Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 01-08-2003, 01:13 PM   #1
wrex03
Member#: 29963
04 sti
Default Engine questions for STI
Is the 2.5 liter boxer engine just an elarged 2.0 liter? Meaning all our goodies from the wrx will mate , or is it based upon the Rs engine And no goodie will transplant?
I'm sure this has been asked, but I didn't want to read through the couple hundred posts.
Thanks,
Dave
wrex03 is offline
Old 01-08-2003, 01:20 PM   #2
underground-mpyre
Member#: 30351
1999 GC8 STI V7 6spd
Silver Coupe
Yea I read that too. EJ25 motor has a buttload of torque. I hope that if you modify it any, that the six speed will hold up. Yea the 6-sp, is built to last, than the wrx tranny, but I wonder what the torque rating is till it breaks. They should've kept the ej20 on it,(yes I know it is blasphemy) but probabley wouldn't kill the tranny. Even the wrc rally cars use ej20. check it out
underground-mpyre is offline
Old 01-08-2003, 01:23 PM   #3
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
The answer is a definitive "We don't know"
But most likely things will transplant. The WRX and the RS aren't even mutually exclusive. Many things will go between. Some things that, in all probability won't fit are pistons and camshafts. One thing that won't be easy, but possibly doable is are the heads. In all likelihood they will bolt together, but the AVCS won't work w/o some extra hardward...
mrbell is offline
Old 01-08-2003, 07:03 PM   #4
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
The EJ22 and EJ25 have the same bore, I believe.
We are getting a block that (I presume) is a semi-closed deck version of it. (think 22B, although it was fully closed deck?)
The EJ20 and EJ22 have the same stroke, so we are getting the longer stroke EJ25 crank. Not sure if this is the new phase III motor or not. I would assume (hope) the crank is stronger than the current EJ253 crank.
The rods are probably specific to this motor too, as they've never combined the 2.5 crank in the higher spec engine.
I'm sure a bunch of people will decide that the engine needs a purple BOV, some kind of cold air intake kit to add what they think is 30 HP but in fact reduces the driveability.
Certainly more boost with appropriate fuel/air/timing changes will generate more smiles, but again I'd be surprised if this is possible (with absolute reliability) on even 94 AKI (without major changes like big FMIC etc).
Glenn
ANZAC_1915 is offline
Old 01-08-2003, 08:09 PM   #5
sperry
Member#: 8636
WRX, OBXT, NA Miata,
F250SD, no more SVX :(
Can someone elaborate on the differences between open, semi-closed, and closed decks? Or point me somewhere for the info?
--Scott
sperry is offline
Old 01-08-2003, 08:17 PM   #6
AKGC8
Member#: 1305
2000 Impreza
Open:
Semi-Closed:
Closed:
AKGC8 is offline
Old 01-09-2003, 12:28 PM   #7
sperry
Member#: 8636
I think I get it... more reinforcement for the cylinder walls right? I see how that makes it a butt-load stronger...
But how's the cooling work on the closed deck!? Perhaps I'm not up on my boxer motor innards, but doesn't the coolant flow thru the space inbetween the cylinder wall and the rest of the block? If so, where's it flowing in the closed deck?
--Scott
BTW: great pics!
sperry is offline
Old 01-09-2003, 01:43 PM   #8
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
it flows thru those little passages... a little restriction in coolant flow doesn't really hurt anything... now if it were blocked, that'd be a problem... but I thought the 2.2L turbo had 97mm bore and the 2.5 is 99mm?
mrbell is offline
Old 01-10-2003, 06:21 PM   #9
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
anyone?
mrbell is offline
Old 01-11-2003, 02:07 AM   #10
Jon [in CT]
Member#: 2992
02 WRX Sedan
I've seen the 2.2 engine quoted as having either a 96.9 or a 97 mm bore. Regardless, I agree with you that the EJ22 bore is not the same as the EJ25, with its 99 mm bore.
Jon [in CT] is offline
Engine question for newbie drunkenmonkey97 Newbies & FAQs 8 01-21-2007 01:49 PM
General Engine Question for the Experts. BlackoutWRX General Community 6 10-19-2006 09:16 PM
engine question for suby gurus 05blkwrx Built Motor Discussion 5 09-09-2006 09:03 PM
Engine question for a swap ttimpreza Subaru Conversions 4 03-22-2005 12:31 PM
New Engine Probs for STI? Procrastinazn Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 02-26-2004 01:11 PM
