Old 04-25-2001, 09:38 AM   #1
PURE EPI
Member#: 2642
Unhappy Scooby having problems!!
I think that the mixture is rich but i'm not sure. I changed the spark plugs a couple months ago. and the symptoms have just gotten worse.
Rough idle with stalling
low idle speed. intermittent choke(i suppose)
bad gas mileage.
not too good low end power
A friend says to change to Ammoco Clear Premium and throw a can of BG intake cleaner in and run the dog doo doo out of it to clean out all the crap that's in there since i run regular unleaded all the time. but I hadn't really noticed the problem until a while after I changed the plugs (Pep Boys NGKs) is that the culpret??? Also still having that drop in power at around 4k RPMs
Tune up in order? Thanks so much everyone.
Christian
PURE EPI is offline   Reply With Quote
Old 04-25-2001, 09:50 AM   #2
steppin16
Member#: 6010
Post
have you done anything witht the intake? my problem was the same as yours. the told me it as the MAF sensor. does your car smell bad?
steppin16 is offline   Reply With Quote
Old 04-25-2001, 10:03 AM   #3
TimCat
Member#: 2451
2000 2.5 RS Coupes
BRP and a STM
Post
Sounds like you are running lean. Might be a bad O2 sensor. They had a big recall on them.
TimCat is offline   Reply With Quote
Old 04-25-2001, 10:08 AM   #4
newt3k
Member#: 5180
Post
that def. sounds like an o2 sensor problem, same exact thing happened to my neon... damn expensive things too.
newt3k is offline   Reply With Quote
Old 04-25-2001, 03:24 PM   #5
PURE EPI
Member#: 2642
Post
update---
car is stock(needs to be for the Rally X championship this year)
the fuel filter is original... where is it anyway(d'oh!!)?
guess i could have the dealer look at it(O2 sensor) is this s wide spread problem? if so I have it under warranty
Old 04-25-2001, 04:13 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Post
Ever since changing the plugs huh? First, did you get the right plugs and did you gap the correctly?
Jay McDade
Auto Tech--Lincoln/Mercury/Jaguar
www.hometown.aol.com/impreza25rs2000
munkis is offline   Reply With Quote
Old 04-25-2001, 04:34 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Post
Take it to the dealer and have them look at the O2 sensor. The part was truly recalled, like with a mass mailing, etc. If you never got the letter and the dealer denies the recall exists, there are a few guys over on the general forum who have been faxing copies of the letter to other members to put nasty dealers in their place.
Old 04-25-2001, 04:47 PM   #8
Poseidon
Member#: 4864
2004 WRX
Post
Before you get all nasty about recall stuff, I should point out that the recall in question only applies to MY'00 cars. At least, that's what the recall letter for our 2000 Outback said.
Jordan
Poseidon is offline   Reply With Quote
Old 04-25-2001, 06:07 PM   #9
PURE EPI
Member#: 2642
Post
God it's good to have a family like this sniff.. Here's my plan cheap fixs first.
replace plugs with Subaru spec hardware.
fill and maintain only with Ammoco Clear
add BG injector engine cleaner
------correction----find fuel filter
can someone help with that??
THEN
change fuel filter
any additions or ideas welcome
Christian
Old 04-25-2001, 06:14 PM   #10
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
Did you reset the ECU yet?
Check your wires with a continuity meter to make sure none of them have blown out. Take out the spark plugs, check them for problems, check the threads, check the crush washer (make sure there is still a washer). Check the terminals on the ignition coil, if there are signs of corrosion, clean them and use dielectric grease.
Screw the Amoco Ultimate, it does squat for our cars (Amoco Regular works just fine). The fuel injector cleaner is a good idea. Check for the second air filter and make sure it isn't soaked in oil. Hmm, and make sure the crank case breather hoses are all tight (3 of em) against the airbox.
[This message has been edited by Revision (edited April 25, 2001).]
Revision is offline   Reply With Quote
Old 04-25-2001, 08:29 PM   #11
PURE EPI
Member#: 2642
Post
Funny thing was, @ Cherokee Trails, I was told by, who could only be descibed as Juha Kankunnen's clone, told me to use premium always or i'd be sorry in the long run... I guess he knew his stuff cuz he had a Legacy there that had over 200K miles on it.
I know Ammoco Ultimate has lless crap in it cuz it's clear... juat trying to fix the problem... could i have used the wrong plugs???
Old 04-25-2001, 09:04 PM   #12
Dissenter
Member#: 3777
03 Yellow WRX Wag
I drive the short bus.
Post
To verify, I got my letter just the other day and yes the recall does NOT apply to the 99s.
Dissenter is offline   Reply With Quote
Old 04-26-2001, 12:30 AM   #13
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
have you changed your fuel filter? The flat spot is an unfortunate trait of the 99 RS...an intake cures it though.
STiShawn is offline   Reply With Quote
Old 04-26-2001, 10:45 AM   #14
Michael
Member#: 989
99 RS Turbo
Graphite Gray Pearl
Post
well i see two different case with you problem and i encountered them both...hee hee hee...
the rough idle with stall.. does your rev go up and down when idle? lets say from 500 rpm to 1200 rpm?
and the car stinks becuase its running a bit rich...you will smell the unburn gas.
you will see a heavy carbon build up on the tail pipe.
if this happens most likely you have a MAF failure.
about your lost of low end power...does you car feel like a vtech all of a sudden?
you know once over 4000 it pulls like there is no tomorrow?
well if that is the case i would check the knock sensor, you knock sensor might be bad also.
are there any check engine light?
take it to the dealer and let them take a look at it.
i have encounter the problems that you have mentioned ...and mostly likely that might be the problems.. i can be wrong though... but bottom line take it to the dealers.
hope this helps
good luck
michael
[This message has been edited by Michael (edited April 26, 2001).]
Michael is offline   Reply With Quote
Old 04-26-2001, 05:22 PM   #15
PURE EPI
Member#: 2642
Post
Thanks dude,,,
all of you(sniff)
[This message has been edited by PURE EPI (edited April 26, 2001).]
I have been having problems with the ladies lately: Subr-man Rocky Mountains Impreza Club Forum -- RMIC 27 03-05-2009 06:03 PM
new scooby, tranny problem azimiut Transmission (AT/MT) & Driveline 1 04-19-2004 05:30 AM
Anybody else having problems with scooby mods? STiTuner Off-Topic 17 04-01-2004 08:06 AM
New to scoobies, have some questions orlandowrx Newbies & FAQs 12 05-24-2002 09:06 PM
