Old 02-23-2001, 11:35 PM   #1
V6
Member#: 2703
Y2K GC8
Silver forever
Post Is that normal for stock RS turn in corners in snow will fish tail?
Hi,
Today when I have a right turn about 40-50km/h and there are snow on the road and I feel the tail loose, is that normal?
V6 is offline   Reply With Quote
Old 02-23-2001, 11:36 PM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Post
Were you on the gas? Anything that sends power to the rear tires will bring the rear end around on you if you hit a corner hot, unless the fronts don't bite at all, then you'll just plow.
CosmoTheCat is offline   Reply With Quote
Old 02-23-2001, 11:48 PM   #3
V6
Member#: 2703
Y2K GC8
Silver forever
Post
I brake before I turn into the corner, then in the middle of the corner (or the apex), I gradually step on the gas to keep the speed constantly.
Is that wrong?
Old 02-23-2001, 11:56 PM   #4
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Post
Well, technically under ideal situations (i.e. dry road) you're doing things correctly.
What MY is your RS? If it's a MY2x, it'll have a limited slip differential in the rear. With the power being distributed to the rear tires (somewhat) evenly, it's easy to bring the rear end around in low-traction environments such as snow. Heck, the first time it snowed here in Vancouver I was pulling out of the parking lot at work. I gassed it a bit too much on the snow and did a 720 without even thinking! Good thing nobody was around. Anyhoo, just be careful out there in the snow. We may be able to "go" easier than anyone else, but when it comes to stopping, we're in the same boat as everyone else!
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 02-24-2001, 12:02 AM   #5
V6
Member#: 2703
Y2K GC8
Silver forever
Post
My car is MY00 AT.
Agree "We may be able to "go" easier than anyone else, but when it comes to stopping, we're in the same boat as everyone else!"
I even expreienced the ABS works so hard, I have to brake in less than a sec and I step on the brake and the ABS works out make the pedal so hard and the noise from the brake make me feel secure.
So what is the correct procedure for turning in the snow?
Thanks
Old 02-24-2001, 05:09 AM   #6
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Post
Slow down!
AWD is cool and everything, but it is not magic. The laws of physics still apply.
blaster88 is offline   Reply With Quote
Old 02-24-2001, 09:02 AM   #7
Jessie James
Member#: 2072
Post
Seems normal to me. That's what happened to me, too, and hence why I crashed.
Pics are on my web site:
<a href="http://www.rs25.com">http://www.rs25.com</a>
Wish I had known about it BEFOREhand!
Jessie James is offline   Reply With Quote
Old 02-24-2001, 09:19 AM   #8
goose
Member#: 3578
Post
Yes, it's normal. Don't drive so fast on snow. AWD is useless if ALL four wheels are slipping-
goose is offline   Reply With Quote
Old 02-24-2001, 04:50 PM   #9
BoZo
Member#: 4392
2002 wrx
sadona red
Have a Nice Day?
Ice is not your friend. I almost found out what an Xtera and an RS look like when joined at the passenger door. Glad ABS works.
BoZo is offline   Reply With Quote
Old 02-24-2001, 05:25 PM   #10
schlong8
Member#: 2104
MY00 2.5RS
Silverthorne
Post
V6,
yah....that's normal. Heh, my RS is stock suspension too except for the crappy winter slaloms i have on steelies.
If u give it some gas in the middle of the turn u'll feel like ur floating out of it, but if u give it a little too much u'll exit in a power slide. It's a very fine line. I brake before entering too cause no matter what, if u going to fast, ur going to understeer. When i think of it, i don't think my ABS actually every engages when i'm doing that. Slow in, fast out...that's the rule i use.
Laterz
Chris
schlong8 is offline   Reply With Quote
Old 02-25-2001, 01:00 PM   #11
rbehny
Member#: 1908
Post
did you ever think there might have been some black ice or just some loose slush that could have effected the car. There are tons of variables that are at play when you drive. Let alone try to get the best line out of a turn..
rbehny is offline   Reply With Quote
Old 02-25-2001, 03:31 PM   #12
98mpreziveRS
Member#: 972
Post
lol.. i miss the subie we had some REALLY nice icy/rain and well i woulda been using the drift style Fast in, gas it all the way, drift out...ease off the gas counter steer, lay back on the throttle. aghh..i really miss that car
and yes that is completely normal because you do have power going to the rear wheels and also becuase of the centre diff sending more power to the rear becuase your fronts were slipping (based on your descrription this is my guess) and thus caused to the rear tyres to get more power breaking free and thus causing you to "fish" tail if you will
98mpreziveRS is offline   Reply With Quote
is this normal for the normal headlight sequence for an 07 outback? jawwadh Electrical & Lighting 6 08-08-2008 11:34 PM
When someone sneezes, is it normal for that person to say 'Bless me'? herewegoagain Off-Topic 15 04-14-2006 11:01 AM
Is it normal for the revs to drop so quickly in neutral? Zoso Transmission (AT/MT) & Driveline 2 06-16-2003 06:41 PM
Constantly meowing cat - is that normal? Hazdaz Off-Topic 24 10-07-2002 01:36 PM
17 HG for vaccuum on boost gauge. Is that normal? BamBooI Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-09-2002 08:17 PM
