Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 01-09-2003, 06:15 PM   #1
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Default The Subaru CEL thread
Purpose: Did your Scooby throw a cel?
Help us to see what is common with subarus, every car line has problems accross the line, with the thread we can see what kind of problems subaru is experiencing, what are the most common causes of the CEL to come on on a scoobie.
So please post, your cars, year, make, model and mileage, what cel code you have gotton, the code and definition.
If it was fixed, please include what was done to rectify the the problem.
Things not to post.
If you have a high flow cat and keep getting cat efficiency codes.
this is a reference thread meant to help those who have from stock to slightly moddified vehicles.
lets see how it goes.
Thanks everyone.
Please try to use this format for posting to the log, then add your comments below the entry.
Code: Defintion
Year/Make/Model
Mileage:
Fix for problem:
Old 01-10-2003, 10:47 AM   #2
GreenGiant
Member#: 19991
2000 Outback Ltd Wgn
Timberline Green
Default P0420 Cat below efficiency
P0420 - Cat. below efficiency threshold: Bank 1.
2000 Legacy OBW LTD.
61k
I have a 2000 Legacy OBW Ltd. with 61K on the clock. My car is BONE STOCK as far as the engine is concerned. I got a P0420 "Cat. below efficiency threshold: bank 1". I was told by the AutoZone clerk that this is an O2 sensor going bad and I needed to replace the sensor. I have since been told by McDade and HndaTch627 that this is really my cat going bad. Updates to come.
Tony
*Update* OK I have to fess up to being dumb. I had replaced the spark plugs before I got the code and I had used Bosch Platinum regular plugs, not the "plus 2 or 4" gimicks just regular platinum plugs. I know that I had been warned about using Bosch plugs but they were the only things available at the time. I ended up calling the stealer (Southern States) and talking to Quincy the lead Suby mechanic. I told him that I had done the 60K service and he said "You put Bosch Platinum plugs in it didn't you.". I told him I had and he told me to get them out and replace them with NGKs. I was able to find regular copper NGK "V-power" plugs that crossed to the original Champion plugs. Once I put the plugs in and drove it a couple of days the light went out but I still had it cleared by AutoZone. I have been driving it now for about a week in the fixed state with no light and much better fuel economy.
/kicks self in butt/
GreenGiant is offline   Reply With Quote
Old 01-12-2003, 10:58 PM   #3
Matt
Allergic to turbos
Member#: 181
Two Subarus and
a truck
Exclamation Re: P0420 Cat below efficiency
Tony
P0420 - Cat. below efficiancey threshold: bank 1
I've had that twice. I had 49k on the clock. The dealer replaced the cat. 10k miles later, I've not seen that CE light.
Now I'm getting another code, P0065. I've had 6 CE lights since Thanksgiving.
A friend had the same code on his RS a few weeks ago. Turns out that a solenoid mounted on a bracket behind the power steering resivoir. I took it apart and cleaned it, seemed to work and the light was off, but as mentioned before, its back on. I also installed a Ganzflow intake at the same time and after 120 miles, I've got yet another CE light. I'll get it scanned tomorrow and post what it is.
BTW, the Ganzflow and K&N are my only modifications to the intake/fuel system.
Matt is offline   Reply With Quote
Old 01-13-2003, 07:14 PM   #4
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Hmmm ... I swear I've seen (and entered info into) a similar thread already ...
Mike Wevrick is offline   Reply With Quote
Old 01-13-2003, 10:59 PM   #5
jeddy
Member#: 7711
2005 WRX STi
I recently had a P0420 (cat efficiency low, bank 1) on my 00 RS. I have a Stromung 2.25" cat-back, Borla headers, and 47K miles. The mechanic i went to (Honda and Subaru specialist) says he sees these types of codes alot in cars with high-flow exhausts and headers. A lack of heat shielding on the headers can supposedly also cause this, since the exhaust loses too much heat before getting to the cat.
I was told this will cause no harm, but the cats may not be working as well as they could.
jeddy is offline   Reply With Quote
Old 01-14-2003, 03:37 AM   #6
Andrew Bacon
Member#: 2267
00RS
rutherforddesign.com
This is a catch 22: I have a Borla/ Apexi N1, 48K miles. I have been throwing CEL's a lot lately. (don't know the code yet) I took off the header yesterday to put in STi motor mounts and ThermoTec Header wrap. The inside of the header has heavy carbon fouling. So...somehow the O2 sensor is seeing an erroneous lean condition and is over richening the mixture, which is fouling the plugs, O2 sensor, Cat.....everything.
My other thought is maybe the Borla has a high enough flow that it blows the gasses through the cat too fast to burn fully?
I'm sure the header wrap will help, but I wish I knew which wire on the O2 sensor was the sense lead so I can test it at closed loop.
Are the 00' RS O2 sensors 0-5 volt? Is STOICH 2.5 volts?
Any help is greatly appreciated!
-Andy
Andrew Bacon is offline   Reply With Quote
Old 01-14-2003, 06:38 PM   #7
Matt
Allergic to turbos
Member#: 181
Two Subarus and
a truck
Have either of you ever received a recall notice from Subaru for your o2 sensors or reprogram of the ECM? I had that code several times and once the dealer replaced the cat, it went away. I had the standard mid-pipe but Stromung rear box. I've also heard that that setup will throw that code frequently, but its meaningless after a while.
Oh, my pe0065 is currently off. I took apart the solenoid behind the power steering resivoir and cleaned it. Seems ok now, but I'll give it a few hundred miles before I declare it fixed.
Old 01-14-2003, 08:19 PM   #8
Jon [in CT]
Member#: 2992
02 WRX Sedan
Default Re: The Subaru CEL thread
Things not to post.
Thanks everyone.
Gee, I thought there was already a "reference thread" for CELs in the Warranty Issues & SOA Problems forum titled WRX Check Engine Light Log, started on April 5, 2001 by a moderator with, currently, 296 posts.
Great idea to Balkanize the information.
Jon [in CT] is offline   Reply With Quote
Old 01-14-2003, 09:13 PM   #9
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Not everyone on this board has a WRX , so spare me, further more that thread/log was started to use as ammo with SOA to get on the ball with all the CE light problems everyone was having with the 'new' wrx.
Also this thread has NOTHING to do with warranty or SOA, its is exactly as stated a log to so members can quickly find information on codes that they may have.
if I can find another full subaru line based cel log thread in this forum I will merge them.
please stick to the subject.
Ive edited some posts to be able to pick out the codes easier, please try to use this format
Code: Defintion
Year/Make/Model
Mileage:
Fix for problem:
thanks
Jay
Old 01-14-2003, 10:30 PM   #10
Jon [in CT]
Member#: 2992
02 WRX Sedan
I argue that the WRX DOES represent the Impreza line. Subaru reports Impreza sales as an amalgam of RS, TS, Outback Sport and WRX sales. Last year Subaru reported that it sold a total of 38,226 Imprezas, of which 22,910 were WRXes (see http://www.prnewswire.com/cgi-bin/st...1869518&EDATE=). In other words, 60 percent of all Imprezas sold last year were WRXes.
However, Keep your thread for the small proportion of non-WRX Imprezas. Merely insure that the WRX CELS are reported in the long-running thread that was established for this purpose and has helped members in the past: WRX Check Engine Light Log.
Old 01-15-2003, 04:53 AM   #11
Andrew Bacon
Member#: 2267
00RS
Originally posted by Jon [in CT]
......Last year Subaru reported that it sold a total of 38,226 Imprezas, of which 22,910 were WRXes.....the small proportion of non-WRX Imprezas.....
Small proportion?!? 22,910 WRX's were added to our roads PREVIOUSLY occupied by Imprezas since the early 90's. There are a whole lot more non-WRX Imprezas on the roads than WRX's, and for that matter, this club was founded when there were ZERO USDM WRX cars on the road. When it comes to Imprezas, the WRX is the exception, NOT the norm, pal.
edit: I apologize for the OT posting I have shared in, but this guys false sense of exclusivity, sour attitude, and misinformation is a joke.
Old 01-15-2003, 03:10 PM   #12
Pocon
Member#: 17479
1999 Impreza WRX
Silverthorn Metallic
Found this, could be for future reference. _
Sorry about the length but there are a lot of codes for a WRX.
Subaru Specific OBDII Diagnostic Trouble Codes (DTC)
P0031 Front oxygen (A/F) sensor heater circuit low input
P0032 Front oxygen (A/F) sensor heater circuit high input _
P0037 Rear oxygen sensor heater circuit malfunction
P0038 Rear oxygen sensor heater circuit high input
P0065 Air assist injector solenoid valve malfunction
P0066 Air assist injector solenoid valve circuit low input
P0067 Air assist injector solenoid valve circuit high input
P0101 Mass air flow sensor circuit range/performance problem (high input)
P0102 Mass air flow sensor circuit low input
P0103 Mass air flow sensor circuit high input
P0106 Pressure sensor circuit range/performance problem (low input)
P0107 Pressure sensor circuit low input
P0108 Pressure sensor circuit high input
P0111 Intake air temperature sensor circuit range/performance problem
P0112 Intake air temperature sensor circuit low input
P0113 Intake air temperature sensor circuit high input
P0117 Engine coolant temperature sensor circuit low input
P0118 Engine coolant temperature sensor circuit high input
P0121 Throttle position sensor circuit range/performance problem (high input)
P0122 Throttle position sensor circuit low input
P0123 Throttle position sensor circuit high input
P0125 Insufficient coolant temperature for closed loop fuel control
P0128 Thermostat malfunction
P0130 Front oxygen (A/F) sensor circuit range/performance problem (lean)
P0131 Front oxygen (A/F) sensor circuit range/performance problem (low input)
P0132 Front oxygen (A/F) sensor circuit range/performance problem (high input)
P0133 Front oxygen (A/F) sensor circuit slow response
P0136 Rear oxygen sensor circuit malfunction
P0139 Rear oxygen sensor circuit slow response
P0171 Fuel trim malfunction (A/F too lean)
P0172 Fuel trim malfunction (A/F too rich)
P0181 Fuel temperature sensor A circuit range/performance problem
P0182 Fuel temperature sensor A circuit low input
P0183 Fuel temperature sensor A circuit high input
P0244 Wastegate control solenoid valve malfunction (high input)
P0245 Wastegate control solenoid valve circuit low input
P0246 Wastegate control solenoid valve circuit high input
P0301 Cylinder 1 misfire detected
P0302 Cylinder 2 misfire detected
P0303 Cylinder 3 misfire detected
P0304 Cylinder 4 misfire detected
P0327 Knock sensor circuit low input
P0328 Knock sensor circuit high input
P0335 Crankshaft position sensor circuit malfunction
P0336 Crankshaft position sensor circuit range/performance problem
P0340 Camshaft position sensor circuit malfunction
P0341 Camshaft position sensor circuit range/performance problem
P0420 Catalyst system efficiency below threshold
P0442 Evaporative emission control system malfunction
P0444 Evaporative emission control system purge control valve circuit low input
P0445 Evaporative emission control system purge control valve circuit high input
P0447 Evaporative emission control system vent control low input
P0448 Evaporative emission control system vent control high input
P0451 Evaporative emission control system pressure sensor range/performance problem
P0452 Evaporative emission control system pressure sensor low input
P0453 Evaporative emission control system pressure sensor high input
P0456 Evaporative emission control system malfunction
P0457 Evaporative emission control system leak detected (fuel cap loose/off)
P0461 Fuel level sensor circuit range/performance problem
P0462 Fuel level sensor circuit low input
P0463 Fuel level sensor circuit high input
P0464 Fuel level sensor intermittent input
P0480 Cooling fan relay 1 circuit low input
P0483 Cooling fan function problem
P0500 Vehicle speed sensor malfunction
P0506 Idle control system RPM lower than expected
P0507 Idle control system RPM higher than expected
P0508 Idle control system circuit low input
P0509 Idle control system circuit high input
P0512 Starter switch circuit high input
P0545 Exhaust gas temperature sensor circuit low input
P0546 Exhaust gas temperature sensor circuit high input
P0604 Internal control module memory check sum error
P0703 Brake switch input malfunction
P0705 Transmission range sensor circuit malfunction
P0710 Transmission fluid temperature sensor circuit malfunction
P0715 Torque converter turbine speed sensor circuit malfunction
P0720 Output speed sensor (vehicle speed sensor 2) circuit malfunction
P0725 Engine speed input circuit malfunction
P0731 Gear 1 incorrect ratio
P0732 Gear 2 incorrect ratio
P0733 Gear 3 incorrect ratio
P0734 Gear 4 incorrect ratio
P0741 Torque converter clutch system malfunction
P0743 Torque converter clutch system (Lock-up duty solenoid) electrical
P0748 Pressure control solenoid (Line pressure duty solenoid) electrical
P0753 Shift solenoid A (Shift solenoid 1) electrical
P0758 Shift solenoid B (Shift solenoid 2) electrical
P0778 2-4 brake pressure control solenoid valve (2-4 brake duty solenoid) circuit malfunction
P0785 2-4 brake timing control solenoid valve (2-4 brake timing solenoid) circuit malfunction
P1086 Tumble generator valve #2 (LH) position sensor circuit low input
P1087 Tumble generator valve #2 (LH) position sensor circuit high input
P1088 Tumble generator valve #1 (RH) position sensor circuit low input
P1089 Tumble generator valve #1 (RH) position sensor circuit high input
P1090 Tumble generator valve #1 (RH) malfunction (stuck open)
P1091 Tumble generator valve #1 (RH) malfunction (stuck close)
P1092 Tumble generator valve #2 (LH) malfunction (stuck open)
P1093 Tumble generator valve #2 (LH) malfunction (stuck close)
P1094 Tumble generator valve circuit #1 (open circuit)
P1095 Tumble generator valve circuit #1 (over current)
P1096 Tumble generator valve circuit #2 (open circuit)
P1097 Tumble generator valve circuit #2 (over current)
P1110 Atmospheric pressure sensor low input
P1111 Atmospheric pressure sensor high input
P1112 Atmospheric pressure sensor range/performance problem
P1130 Front oxygen sensor circuit malfunction (open circuit)
P1131 Front oxygen sensor circuit malfunction (short circuit)
P1134 Front oxygen (A/F) sensor microcomputer problem
P1137 Front oxygen (A/F) sensor circuit range/performance problem
P1139 Front oxygen (A/F) sensor #1 heater circuit performance/range problem
P1141 Mass air flow sensor circuit range/performance problem (low input)
P1142 Throttle position sensor circuit range/performance problem (low input)
P1146 Pressure sensor circuit range/performance problem (high input)
P1230 Fuel pump control unit malfunction
P1244 Wastegate control solenoid valve malfunction (low input)
P1245 Wastegate control solenoid valve malfunction (fail-safe)
P1301 Fire due to increased exhaust temperature
P1312 Exhaust temperature sensor malfunction
P1400 Fuel tank pressure control solenoid valve circuit low input
P1420 Fuel tank pressure control solenoid valve circuit high input
P1443 Evaporative emission control system vent control function problem
P1480 Cooling fan relay 1 circuit high input
P1507 Idle control system malfunction (fail-safe)
P1510 Idle air control solenoid valve signal 1 circuit low input
P1511 Idle air control solenoid valve signal 1 circuit high input
P1512 Idle air control solenoid valve signal 2 circuit low input
P1513 Idle air control solenoid valve signal 2 circuit high input
P1514 Idle air control solenoid valve signal 3 circuit low input
P1515 Idle air control solenoid valve signal 3 circuit high input
P1516 Idle air control solenoid valve signal 4 circuit low input
P1517 Idle air control solenoid valve signal 4 circuit high input
P1518 Starter switch circuit low input
P1540 Vehicle speed sensor malfunction 2
P1544 High exhaust temperature detected
P1560 Back-up voltage circuit malfunction
P1590 Neutral position switch circuit high input
P1591 Neutral position switch circuit low input
P1592 Neutral position switch circuit (MT model)
P1594 Automatic transmission diagnosis input signal circuit malfunction
P1595 Automatic transmission diagnosis input signal circuit low input
P1596 Automatic transmission diagnosis input signal circuit high input
P1698 Engine torque control cut signal circuit low input
P1699 Engine torque control cut signal circuit high input
P1700 Throttle position sensor circuit malfunction for automatic transmission
P1701 Cruise control set signal circuit malfunction for automatic transmission
P1703 Low clutch timing control solenoid valve circuit malfunction
P1711 Engine torque control signal 1 circuit malfunction
P1712 Engine torque control signal 2 circuit malfunction
Pocon is offline   Reply With Quote
Old 01-15-2003, 06:04 PM   #13
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Jon
Well since you have reported the post for no good reason as at all
if the super mods see fit that it is not viable then so be it.
Why are you insisting on arguing, is this thread really bothering you? Dont click on it if it is. Why are you beings so apposed to a thread that is designed to help?
WRX ce lights and WRX codes have absolutly nothing to do with the rest of the subaru line, so please give it a rest.
Im politly asking you, if you have nothing to contribute to this thread that is pertinent and helpful, do not post here.
thanks
Jay
Old 01-15-2003, 07:26 PM   #14
Torch
Member#: 10172
I got this one today. I have a 02 WRX Auto. Mods are exhaust, Unichip, intercooler hoses, and CAI.
Does anyone know what this means?
Thanks,
Torch
Torch is offline   Reply With Quote
Old 01-15-2003, 09:03 PM   #15
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
There is a soleniod that is controled by the ecu that is activated, when circusmstances are met for evaporative emmissions to be vented back into the engine.
I dont think any of your mods would affect that function. Since you do have mods, and ya know how finicky subaru is, you may want to just clear the code and see if it comes back, if it does I would take it to the dealer and have it checked.
Jay
Old 01-15-2003, 09:48 PM   #16
Jon [in CT]
Member#: 2992
02 WRX Sedan
I don't know why Torch's search on that trouble code failed to uncover the WRX Check Engine Light Log thread. A quick scan of that thread will reveal at least 30 reports of this trouble code. In most cases, including mine, the problem was resolved by sending the ECU to Subaru HQ for a reflash.
Old 01-16-2003, 12:51 AM   #17
Impulsivegoat23
Member#: 25761
2002 2.5 RS
Alpine White
Code: P0031, Front oxygen (A/F) sensor heater circuit low input.
Year/Make Model: 2002 Impreza RS
Mileage: Approx. 7k
Fix: (general) Replace/Clean front O2 Sensor
(my case) Plug front O2 sensor back in
Mods: Ganzflow Intake, K&N Panel filter, Borla Header (wrapped), Apex'i N1 Exhaust.
Impulsivegoat23 is offline   Reply With Quote
Old 01-16-2003, 05:57 AM   #18
lakepop
Member#: 3851
2007 Outback Ltd.
Champagne Gold
Lightbulb
Well .....2 of the most common reasons for a non blinking CEL:
1. not tightening the gas cap
2. overfilling the tank by trying to round off the sale to some $.
Other common reasons are O2 sensor and knock sensor.
I personally had the overfill problem which I fixed with a reset.
OK...just my .02
lakepop is offline   Reply With Quote
Old 01-18-2003, 07:43 PM   #19
outback2.5HO
Member#: 15135
95 GF WRX
My wife's car:
'96 Outback Auto, 2.5, 155k miles, stock
PO 400 - EGR Flow Malfunction
Has had the code for quite some time. The CEL comes on about every 50-100 miles after clearing the code. Doesn't effect driveability at all.
outback2.5HO is offline   Reply With Quote
Old 01-21-2003, 10:16 AM   #20
ImprezedRS
Member#: 2771
2003 BMW Z4
I got a check engine light last night but I have yet to get it pulled, I will be doing that after work today. But since were on the topic of Check Engine lights. When you pull a code don't you have to connect the two green harnesses and two black harnesses under the dash? Is that what there used for? Someone told me this and I'm not sure. The reason I ask this is cause I have both the green harness and one black harness and to black wires dangling there which seemed to go in the other black harness? I noticed when I had my dash of the other day but I have never touched them before or have ever had any codes pulled off my car before? Do you think Subaru will fix this for free, even though I have 78k miles now? Its there fault, they forgot the harness.
I'm not sure yet of what the code is but I'm pretty sure whats causing it. I just installed 2 10" subs and 2 222W amps and I already had a light weight battery. The lights dim evertime the bass hits even when going 70 mph at 3k rpm. I don't think the ignition getting enough power to fire properly.
ImprezedRS is offline   Reply With Quote
Old 01-21-2003, 12:40 PM   #21
outback2.5HO
Member#: 15135
95 GF WRX
ImprezedRS,
Connecting those wires will do nothing but make your CEL flash. On the OBDI cars (pre95) that was part of the self diagnosing computer, not on the later cars though. On your car, to the left of the steering column, on the lower side of the dash, will be a little door-type thing that flips down, that's where the OBDII port (plug in) is.
Will Subaru fix it for free? Highly doubtful...your car has too many miles to be covered under warranty, and they sometimes make people pay to pull codes on warranty fixes. Many parts stores are pulling and clearing codes for free to get people in to buy parts, check that out first.
It is probably something to do with your amp and power supply situation. Might need an Optima battery and HD alternator to keep the juice flowing. If your voltage gets below 12v, your car WON'T run, so get get it fixed ASAP, or you might be using your AAA...
Old 01-21-2003, 01:13 PM   #22
ImprezedRS
Member#: 2771
2003 BMW Z4
Thanks outback2.5HO, yeah I doubt that Subaru would fix it, all I wanted was the black harness put back on, the one that is missing. As far as getting the code pulled I have a friend that works for a Toyota dealership that is going to do that tonight. I have never done the scanning before so I didn't know about those black and green connectors but I did know about the OBDII port though. Yeah if it is the system that is causing this then the system will go before I will change the battery. I will never put in a hevy Optima battery. I like my lightweight battery, 13.5 pds compared to the stock I think was about 38 pds. I saved as much weight as I would with a carbon fiber hood.
Well I will post the results tonight of what my code is.
Old 01-21-2003, 09:18 PM   #23
ImprezedRS
Member#: 2771
2003 BMW Z4
Code: P0500 Vehicle speed sensor malfunction &
2000 Impreza 2.5 Rs
Mileage: roughly 78k
Fix for problem: Havn't done it yet but need to check the wiring for my TCII and the reconections from removing the FieldsSFC-Hyper R. Its says if it is not throwing the P0720 Output speed sensor (vehicle speed sensor 2) circuit malfunction code and the speedo works to check the wring to make sure it has a 10ohm connection in the wiring from the ECU harness to the Gauge Cluster Harness. So I know it must be something in my wiring. I had him clear the codes and it has yet to throw the code again, so I tthink it was just a glitch. But I will be checking it again.
Also the OBDII reader said that the code was set off at 2250rpms and at 0mph . Thats funny since I was already in third speeding up to 60 when the Check Engine light came on.
Old 01-25-2003, 06:59 PM   #24
obyone
Member#: 16523
JDM Maxxpro
0107, & 0113
2000 Impreza RS
(mods=full header back exhaust, cobb intake)
Possible solutions= possible changing of MAP sensors
Actual solution = my MAP sensor wire came loose and just needed to be plugged in again.
below is a cut and paste from my original thread about this.
Dammit!...My car chrew a CEL light Sat. night on my way home.
I was stuck in traffic, when I saw an opening on the right lane. I gunned it and noticed the CEL when I was about 5000 or so RPM's. Then the car started giving me lip. Instead of idling like it's supposed to, it would rev up and then rev down like if it was following the beat of a ticking clock. My MR2 used to do that when it was low on coolant or was about to overheat, but the temp guage on the RS didnt' budge.
I took the car in today to have the CEL code pulled and I got a: 0107, and 0113 code.
I've included the pics of the print out so that, anyone who knows what that means, can tell me what happened
http://forums.nasioc.com/forums/show...hreadid=235121
obyone is offline   Reply With Quote
Old 01-26-2003, 06:15 AM   #25
Andrew Bacon
Member#: 2267
00RS
[quote]Originally posted by obyone
[b]0107, & 0113
2000 Impreza RS
[i]Dammit!...My car chrew a CEL light Sat. night on my way home.
I was stuck in traffic, when I saw an opening on the right lane. I gunned it and noticed the CEL when I was about 5000 or so RPM's. Then the car started giving me lip. Instead of idling like it's supposed to, it would rev up and then rev down like if it was following the beat of a ticking clock................
My MR2 ........................used to do that when it was low on coolant or was about to overheat......................didnt' budge.
How did [could] that happen?
The Subaru 360 Thread SIL01 Member's Car Gallery 29 09-19-2006 09:21 PM
Subaru impreza CEL thread dominiond Service & Maintenance 3 04-25-2004 01:00 AM
The Subaru Upscale Thread SUBE555 News & Rumors 46 10-18-2003 09:16 AM
Message Board Statistics All times are GMT -4. The time now is 06:00 AM.
