Old 03-02-2001, 03:11 PM   #1
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Thumbs down For those who wanted the 4.8v diodes :(
No Company anywhere makes a 4.8v diode, sorry. . 4.7 is as high as they go. I will question my mom about how involved it would be for her company to make them. Ill lets you all know.
Jay McDade
Auto Tech--Lincoln/Mercury/Jaguar
Old 03-02-2001, 03:31 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
It's been a long time since I studied electrical engineering stuff, so I could be wrong on this. I'm pretty sure, though, that if you can't find a 4.8V diode that you could just get a couple of 2.4V diodes in series. I'm almost positive I remember studying circuits that used zener diodes in series to give the desired voltage drop.
Pat Olsen
'97 Legacy 2.5GT sedan
Mechanical Engineer who had to take 2 full semesters of EE at the Naval Academy, and then forgot everything because all the Naval Nuclear Power information forced it out of my brain.
Old 03-02-2001, 03:38 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Post
i think that you are thinking resistors, not diodes
[This message has been edited by Jaxx (edited March 02, 2001).]
Old 03-02-2001, 03:54 PM   #4
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
Post
Diodes in series work just like you said... so throw two 2.4's in series is like having one 4.8.
Are you trying to make some sort of voltage clamp I take it?
iodine23 is offline   Reply With Quote
Old 03-02-2001, 04:13 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Post
yeah voltage clamp to stop the map/boost problem on 00-01 RS. Rallispec posted about, it they are using 4.7 volt diodes soddered directly into the ecu, on the map signal circuit, dont remeber the specifics, but they would have liked to use 4.8v diodes to gut more injector duty cycle, I dont know whey they dont use two 2.4, if they make them, maybe not enough room. Have to ask Rallispec about that. Since my mother workes at a large electronics company I thought maybe she could get them. Just trying to help out. But no dice.
Jay McDade
Auto Tech--Licnoln/Mercury/Jaguar
Old 03-02-2001, 04:59 PM   #6
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
Post
It may be more of a pain to put the two diodes in series, because now you have to solder one end of each diode to the ECU and the other ends of each diode to the other diode.
If you use one diode you just jumper a connection with the diode to clamp to the voltage.
Old 03-02-2001, 05:07 PM   #7
ludespeed
Vendor
Member#: 2734
Post
I thought that 'in series' meant one attached to the end of the other, like flashlight batteries and parallel would be both diodes next to each other with the 'like' ends connected to the same points.
Anyway, I used a 4.7 zener on a MY01 and I opted to solder it to the wire going into the ECU and it works fine. I don't know about the rest of you but I don't want to go soldering on the ECU board. As long as the zener is VERY SECURE (completely taped to) the wiring harness, it will be trouble free.
But this discussion brings on another point. Someone said that the diode might 'wear out' eventually so I was thinking that if 2 4.7 diodes were run in parallel, wouldn't that make the unit twice as durable while still bleeding off anything over 4.7 volts?
Anyone know the answer to that?
Tom
ludespeed is offline   Reply With Quote
Old 03-02-2001, 06:33 PM   #8
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Post
Putting two zeners in series will work. You just have to connect them like a battery in series - cathode to anode. Then heat-shrink them together. Otherwise, a butt-splice connector will work just fine too.
However, the difference between using a single 4.7V zener and two 2.4V zeners in series can be insignificant. For example, a 2.4V zener is typically rated between 2.2V and 2.6V, while a 4.7V zener is typically rated between 4.4V and 5.0V.
Zener diodes don't wear out. At least not in an application such as this one. If you manage to dump too much current into a diode, it will usually fail shorted, so a parallel scheme will do you no good.
-WaC
Wayne
wac is offline   Reply With Quote
For those who want to give the Ralph Wiggum Valentine Ripper Off-Topic 15 02-13-2009 01:16 PM
For those who want the WRC look of old SubaruWRC Interior & Exterior Modification 2 12-03-2002 03:06 AM
For those who want to see the STi CF Wing (long) Hakaider Member's Car Gallery 12 06-28-2002 07:40 PM
Good News for those who like the Dual (3,3.5,DTM) and single 4" style exhausts GTBGUY Normally Aspirated Powertrain 85 05-24-2001 07:33 AM
For those who want to be in the "Redline Movie" from Universal Pictures ARG General Forum Archive 10 09-23-2000 01:23 AM
