#1 |
Member#: 3231
RMIC
Vehicle:88 626 Turbo white |
on a 98RS? will it work i kinda want some temporary power and wouldnt mind some juice. what all would ential me getting my 98 RS juiced? if i just use it for a lil bit will it be bad for the car? i must get a lil more power. and cant afford boost yet
.........Brian
#2 |
Member#: 1174
Vehicle:2011 Subaru WRX Black |
Brian,
A mechanic I know is begging me to nitrous my car. He has done over 2 dozen various makes before, and said if done properly, the 2.5 will handle it well. I do believe him, as he nitrous'ed my friends 91 accord (pos) and he's got over 130,000miles now with nitrous since 85,000 and no problems. I know this is very general, but the physics of NO2 make sense if the car can handle the power. CHad |
#3 |
Member#: 3231
RMIC
cool let me know or post if you do juice your car.
and how you like it![]() Brian |
#4 |
Member#: 1174
Brian,
I might consider it if I were keeping it, but I'm not. Also, my big turnoff with nitrous is that I would ALWAYS want to be pushing that damn button. I'm a leadfoot and I don't think I could resist the temptation! Chad |
#5 |
Member#: 3231
RMIC
i understand man same here ocasionally, hell my son heres my engine and goes race?? i then have to stop and get off the gas. oh well thanks for the info eh..
Brian |
#6 |
Member#: 5767
It is impossible to have nitrous on a NA car. Then you have a Forced Induction car.
#7 |
Member#: 3231
RMIC
i was under the impression that forced induction was turbo or supercharging... i just want to add nitrous.. maybe. anyone
#8 |
Member#: 1174
Brian-this guy doesn't know what he's talking about. Ignore him. Nitrous in NO WAY forces air into the motor. I'm not gonna start explaining b/c he's just flapping his jaws, or fingers
![]() Chad |
#9 |
Member#: 5390
Vehicle:2007 Mazdaspeed3 GT Black Mica |
Nitrous does not equal forced induction. Nitrous simply carries more oxygen than normal "air", so you can add more fuel in with it and create more power.
Kind of the same idea as a turbo (more oxygen + more gas = more power), but there's nothing forced into your motor with nitrous. |
#10 |
Member#: 1871
Vehicle:2000 Impreza 2.5RS Blue Ridge Pearl |
Nothing forced? Is that why the bottle is pressurized?
Nitrous is a form of forced induction. It forcing more oxygen into the engine than it could draw in on it's own... Perhaps a better term would be super-naturally aspirated instead of forced induction. |
#11 |
Member#: 5390
The bottle is pressurized so you can fit more in there. If it weren't pressurized, you'd have about 2 seconds of nitrous per bottle....
It's not "forced", because you're not pushing the nitrous in there any more than the fuel injectors are pushing fuel in (yes, I know they spray it at a certain pressure, but they're not squishing it like a turbo would). The nitrous is sprayed into the intake (in various places depending on nitrous setup), and it flows along with the air/fuel mixture as the engine breathes it in. The extra oxygen is simply a byproduct of the nitrous, and isn't a result of pressurization. The nitrous takes the place of some of the normal air that would be in the cylinder and carries more oxygen than that air. Whew....I think that's readable.... |
#12 |
Member#: 2072
Nitrous ... forced induction - two totally seperate things. Here's how it really works for your car.
When you heat nitrous oxide to about 570 degrees F, it splits into oxygen and nitrogen. The injection of nitrous oxide into an engine therefore means that more oxygen is available during combustion. Because you have more oxygen you can also inject more fuel, and that means the same engine can produce more power. Nitrous oxide has another effect that improves performance even more. When it vaporizes, nitrous oxide provides a significant cooling effect on the intake air. When you reduce the intake air temperature you increase the air's density, and this provides even more oxygen inside the cylinder. The only problem with nitrous oxide is that it is fairly bulky and the engine needs a lot of it. Like any gas it takes up a fair amount of space even when compressed into a liquid. A 5-liter engine running at 4,000 RPM consumes about 10,000 liters of air every minute (compared to about 0.2 liters of gasoline), so it would take a tremendous amount of nitrous oxide to run a car continuously. Forced induction... please ![]() |
#13 |
Member#: 3231
RMIC
so who of has responded
uhh yeah.. who has nitrous in their car..? and what was entailed with putting it in. is it affordable? i want to use it for a while then sell it. plus i can get bottles recharged $35 around...Brian |
#14 |
Member#: 711
Vehicle:1993 Rx7 R1 Yellow |
I was in the same position your in now. I want a turbo but didnt have the money yet, so i bought a nitrous kit. Its proven that the internals of the 2.5 and the 2.2 can take a beating. The biggest shot i would run would be a 65 shot, I am running a 55 shot off the Zex kit. The only problem is hoping your clutch will slip before your tranny blows
#15 |
Member#: 3231
RMIC
nope x i have an auto
so when i boost i willl be good there too![]() Brian |
#16 |
Member#: 1174
Brian,
Check out Venoms web page. I think it's www.venom-performance.com. There's a graph of a nitrous'ed 2.5 somewhere there. Venom is the only kit my friend will use, for what it's worth. Chad |
#17 |
Member#: 1871
so... not to really start a fight here... I think we're arguing over semantics, but let's break down the term "forced induction". First lets clarify that "of oxygen" is assumed... I use this extension because if you refer to the fuel in this term, then any car that runs on fuel would be forced induction... or at least any car running rich...
Force(n.)-The capacity to do work or cause physical change. Induct(v.)-To recieve, as a member; To introduce into. A turbo/supercharger has the capacity to mechanically(read: physical) change the amount air(therfore oxygen) introduced into the cylinder that the piston could normally draw in. On the other hand, nitrous has the capacity to chemically(read: physical) change the amount of oxygen recieved in the cylinder. So from the basics, they would both be forced induction, just different methods. They work differently, and because of this, they have other benefits and problems of their own. |
#18 |
Member#: 5390
mrbell -- yes, if you put it that way, nitrous is a way of "forcing" more oxygen into the cylinders than would normally be there. It's just that forced induction is usually meant to describe a motor that has its intake air compressed by a turbo/supercharger.
I've never really heard the term applied to a nitrous (only) car, but if you define it that way, it works. |
#19 |
Member#: 2956
Vehicle:06 Sti-white Stg 2 98RS-rally blue |
go start another post about forced induction, why can;t anybody just answer the question, because I'm curios too, is it safe on a n/a 2.5 or not,?
#20 |
Member#: 5390
SuBart -- sorry about that.
I don't really see any reason why it would be a problem, as long as you get a good nitrous setup and the engine isn't starved for fuel or anything. I remember seeing an article on a bunch of guys from a car magazine that rented a Neon for a weekend, put on a nitrous system (a 150 shot, I believe?), played with it for the weekend, took off the nitrous and returned it with no problems. Now obviously, that's an extreme case, but you should be fine as long as you go about it correctly. [edit -- can't spell tonight!] [This message has been edited by BrandonC (edited April 25, 2001).] |
#21 |
Member#: 5767
Sorry for being a wise guy. Nitrous is Forced Induction. You are forcing more oxygen into the engine so you can get more fuel in. Why do you think you have to turn up the fuel pressure when you activate the nitrous? It is the same idea, just a different method. I have been on other forums that have argued this same point, and basicly it is pointless to argue about it. Really, who cares? Only us.
To answer you question, if it is good for an Acura or Honda it is good for a Subaru. Now based on how strong the internals are, you have to make sure you don't do to much. |
#22 |
Member#: 2956
thank you
#23 |
Member#: 3231
RMIC
so what are the power increases with this? i just want some quick power and when i am done i want to sell the kit.
Brian |
#24 |
Member#: 1174
Brian,
It all depends on how much NO2 you're injecting. Thats why kits come in "50 shot) or "75 shot" etc. I would assume going over 75, you would start running into drivetrain problems, considering with nitrous it is a sudden burst of power, things tend to break easier. Chad |
#25 |
Member#: 5767
They call them "55 hp shot". But a 55 shot does not add 55 hp. On a smaller engine, (read 4 cylinder) it makes less than that. I think a 50 shot will make about 35 to 40 hp. On a big V8, it will make more than that.
| Thread Tools | |
| Display Modes | |
| GM: Plug-in SUV coming in 2011, all-electric car may be in the works | AVANTI R5 | Non-Subaru News & Rumors | 0 | 07-07-2009 12:47 PM |
| Pastrana crashes in the Baja 1000. Car engulfed in flames in seconds. | Protege Menace | Off-Topic | 17 | 11-22-2006 09:47 AM |
| In light of recent car crime, JGard has developed an anti-theft device for his car. | SkirtBoy | Off-Topic | 31 | 07-25-2006 12:09 PM |
| Question on Trading in a car \ trading in a more xpensive car.... | ptsmalls | Tri-State Area Forum | 5 | 07-27-2004 11:10 PM |
