Old 04-24-2001, 10:02 PM   #1
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Question Underdrive Pulley questions Pros/Cons
Ok, I've done some research on these. Been considering one for a while. I know about how the lighten weight and smaller dia helps the engine, faster revs, more hp, etc.
I guess my main concern is the reduction in rpm's of the alternator. So at an idle there is less juice goin to the car's electrical system. I have read what their site says, and everything. I have talked to two friends, that have done it, one has an RS, and it does dim the lights when at an idle, until the revs get to about 1200-1500. The other friend has a early 90's turbo touring wagon....he said he didn't notice any difference or dimming in the lights.
Sooo, my question....what's everyone else's experiences, observations, Legacy, impreza, svx owners..???
I have a 90 Legacy. I do have a 500+ Watt stereo system, however I have it tuned where the gains are fairly low. I also have an Optima Yellow top deep cycle battery.
I've got more specific details on my stereo and other mods on my website Check it out.
The main reason I am asking is that uncle sam decided to give me some money this year So I was thinkin....what better way to spend it, then on my subie...haha
Thanks for any input.
Josh
Legacy777 is offline   Reply With Quote
Old 04-25-2001, 12:30 AM   #2
suberboy
Member#: 1531
2008 GRB
Red
Post
i have had an underdrive pully for about 9 months now and havn't had any problems. i have 500+ watt stereo and use the ac occasionally and havn't noticed a difference from stock. some people on this board have noticed a difference with ac though so you never know. hope that helps.
suberboy is offline   Reply With Quote
Old 04-25-2001, 05:35 AM   #3
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
If you're worried about not enough electricity being generated by using UDP, you have an option of getting the same size pulley as the stock ones, but a lot lighter. I think JC Sports sells it.
tmat3 is offline   Reply With Quote
Old 04-25-2001, 08:37 AM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Post
I've had the unorthodx pulley for about 3 months. I haven't noticed any problems, and my gas mileage went up about 1 mpg.
My car is a MY00 RS w/cobb intake and stromung cat back.
Old 04-25-2001, 09:26 AM   #5
LangstonSubaru
Vendor
Member#: 2175
Cool
I have them, haven't seen any difference. It took a couple days to get used to the new belt sound, after listening to the belts on the steel heavy pullies, the aluminum sounds different. I say "go getcha sum!"
LangstonSubaru is offline   Reply With Quote
Old 04-25-2001, 10:21 AM   #6
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
Post
Ahh so the trick to avoid the idle/stalling out problem/ with a racing underdrive pulley is to find one that is same sized as stock but lighter? I've heard problems from other ppl as well about the smaller sized pulleys and inadequate electrical delivery to the alternator.
Ed
edkwon is online now   Reply With Quote
Old 04-25-2001, 11:43 AM   #7
adamsrs
Member#: 3768
Post
I love mine!
adamsrs www.unnatural.org
adamsrs is offline   Reply With Quote
Old 04-25-2001, 11:45 AM   #8
Legacy777
Member#: 4800
Post
The thing is that when you reduce the size of the main pulley, you are effectively changing the "gear" ratio between the main pulley and the alternator. and/or other pulleys.
This helps, because it gives the engine less resistance and is easier to rev, hence little more power, and throttle response.
However it decreases the final drive ratio by the alternator pulley.
Easy way to think of this, is with a mtn bike. When you're in the big gear in the front and little one in the back you can go very fast, but it takes alot more leg power to get moving. However, when you're in the small gear in the front and big one in the back, you have alot more torque, it's easier to get going faster, but you can pedal like crazy and you only go so fast. Granted this example is on the extremes. But should give you a better picture.
The best solution would be to make a smaller alternator pulley to compensate for the decrease in size of the main pulley. A friend of mine was going to do this for me, but backed out at the last minute, because of time.
I've got it calculated how much the rpm of the alternator drops. I'll post the difference when I get back home and have the papers.
Josh
Old 04-25-2001, 11:55 AM   #9
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Question
I have an UDP and notice that the power steering is also effected. Anyone else?
John2.5RS is offline   Reply With Quote
Old 04-25-2001, 01:27 PM   #10
Legacy777
Member#: 4800
Post
What does it do to the power steering? Just harder to turn at idle speeds?
Old 04-25-2001, 01:39 PM   #11
Legacy777
Member#: 4800
Post
Ok, here's the info on the speeds of the pulleys (mainly alternator and main pulley)
Here's the test or given info, if you want to call it that.
Engine speed(rpm)=500rpm
Stock crank pulley dia (edge to edge)=5.25"
Stock Alternator pulley dia (edge to edge)=2.375
Underdrive crank pulley dia (edge to edge)=4.375
For those parameters, engine speed 500 rpm
With the stock crank pulley the alternator pulley would be goin around 1105 rpm's
With the underdrive crank pulley, the alternator pulley would be goin around 921 rpm's
So....Ultimately...you're loosing about 200 rpms in speed to the alternator pulley.
Without knowing more info about the alternator, it's hard to tell how much less voltage & amperage is coming out with a loss of 200 rpm's.
If anyone cares to know how I got my info, here's the calcs I used
D=dia driving pulley
d=dia driven pulley
S=speed of driving pulley
s=speed of driven pulley
d = (D*S)/s
Have any questions about the above stuf....drop me a line
Underdrive pulley questions Acejam2k Normally Aspirated Powertrain 7 08-17-2004 02:34 AM
GFB pulley kits, pros and cons and how to install Imprezanize Normally Aspirated Powertrain 1 04-06-2004 10:39 AM
pros and cons of an underdrive pulley? Poe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 45 11-18-2002 04:18 PM
Underdrive Pulley Question TheNookie Rocky Mountains Impreza Club Forum -- RMIC 7 10-11-2002 07:01 PM
Another Underdrive Pulley Question bobski Legacy Forum 1 12-09-1999 10:43 AM
