Old 02-28-2001, 08:38 PM   #1
pimpomtic
Member#: 2699
2001 2.5 RS- ?????
Post Reset on ECU?
In a week or two Iam getting a cobb intake for my 01 and I have a borla header and borla cat-back on it know so how would I reset my ECU?
pimpomtic is offline   Reply With Quote
Old 02-28-2001, 08:42 PM   #2
preza
Member#: 1454
2000 2.5 RS-T
Post
Disconnect your negative battery terminal(the black wire going to the battery) for about 30 minutes, then connect it back. I believe it takes a 10mm socket.
preza is offline   Reply With Quote
Old 02-28-2001, 09:23 PM   #3
ivbdn
Member#: 2736
2001 Impreza 2.5RS
Post
If you've got an alarm, don't forget to somehow mute the siren when you reconnect the battery. Once you reconnect, it sets off the alarm. Then, turn on your car and let it idle for about 20 - 30 mins. w/o pressing the gas. Once that's done, turn it off. Then turn it on and drive around. That's it!
ivbdn is offline   Reply With Quote
Old 02-28-2001, 10:56 PM   #4
kaos200
Member#: 2692
Post
How about resetting without removing total power, I have radio presets, cd presets, bosst controller setting and ttimer settings
anyway to remove a fuse to the ecu or something?
kaos200 is offline   Reply With Quote
Old 03-01-2001, 07:48 AM   #5
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
Post
You dont have to reset your ECU, ever if you dont want to. It just helps speed up the process. The ECU will learn the new intake without being reset. If you dont mind driving around for about 15 minutes to allow the computer to learn the new settings, then you dont have to unplug anything. The computer works on constant feedback from the emission controls. It will detect something has changed and adjust it for you.
The ECU reset is just to "speed up" the process. If you would rather keep all your settings. Dont reset the ECU.
SCRAPPYDO
stephen
Old 03-01-2001, 08:02 AM   #6
bratmantlz
Member#: 3231
88 626 Turbo
white
Question
maybe write down the settings and then do the reset??
bratmantlz is offline   Reply With Quote
Old 03-01-2001, 11:13 AM   #7
akacuron
Member#: 4553
Post
In order to reset the CPU, you'll have to diconnect the neg terminal for about a hour if not more. You'll know its reset when your clock start at 12:00. The system has a battery backup that will hold the data for about an hour while bat is disconnected. Then I recommend letting your ride idle for 10-15 min. Then drive it like a wuss for a few days to get a good air/fuel mixture.
This is what I had to do.
ps: if you reconnect your bat and punch the gas, the CPU will since all the air-think its the norm and you'll have horable gas milage for awhile till it fixes itself.
akacuron is offline   Reply With Quote
Old 03-01-2001, 05:05 PM   #8
inpreza kid
Member#: 3334
Post
if you don't reset its ok but it just takes longer for the ECU to learn the mods you put on. over time the ecu will learn to deal with the but if your looking for instant results then you should reset.
inpreza kid is offline   Reply With Quote
Old 03-01-2001, 08:16 PM   #9
etam
Member#: 439
www
Post
I don't know, you all say negative terminal, how about disconnect positive terminal?? Any reason why not?
etam
etam is offline   Reply With Quote
Old 03-01-2001, 10:18 PM   #10
Scooby2
Member#: 2644
Post
Disconecet the negitive and you don't have to worry about grounding the pos and arc welding your wrench to the body.
Scooby2 is offline   Reply With Quote
You know how your lights blink on and off when you reset your ecu? eurojax Off-Topic 7 01-17-2006 08:15 AM
How do i reset my ECU on my 02 WRX? BlackedOut REX General Community 1 07-23-2005 11:13 AM
Reset the ECU after full STI exhaust install on 04 FXT? shinyhappyzealot Forester Forum 3 03-03-2005 03:00 PM
ECU Reset on STI, Jerry C STi Forum Archive 10 08-05-2003 03:05 AM
ECU Reset on CAI Install?? DustinR Normally Aspirated Powertrain 8 10-30-2001 04:14 PM
