Old 04-23-2001, 07:29 PM   #1
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Post Questions on the nasty EGG smell
Hello,
I have a question reguarding the nasty egg smell comming from my car al the time.
1st....I increased the size of my exhaust pipe to 2.25"(cat-back).....and added a high flow muff.
Could the decrease in backpressure cause the cat to NOT be working properly giving me the egg smell....???
I have to do something about the smell.
Thanks,
AaRoN
Old 04-23-2001, 07:32 PM   #2
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
Post
The rotten egg smell is caused by the "Sulphur" in the fuel, try another brand of fuel and see what happens after a couple of tanks.
Hope this helps.
JoeT is offline   Reply With Quote
Old 04-23-2001, 07:36 PM   #3
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Post
Also, your car is likely to be running lean unless you added a fuel computer to compensate.
bsquare is offline   Reply With Quote
Old 04-23-2001, 07:51 PM   #4
steppin16
Member#: 6010
Post
i had that problem but i was running rich and it had to do with my intake
steppin16 is offline   Reply With Quote
Old 04-23-2001, 07:57 PM   #5
Blindeye_03
Member#: 4418
2016 Focus ST
Post
i usually smell that cuz of the clutch burning ..which isnt good
Blindeye_03 is offline   Reply With Quote
Old 04-24-2001, 06:59 AM   #6
25psi
Member#: 3086
2001 2.5 RS
Post
Rotten Egg smell is very often indication of catalitic converter going bad.
Eugene
25psi is offline   Reply With Quote
Old 04-24-2001, 01:36 PM   #7
tonytiger
Member#: 3844
1993 Legacy 1.8
Post
I think the cat isn't working as it should. Here where I live it's usual to have that smell when starting at winter time (even -20 celsius). When the cat is cold it doesn't work properly and that makes the sulphur with the its lovely smell come through the pipe. I had the problem couple of months ago, but it vanished. I'd (very unprofessionally) would say there is something wrong with the new setup. In cold air the pressure is smaller than in warm and it might be compared with the decreased backpressure. Don't know but could reseting ECU help. Really just a gues My oppinion...
tonytiger is offline   Reply With Quote
Old 04-24-2001, 01:40 PM   #8
bratmantlz
Member#: 3231
88 626 Turbo
white
Post
so what would be the fix for this smell prob? what are some signs besides the smell?
Brian
bratmantlz is offline   Reply With Quote
Old 04-24-2001, 03:55 PM   #9
sck
Member#: 6064
Post
Hello,
I've been lurking around this forum for a while and never posted. But today I found out something very interesting that I had to share...
I have had the rotten egg smell since I bought my car last June and the dealer has never been able to find a problem. Just recently my CEL came on and turns out have a bad front O2 sensor(being replaced tomorrow). Today, I had the opportunity to talk to 3 independent mechanics at my friend's garage and I asked them what could cause a rotten egg smell. They all said, almost simultaneously, "The battery's over-charging" What?! They said most often that is the problem...the voltage regulator doesn't kick in. Check that, or the alternator. Not a bad O2 sensor, catalytic converter going, bad gas? They said not usually.
I'm not saying that is the definitive answer, but does it not sound plausible that the sulphuric acid in the battery could break down into sulpher dioxide under a heavy electrical current? Maybe I'll crack open some old textbooks and take a look.
This might be something to look into.
sck is offline   Reply With Quote
Old 04-24-2001, 06:31 PM   #10
Bonzo
Member#: 2307
2009 530EXCRF1000D
Orange
Post
here's my .02 worth. I don't believe it's the batteries over charging. Drive an electrical fork lift truck and you will smell batteries.
I beleive the rotten egg smell which I have also on my 2001 is from an overly rich fuel mixture. When I drive the car slow as in he city w/o much throttle the smell is non-existent. When I get into it hard with some full throtle use I can even smell it coming in through the sun roof. At wot the injection system is running rich, and the smell is the catlysts working but not quite up to optimal temps. A rich fuel mixture will produce lower egt's (exhaust gas temps) and thus lower catylist temps. Catylists need heat, the more the beter to burn off the bad stuff.
Bonzo is offline   Reply With Quote
Old 04-24-2001, 06:39 PM   #11
Xio
Member#: 3805
2011 STi Sedan SWP
2011 Outback ABP
Post
Bonzo-- I am experiencing the exact same problem. What can be done about it?
Xio is offline   Reply With Quote
Old 04-24-2001, 06:51 PM   #12
steppin16
Member#: 6010
Post
my car was running rich as stated above because of my aftermarket air filter... today i got it back from the shop and punched it with no smell at all... so i would suggest something to keep the fuel mixtures correct... i think a ecu would do it right?
Old 04-24-2001, 07:42 PM   #13
sck
Member#: 6064
Post
I only bring up the battery idea because I thought it was interesting and it was mechanics telling me this.
I don't seem to have a pattern to when my car smells and I don't drive hard at all because I've been getting what I believe to be horrible gas mileage(18 mpg, every tank counted, gas is 80 cents a litre here, ?/gallon). That is what my dad gets with his 214hp V6 1994 Eagle Vision TSI(this might get me in trouble, but I love that car)
Hopefully, my new O2 sensor should fix my problem. If it doesn't, I'm going to follow up on this battery idea, and any others.
The bottom line is we shouldn't have to put up with the smell. In 15 years of driving, I have smelled sulphur from a car I was driving maybe a half-dozen times - not several times a day like I do from my Impreza. No one I know with Legacys or Outbacks is having the kind of problem I am having.
I love my Impreza, just not the way it smells.
Stephen.
Old 04-24-2001, 08:53 PM   #14
Bonzo
Member#: 2307
2009 530EXCRF1000D
Orange
Post
It sounds like a fuel mixture problem. I am not a scooby specialist but from what i gather and ahve experienced the fi system in this car is not the most consistent compared to other cars I have owned and it is somewhat quirky. Maybe an ecu reset might help. I have zero mods, never did a reset and am getting 23 to 29mpg. I did read somewhere that after an ecu reset you get bad mileage until the puter re-adjusts. I will be installing my own cai in a week or so and will try to run w/o a reset and then try a reset and see what happens.
Good luck hope the 02 sensor helps. What year scooby? 00?
Old 04-24-2001, 10:49 PM   #15
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Post
Well people,
I'm not new to resetting my ECU, i've been doing resets now for a year (sometimes 3-4 times a month!!!)
But my set-up looks like this
MY99
K&N panel w/snorkus removed
2.25" pipe from the cat back with a Borla on the end, the muff has 2--3" tips
This is why i am conserned that the back-pressure may be low and keeping the cat to cool to work properly.
My train of thought is maybe if i were to replace my 2.25" pipe with a 2" pipe i might increase back-pressure just enough to fix the problem AND maybe get back a small amount of my low end power.
I know.....i know....it's a long shot....Opinions....
AaRoN
Old 04-25-2001, 12:36 AM   #16
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
Not necessarily going bad, but definitely not working as it should.
Do you have headers, too, or just a catback? Maintaining EGT is very important for a properly functioning cat. I suppose that just adding a larger cat back could be slowing the exhaust enough to cool it inappropriately, but I wouldn't think so. A quick test would be to temporarily wrap your exhaust and see if the problem goes away.
gavin is offline   Reply With Quote
Old 04-25-2001, 12:58 AM   #17
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
Question
Not to be on a completely different side here, but do you have the Subaru Air Filtration System under the dash?
I think my manual says something about a horrid smell when the filter needs to be replaced. It is supossed to be done every 12 months. I am working on month 23 of the original filter w/o a problem, but I have a new one ready to go.
Just another idea, I was not sure if your smell was inside or outside the car.
Paul G.
paultg is offline   Reply With Quote
Old 04-25-2001, 05:31 AM   #18
bratmantlz
Member#: 3231
88 626 Turbo
white
Post
so if its a bad cat or fuel shouldnt it smell all teh time.??
Brian
Old 04-25-2001, 09:13 AM   #19
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
Once again, wrap your exhaust, temporarily, which will keep your EGT high, and see if it goes away.
Quick question! On the b-connector what is the power pin? snowcrzy Electrical & Lighting 2 10-18-2006 07:04 AM
Question on the new WRX's turbo Gambit Normally Aspirated Powertrain 4 03-17-2001 12:02 AM
Cant get rid of the rotten egg smell Swivel1000 Normally Aspirated Powertrain 13 11-09-2000 12:58 AM
Questions on the KYB struts kappa652 Legacy Forum 8 11-01-2000 05:49 PM
More questions on the 2.5L engine kappa652 Legacy Forum 2 10-19-2000 07:51 AM
