Old 01-08-2003, 03:57 PM   #1
Vostok 7
Member#: 30209
Do you need to
read this in Braille?
Default Best front and rear big brake kit...
What's everyones opinions on big brake kits?
I need something that's bigger/more powerful than stock but will fit 16s.
I've been looking at the new Wilwood kits. 6pot front and 4pot rear... but not sure if they'll fit the 16s.
What's everyone's suggestions?
Vostok 7
Vostok 7 is offline   Reply With Quote
Old 01-08-2003, 04:18 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Oh man...you need to use the SEARCH TOOL, but I'll help you out with the little that I know.
The Wilwood 6-Pot/4-Pot will not fit under the 16's. You'll need at least a 17" wheel. I think the only brake set-up that'll fit under the stock 16's is the Perrin kit, but I think they're others I can't remember.
Old 01-08-2003, 06:21 PM   #3
Boxologist
Member#: 21118
he ION Perfromance brake jobbies will fit under 16"s. Check the Group Buy forum for th Fronts. Rears are suspossedly expected in the spring.
Boxologist is online now   Reply With Quote
Old 01-08-2003, 07:19 PM   #4
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
Go to 17's. Then you can get a few different kits.
Wilwood and Rotora are the only companies I know of doing Front/Rear kits for 17" or larger wheels that involve larger rotors and better calipers. Rotora's rear kit isn't availiable yet, but I've got pics
Zahnster is offline   Reply With Quote
Old 01-08-2003, 08:25 PM   #5
Vostok 7
Member#: 30209
Do you need to
Yes, I would love to go 17s but I don't want to have to change my brake setup whenever I want to rally or use snow tires. There's no way I'm rallying on 17s.
So, my thought was to get the biggest rotors/calipers I can for 16" that way I can swap wheels without a problem.
Vostok 7
Old 01-08-2003, 10:12 PM   #6
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
Well, get the Brembo's from RallyPerformance (ScoobySport)
Old 01-08-2003, 11:13 PM   #7
M3sum
Member#: 18226
2001 M3
Laguna Seca Blue
Default Re: Best front and rear big brake kit...
What are you needing it for? Are you fading your brakes now? The stock brakes are pretty good unless you are doing repeated high speed brakes....
Vostok 7
M3sum is offline   Reply With Quote
Old 01-08-2003, 11:21 PM   #8
Vostok 7
Member#: 30209
Do you need to
Well, I dunno. I suppose I should get it out a bunch and see what it does. I want to get into autoxing and rallying and I figured upgraded brakes would be a good idea.
Vostok 7
Old 01-08-2003, 11:25 PM   #9
M3sum
Member#: 18226
2001 M3
Laguna Seca Blue
You don't need bigger brakes for autoX. autoX is such low speeds and its over usually in less than a minute.
Bigger brakes won't help you stop faster, it will just let you stop repeatedly at high speeds without fading. Tires will more likely help you stop faster.
Old 01-08-2003, 11:33 PM   #10
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
For what you're doing it sounds like upgraded pads, fluid, and stainless lines will probably be enough.
driggity is offline   Reply With Quote
Old 01-08-2003, 11:39 PM   #11
Vostok 7
Member#: 30209
Do you need to
What about upgraded front rotor?
and a bigger rear kit?
Vostok 7
Old 01-09-2003, 12:03 AM   #12
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
Probably overkill. You could get some better DBA rotors for up front and the legacy rear rotors (bigger than wrx) but I'd do the other stuff first. Just my opinion though. If you plan on doing lots of trackdays then a big brake kit would probably be worth it.
Old 01-09-2003, 12:31 AM   #13
STiTuner
Member#: 5778
09 135i
Jet Black
Perrin or 4 pot subaru fit the 99-01 RS rims.. check those out.
Brad
STiTuner is offline   Reply With Quote
Old 01-09-2003, 12:02 PM   #14
mav1c
Hoodbridge!
Member#: 560
Yeah, unless you're running track days, A big brake kit is probably overkill.
Rotora Front and Rear Big Brake Kit BBK mrtrex Private 'For Sale' Classifieds 8 01-28-2006 08:40 PM
New!! Rotora Front & Rear Big Brake Kit $1999 Shipped mrtrex Private 'For Sale' Classifieds 16 01-27-2006 04:18 PM
Rotora front and rear big brake kit red in color mrtrex Private 'For Sale' Classifieds 30 01-19-2006 08:06 PM
Rotora: Front and rear big brake kit in stock! autoarttech.com Vendor 'For Sale' Classifieds 37 10-17-2003 02:13 PM
