Old 02-23-2001, 04:53 PM   #1
imprezive
Member#: 746
Question Correct me if I'm wrong (turbo)
YOu could do everything nessesary for a stage I turbo kit for a MY00 for about $2900 (not including instalation)
My reasoning: $2700 for kit from ASR
$??? for diode, I don't know much one costs,but it's not much
and like $200 to have a car shop put on an O2 sensor in front of the cat of the right voltage so that the S-afc will work right.
now it is your turn to correct me If I'm wrong.
PS> how much is ludespeed's kit
imprezive is offline   Reply With Quote
Old 02-23-2001, 06:00 PM   #2
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Post
+ exhaust ($400-700)
+ gauges ($150-300)
+ clutch ($280-400)
+ labor
Jon Bogert is offline   Reply With Quote
Old 02-24-2001, 10:19 AM   #3
imprezive
Member#: 746
Post
Yeah I wastn' including that stuff. But the gauges are they REALLY NESSESARY. Especially if you have the S-AFC working right. I mena what gauges do you need?? EGT is just to see if you are running lean Same thing as a S-AFC. BUT I do relize that you would need a FPR, So I guess I'm wrong, but I was close.
Old 02-24-2001, 10:22 AM   #4
SkToBe
Ghost Mod
Member#: 1278
2001 RS
Wink
Ok first you need a car to bolt it onto...
SkToBe is offline   Reply With Quote
Old 02-24-2001, 11:16 AM   #5
Aphex
Member#: 146
'16 WRX Limited
Post
last I knew the ludespeed stage 1 kit was slated to be at $2500. While the A/F meter is Ok for tuning the lean/rich condition, the EGT is much faster and more realtime, it reacts to your inputs immediately, while the O2 sensor is slower.
you'd also need a boost guage to make sure you aren't boost spiking or that you're even running at the boost you want to be.
Aphex is offline   Reply With Quote
Old 02-24-2001, 07:18 PM   #6
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Post
I would guess it would cost close to $4000 to do a good small turbo system.
That would inculde the turbo kit, RRFPR, gauges, clutch, exhaust, etc.
I would say the boost and Fuel Pressure gauges are required with the EGT a very good idea. You can use the stock clutch for a while (I am still running mine with 5psi). A free flowing exhaust is a good idea.
AaronB is offline   Reply With Quote
Old 02-24-2001, 09:45 PM   #7
HYDCSX400
Member#: 2183
87' Shelby CSX #400
Black/silver
Post
I can tell you from exp. boost is a combination of and infectious disease and a strong drug. VERY addictive. You start with a simple 5psi and you say thats plenty of power for you (I can quit any time...). And next thing you know your shopping for custom made dished forged pistons, ARP head studs, and a boost gage that goes up to 30PSI!!! (just to name a few of the many things that you will absolutely have to buy or your life WILL come to an end)
When in doubt, buy more than what you THINK you will need, trust me you'll use it sooner than you think.
HYDCSX400 is offline   Reply With Quote
R180: correct me if i'm wrong DN1911 Transmission (AT/MT) & Driveline 7 03-13-2009 06:48 PM
Correct me if i'm wrong please :) scooby_snacks_imprez Normally Aspirated Powertrain 16 01-09-2006 08:38 PM
correct me if I'm wrong dabigmooish Newbies & FAQs 20 11-16-2004 09:00 AM
Please correct me if I'm wrong XLR8 out the turn Brakes, Steering & Suspension 17 09-07-2004 01:02 AM
correct me if I'm wrong, BOV only VajraTLR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-20-2003 09:04 AM
