Old 04-24-2001, 07:04 PM   #1
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Post Opinions on Lightweight Flywheels for an everyday driver
So what does everyone think? I did a search, ddn't turn up what I was looking for. Are they to light? Drop revs too fast? Would a short shift kit be needed? How much more power would be sent to the wheels if any, and how much would accerleration times improve? Thanks for the help!!
96Lconversion is offline   Reply With Quote
Old 04-24-2001, 11:34 PM   #2
BongMan
Member#: 2399
2001 Impreza RS
Post
It helps on acceleration, but it's loud. kind of like an intake but helps the whole power band. i guess revs drop faster, but a short shifter isn't really needed. also if you miss a shift and rev the engine/flywheel too much you'll blow up the tranny.
I honestly think it's a good mod but hard to do because it's pretty internal. ok have fun
BongMan is offline   Reply With Quote
Old 04-25-2001, 05:49 AM   #3
Bottom Feeder
Member#: 2808
Question
Hey BongMan- You'd better lay off the buds before you start giving out advice.
What the hell does a lightened flywheel have to do with how loud an engine is? Answer: not a damn thing. And a short shifter is a completely separate part, so installing a lightened flywheel does not make a short shifter unnecessary.
Where do some of you guys get this stuff?
[This message has been edited by Bottom Feeder (edited April 25, 2001).]
Bottom Feeder is offline   Reply With Quote
Old 04-25-2001, 10:17 AM   #4
BongMan
Member#: 2399
2001 Impreza RS
Post
My buddy has a lighten fly wheel and it sounds hella load. Perhaps that has nothing to do with the engine directly but that noise is still there. Maybe he should change is fluid but that thing makes hella noise.
Bottom Feeder: You seem to be really helpful with your responce. Do you have a fly wheel? Does it seem quiter than stock?
If the answer is yes to both of these i bet your flywheel is heavier. Regardless you haven't brought anything new to this discusion.
Jeez the nerve of some people.
Old 04-25-2001, 10:39 AM   #5
subarumantoo
Member#: 3257
2000 ImprezaRS
Blue Ridge Pearl
Post
A lightened flywheel will allow the engine to accelerate more quickly. This of course translates into the vehicle accelerating faster as well. It can cause more engine braking under decelleration because the rotating mass is reduced which allows the engines commpression to be transfered to the wheels more redily. As far as it sounding different, no, it makes no difference what so ever. I am about to purchase the chrome molly 12lb. flywheel from JCSports that is made by N1. Also keep in mind that it takes weight off of the vehicle as well. 13lbs. lighter is 13lbs. lighter! The factory flywheel weighs about 25lbs.
subarumantoo is offline   Reply With Quote
Old 04-25-2001, 10:41 AM   #6
smacksube
Member#: 4067
01 2.5 rs
Post
the flywheel really smoothes out the power band. My friend has a turboed integra ls and before he got the flywheel in you'd kinda feel an extra surge when the turbo spooled up, but now it's just a really smooth rev. I drove it and it feels the same to me actually. However the lightest flywheel I've seen for the impreza was 11 lbs and his is 7 lbs, so it probably couldn't be worse
smacksube is offline   Reply With Quote
Old 04-25-2001, 02:04 PM   #7
Cacophony
Member#: 213
2004 Mazda RX-8
Post
Hey. I've got an unorthodox racing 11lb flywheel in my car. And yes, it does make a little more noise than stock.. but it really can't be compared to the noise of an intake.. It's just a small increase in mechanical noises, more along the lines of harder engine/tranny mounts.
As far as being good in a daily driver, they certainly don't allow you to be lazy. If you're lazy, it'll make you look clueless with a manual tranny. And if you like taking your scoob out to thrash in the snow, then don't get an 11lb flywheel. I had to brutalize my act clutch this winter to get my RS moving in heavy snow. I don't think I'll be putting in as light of a flywheel on my STi motor
Cacophony is offline   Reply With Quote
Old 04-25-2001, 02:48 PM   #8
BongMan
Member#: 2399
2001 Impreza RS
Thumbs up
So let me recap what people have said.
One person is about to add a light flywheel to their car and says it won't make a difference.
Then someone else says that his buddy's turbo integ flywheel didn't seem to make that much more noise. However i'd say you couldn't hear the flywheel noise between the turbo or the BOV.
The last guy says that his impreza's flywheel sounded a somewhat louder.
Then OG bottom feeder says hay that has nothing to do with engine noise. Well then intakes shouldn't make noise either than huh?
To summarize I'd say bottom feeder needs to smoke some buds and prehaps listen to a impreza with at light flywheel before acting like an expert.
[This message has been edited by BongMan (edited April 25, 2001).]
Old 04-25-2001, 03:23 PM   #9
Bottom Feeder
Member#: 2808
Post
Kinda sounds like the Chewbacca Defense.
Are you serious?
Old 04-25-2001, 04:31 PM   #10
ImprezaRS dot com
over boosted again
Member#: 1458
2017 WRX Limited
2015 Forester XT, Tribeca
Post
I always wondered what the Chewbaca defense was - someone clue me in on this (yes, I've seen all the star wars)
My ACT clutch is louder than stock, and was installed at the same time as the JC Sports flywheel. I wonder if that is what is actually noisier for the other people, the clutch not the flywheel.
Now, about the short shifter. I did the SYMS short shifter and it does make a nice difference, and it isn't even any louder
However, the STI tranny mounts help shifting even more, as did the motor mounts that I did later, since the tranny is now rock solid and not moving about between shifts.
Larry www.ImprezaRS.com
ImprezaRS dot com is offline   Reply With Quote
Old 04-25-2001, 04:40 PM   #11
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Post
My Kartboy shifter is louder than stock.
*snick snick* as I run through the gears.
I can understand how a rotating mass can make noise though. If it's harder, got a different cut to the edge, has different holes, whatever... it'll make different noises. And there isn't as much mass to muffle the noises either. But I haven't driven one, or ridden in one, so I don't really know fo sho.
CosmoTheCat is offline   Reply With Quote
Old 04-25-2001, 04:57 PM   #12
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
larry,
the chewbacca defense comes from an older episode of SouthPark. basically it is a spoof on Johnny Cochran's "if the glove does not fit, you must acquit" from OJ's murder trial. anyway, the SP version is of course ludicrous and involves the following logic: "is Chewbacca a wookie?" (yes) "if Chewbacca is a wookie, then you must acquit." And naturally, the jury falls for it.
Our catfish friend here is trying to say that the argument or reasoning is unsound.
[This message has been edited by ColinL (edited April 25, 2001).]
ColinL is offline   Reply With Quote
Old 04-25-2001, 06:01 PM   #13
Rich L
Member#: 961
1999 RS-Tw/ CobraMAF
Custom Rallispec kit/IC#1
Post
96Lconversion
The lighter flywheel is a great mod.
Its similar the pully mod except it actually works!
Alot of ppl like to think that the pulley mod is worthwhile, but I disagree.
The flywheel mod is a different story and is big reason why I was able to pull off a [email protected] run at only 6psi of boost.
I would recommend a 13lb chrome molly flywheel. You'll notice the engine rev up and down quicker... But it is alot easier to stall the car. (a short throw shifer is not necessary)
To give you an idea. I never once stalled the car with the stock heave 26lb flywheel(in 2.5 yrs).
Since about Jan... I stalled my car 4 times (all times while going reverse)
Under 13lbs and you better avoid stop and go traffic. Of course this is my own subjective opinion.
Good luck
Rich L is offline   Reply With Quote
Old 04-25-2001, 06:53 PM   #14
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Post
People, please stick to the topic, I don't car WHAT noise a lighter flywheel makes, I want to know if it is a pain in a car used as a daily driver. Cacophony, Rich L, thanks for the info.
[This message has been edited by 96Lconversion (edited April 25, 2001).]
Old 04-25-2001, 08:14 PM   #15
efoo
Member#: 80
Post
well, noise *is* one of the factors that makes a car a daily driver or not, at least in my opinion.
but anyways, what Rich L said. especially since he has (what used to be) my flywheel. do a search on Exedy flywheels and you'll see my impressions of that 13lb flywheel.
noise-wise, yes, there *is* some addl. noise. the engine revs up much faster and so you just hear more engine noise more quickly. there is a slightly more metallic sound to it which is hard to describe unless you've heard it yourself. it didn't bother me while i had the lightened flywheel in my NA 2.5RS though. now that I have a turbo in the car and use a turbo tranny and STi flywheel that still weighs about 15 lbs, I still feel that the lightened flywheel is a big part of what makes my car fun to drive.
but you do have to drive it more. stop and go traffic makes your left foot a bit tired after a while. caveat emptor.
-Edwin
efoo is offline   Reply With Quote
Old 04-25-2001, 08:30 PM   #16
BongMan
Member#: 2399
2001 Impreza RS
Cool
I told you so.
HAa haa
Old 04-25-2001, 08:41 PM   #17
efoo
Member#: 80
Post
uh...
Old 04-25-2001, 08:45 PM   #18
Captain Ding
Member#: 5773
2003 Forester XS
Pacifica Blue
Post
I think Cacophony is right on the money. I have an Unorthodox Flywheel which weighs 12 or 13 lbs on my daily driver. The difference in acceleration at low speeds is very noticeable. As far as driveability goes, it just takes a little bit more concentration to get going from a standing start, especially in stop-and-go traffic or on hills. After a couple of days with it, you will have no problem. Revs drop a lot quicker, so it will definitely change your shifting habits, especially when the A/C compressor turns on. The benefit (faster shifts, easier heel/toe downshifts, faster acceleration at low speeds) far outweigh any negative points. As far as noise, there's a slight metallic sound if you are standing by the hood of the car while it is idling, but I've never heard much noise while actually driving.
Captain Ding is offline   Reply With Quote
Old 04-25-2001, 10:54 PM   #19
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Post
Hey guys, all this info is great, I really appreciate it. I am sometimes a very lazy driver, would I have to be really careful all the time or would I just get used to it? Does anyone make a 15 or 16lb-er?? I wish they had ajustable flywheels , 11-25lb setting!! that would be nice!
Old 04-26-2001, 01:56 AM   #20
Bottom Feeder
Member#: 2808
Question
*sigh*
If you say so...
Old 04-26-2001, 06:16 AM   #21
pottsie350
Member#: 6110
98 Impreza L
Red
Question
How much would a lighter flywheel effect traction in snowy/loose gravel conditions? Or is a lighter flywheel just best suited to road use?
pottsie350 is offline   Reply With Quote
Old 04-26-2001, 12:51 PM   #22
CosmoTheCat
Member#: 3409
98 My FMIC
Post
pottsie - With the lightweight flywheel you would have to feather the clutch more to get started in slick conditions. Because it is easier to stall (less rotating mass helping you out) it takes a little more work (and a little more riding on the left foot). Once you are under way I wouldn't think there would be too much difference. Maybe go easy when getting on or off the gas though.
Old 04-26-2001, 05:37 PM   #23
pottsie350
Member#: 6110
98 Impreza L
Red
Smile
Thanks, I really like driving in the gravelly greasy stuff. If it mostly effects low speed operation and stalling, then I should be alright. I ride dirt bikes a lot, and I know when you lighten a flywheel on the scooters, it can really make them difficult in the soupy stuff. But then again I'm only going 5~10 mph through the woods on the bike, vs 30 to 100 on gravelly/snowy roads in the car.
Old 04-27-2001, 07:12 AM   #24
Rich L
Member#: 961
Exclamation
96Lconversion
I wouldnt worry about any increase in noise created by the flyheel. Usually 10 out of 10 times, by the time you swap flywheels you have already done other "noisier" mods!
Like intake and exhaust.
My car is so dam loud now with an upgraded intake, headers, and Supertrapp mufflers...
I can have 4 bad wheel barings and I would never know! So dont worry about flywheel noise. Its a good mod.
Old 04-27-2001, 11:52 AM   #25
deepbeep
Member#: 1392
Post
Does anyone run this HKS clutch/flywheel combo?
http://www.maxpower.co.uk/products/p...?idArticle=589
deepbeep is offline   Reply With Quote
Opinions on lightweight batteries only1agam Electrical & Lighting 8 12-11-2006 03:31 PM
Best modes for a everyday driver for about 2 grand mjjantz General Community 15 04-23-2005 05:59 PM
lightweight flywheel without an uber-clutch? alacrity024 Transmission (AT/MT) & Driveline 10 12-14-2004 06:41 AM
Used Exedy lightweight flywheel for an 02-03 WRX BLUETURBOWRX Private 'For Sale' Classifieds 12 09-17-2003 08:16 PM
opinions on Sequential Turbochargers for an Impreza FuJi K Normally Aspirated with bolt-on Forced Induction Powertrain 30 11-07-2001 02:44 PM
