04-12-2001, 11:34 AM | #1 |
Member#: 296
Need an answer
Hi guys,
I've gone and confused myself... Can someone please tell me the type of bolt the 2.5 block uses (DOHC not that, that makes any difference). Does the main block bolts have a washer on it ? Is it silver or gold in colour ? What size spline socket does it use 12mm or 14mm ? Which of these looks like it: <IMG SRC="http://www.firefox-technology.com/images/closed%20deck%20bolts.jpg" border=0> <IMG SRC="http://www.firefox-technology.com/images/open%20deck%20bolts.jpg" border=0> Anyone have a part number for them ? (two lengths, main bolts are longer, two front ones are shorter) Cheers, J.
04-12-2001, 11:45 AM | #2 |
Member#: 114
Vehicle:'03 Evo, Rice White '01 Erion CBR 929 |
I can answer for SOHC. If you think it's the same, fine.
They use 14mm 12 sided bolts which are silver. The center pair have red heads, the outer four have silver heads. I do think they have washers. They look like the second pic. [This message has been edited by ColinL (edited April 12, 2001).] |
04-12-2001, 11:53 PM | #3 |
Member#: 296
Thanks for Colin,
I assume the washers dont slide off the bolts ? I just need to confirm for sure these are the correct bolts I have... Can someone measure the length of the bolt, the diameter of the unthreaded bolt and the washer diameter. Cheers, J. |
04-12-2001, 11:57 PM | #4 |
Member#: 4679
BAIC
go to a subaru dealer and ask them for a shop manual. You will have a correct answer for sure.
04-15-2001, 11:27 AM | #5 |
Member#: 296
Hi there,
I am trying to establish if the US blocks are the same as our 2.5 blocks. Anyone ? J. |
04-15-2001, 04:25 PM | #6 |
Member#: 2692
TXIC
You have 2.5s in england?
what cars do they come on? sorry haven't heard of this at all, |
04-15-2001, 08:57 PM | #7 |
Member#: 972
some of the forestors and such i think.
as for the blocks on the DOHC IF i recall right when i was messing around on my motor they were the silver colour 12 sided bolt which was a 14mm. can't remember the colour of the heads though..sorry. As for the washers.. i do remember them floating around on the bench AND i knew i shoulda taken pictures a little over a year ago..sorry |
04-16-2001, 06:10 AM | #8 |
Member#: 114
Jay, I believe the washer doesn't come off. If you need a part number, ask Ryan Cavalier at Irvine Subaru. His email is [email protected] , just tell him you have a 99 Impreza 2.5RS and need cylinder head bolts for it.
Fuel pressue- I need an answer! Thanks! | adamsrs | Normally Aspirated with bolt-on Forced Induction Powertrain | 10 | 04-13-2002 11:25 AM |
I need an answer to this question.... | WRX_02_227 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 11-28-2001 04:24 AM |
Help, stock bushing won't come out. I need an answer now, please | Aspen_2.5RS | Transmission (AT/MT) & Driveline | 4 | 09-16-2001 10:20 PM |
ground control guys... need an answer ASAP | burr101 | Technical Forum Archive | 10 | 10-06-2000 12:09 AM |
Amsoil filter installed - dumb question needs an answer please | Joe Lee | Technical Forum Archive | 3 | 06-29-2000 06:17 PM |
