Old 04-23-2001, 07:38 PM   #1
WR-REX
Member#: 5250
2007 Tundra RCSB 5.7
Question What does a Turbo Timer do?
Does a turbo timer tell you how long you have to wait to turn off your car? Or what? Also you are saying that if i get an Impreza WRX then I can't just go and park and turn my car off immediately? I have never had a turbo so i am interested how people wait so long while letting their car cool down.
WR-REX is offline   Reply With Quote
Old 04-23-2001, 07:41 PM   #2
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Post
You posted this in the wrong forum (NA instead of Turbo), but...
A turbo timer keeps your car running for whatever amount of time you tell it (usually not more than 5 minutes) after you turn off the ignition and remove the key. This allows oil to circulate through the turbo which gets extremely hot. If the oil did not circulate, it would be incinerated by the heat, leading to premature failure.
bsquare is offline   Reply With Quote
Old 04-23-2001, 08:01 PM   #3
2yLiTe
Member#: 660
Post
leading to what is referred to as "Coking"
And this is BAD!
Why is it BAD? uh....anyone?
2yLiTe is offline   Reply With Quote
Old 04-24-2001, 05:18 AM   #4
makua11b
Member#: 5931
02 WRX Sdn
Post
My HKS Type 0 Turbo Timer has a few different modes of operation. The one I will use most of the time monitors the engine speed and will automatically adjust it self. The harder the car was driven just prior to shut off the longer the TT allows the engine to run. HKS has not yet produced the WRX specific wiring harness, it should be available in the next few weeks. In the meantime I'am just letting my car run for a bit when I can.
Here's some interesting numbers. At idel (sp) the turbo is spinning at 20,000 rpms. At full boost it's spinning at about 250,000 rpms. Amazing but true.
makua11b is offline   Reply With Quote
i just ordered greddy turbo timer, do i need a wrx harness? GregBolby Normally Aspirated with bolt-on Forced Induction Powertrain 3 02-24-2004 04:09 PM
What does a boost timer do? Drivinwest Factory 2.0L Turbo Powertrain 6 07-20-2003 06:02 PM
How does a turbo timer work electronically? ScreaminFast Electrical & Lighting 5 10-22-2002 09:12 AM
What kind of turbo timer do you have? REXej20 Normally Aspirated with bolt-on Forced Induction Powertrain 8 08-17-2001 01:40 AM
Message Board Statistics All times are GMT -4. The time now is 05:47 PM.
