2003, 11:19 PM   #3
jsmithjr732
Member#: 20272
2007 SWP STI
Bizarre, I've checked my tranny fluid before and it had a color to it. There appears to be fluid, but I can't be certain. I'm not sure if it's just residue from hitting the sides while sticking it back in the container tube.
Isn't tranny fluid supposed to have a color to it?
Edit: One other thing: when I pulled out the dipstick and put it up to my nose, it smelled like something was burnt.
Old 01-07-2003, 11:34 PM   #4
jsmithjr732
Member#: 20272
2007 SWP STI
Looks to be fluid in there now, but it appears to be overfilled. And I'm still getting the rickety-rackety sound when the clutch is not pressed. I'm searching for answers as we speak.
Anyone have an idea of what's going on?
Old 01-08-2003, 05:05 PM   #5
jsmithjr732
Member#: 20272
2007 SWP STI
Took the car up to Irvine Subaru this morning. Had Chris (technician) ride along. He said the following:
1. Shift problems while stopped--you're going to have problems with this as the synchros won't be lined up when the car isn't moving. Seems odd as the showroom car didn't have this issue. The fact that I have a Karboy shifter makes it worse. He mentioned that the geometry of the Kartboy isn't exactly matched to the stock shift linkage.
2. Exhaust-sounding leak--thought I heard something from under the shifter. He said that it's the sound of the transmission. I'm wondering if having spacer washers between the rubber insolator and the metal shift ring may have opened a small gap for sound to come in?
3. Rickety-rackety sound from tranny--it's normal (don't remember the exact words he used to describe what it was).
I'm a little concerned because this problem happened immediately after having service done. Chris mentioned that the bolts are all torqued to specs and that I pretty much have a new transmission (in theory, since it was examined and has new fluid in it). He said to give a little time.
I may change out the Kartboy shifter this weekend if I keep having this problem. Weird, while driving with Chris in the car, the shifting problem didn't happen.
Grinding into 4th and 5th, syncos or gear oil? moss Transmission (AT/MT) & Driveline 16 09-20-2007 12:34 PM
Can't get into 4th, and 5th feels funny. st1llet0 Transmission (AT/MT) & Driveline 5 09-06-2007 01:51 AM
hard to shift into 1st and 2nd when cold orionh2215 Transmission (AT/MT) & Driveline 2 11-12-2006 09:05 PM
Hard time shifting into 1st at stop Lever2ooo Transmission (AT/MT) & Driveline 25 08-03-2004 08:15 AM
grinding going into 4th and 5th vile Transmission (AT/MT) & Driveline 11 05-09-2004 04:39 PM
