Welcome to the North American Subaru Impreza Owners Club Wednesday January 28, 2015
Old 04-15-2003, 08:29 PM   #76
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Maybe- but unless you want to just throw money away you still need to know exactly what code it was. As I said above there are multiple codes related to the 02 sensor, and having one (or more) doesn't necessarily mean that the sensor itself is bad. Sometimes a wiring problem or mixture issue can set these codes as well so changing the sensor blindly isn't a guarantee the CEL will go away.
Old 04-17-2003, 04:54 PM   #77
Turbotegra
Member#: 1389
2007 IS350
05 VFR 800 ABS
Just had my codes pulled today and I have:
P1510
P1512
P1514
P1516
P0420
Turbotegra is offline   Reply With Quote
Old 04-17-2003, 05:53 PM   #78
Susie's Suby
Member#: 21370
01 Impreza RS 2.5
Blew-ridge Pearl
Cool
FINALLY I got my code read. Had to drive a long way, but it was worth it. (Thanks, Autozone. )
P0420
The guy said "0-2 sensor, bank 1". Still don't know what that means, but will do a search now that I have a number to work with. To recap:
Stock 2001 RS 2.5 Sedan, manual trans.
Mileage is 71,000 (and rapidly increasing)
CEL went on about 5K ago. Solid, no blinks.
Code: P0420
Susanna <---gradually getting a clue
Susie's Suby is offline   Reply With Quote
Old 04-17-2003, 06:01 PM   #79
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
P0420 is the code for catalyst inefficiency. It does NOT indicate a bad 02 sensor. It is triggered by the readings from the rear 02 being out of spec because the catalytic converter is no longer doing its job.
The dealer should replace the cat under the emissions warranty, which is still in effect even at 71K.
Old 04-17-2003, 06:23 PM   #80
Susie's Suby
Member#: 21370
01 Impreza RS 2.5
Blew-ridge Pearl
Wink
Thanks, Mulder.
I read Tony's post about his Legacy throwing the P0420 also and will see what kind of plugs the Hub-meister put in--may very well have been those Bosch platinums.
I assume that these codes are universal? Does Pocon's long list of codes apply to all Suby WRX's, RS's, etc.?
Shanksh.
Susanna
Old 04-17-2003, 06:42 PM   #81
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Some of the codes apply to specific models/engines, others are common to all. The 0420 is pretty universal.
Old 04-20-2003, 09:27 AM   #82
Vinnie
Member#: 7869
2011 STi
TheUrbanRallyProject.com
Default P0102 Mass air flow sensor circuit low input
I recently pulled a: P0102 Mass air flow sensor circuit low input
02 WRX - 34K miles
Any Ideas what causes that. My dealership changed the MAF, but I still have the CEL.
Vinnie is offline   Reply With Quote
Old 04-21-2003, 03:42 PM   #83
epicurux
Member#: 3634
I got a flashing CEL a week ago that lasted for about 15 seconds.
I was cruising at about 80 MPH when this happened. Nothing seemed out of the ordinary when the CEL was flashing and it just went away 15 sec later and hasn't returned. I have the TurboXS stage one minus the exhaust for over 10K miles now with no problem. So I'm scratching my head on this one ...
epicurux is offline   Reply With Quote
Old 04-21-2003, 03:53 PM   #84
Vinnie
Member#: 7869
2011 STi
I am going to my dealer and getting my Denso's replaced with new stock plugs and wires. I am going to have them look at my coil packs also
Old 04-22-2003, 06:33 PM   #85
izzy
Member#: 1498
05 92X Aero
P0301 - cylinder 1 misfire
P0302 - cylinder 2 misfire
Car: RS 99 coupe (5sp)
Mileage: 48k
Mods: lightweight flywheel (Jun), clutch
For a few months now while on the freeway it would flash 4 times, then disappear. Recently it came on solid for a day, then disappeared the next day.
Help!!!
Could it be the lightweight flywheel (12.6lbs) causing the misfire readings? Doing a search shows up some WRXs getting misfire readings with lightweight f/w but i haven't heard of any RS having this problem.
izzy is offline   Reply With Quote
Old 04-22-2003, 11:41 PM   #86
stikboy
Member#: 6697
2011 WRX 5-door
Look-At-Me Red
Default misfires
PO302 - Misfire in Cylinder 2
PO304 - Misfire in Cylinder 4
26,900 on a '01 RS
Mods-Intake, Underdrive Pulley, Lightweight Flywheel (12.6), Borla Exhaust, Brospeed Exhaust.
I have had three run-in's with my CEL. None of which occured until I added the flywheel, header and exhaust (The cat is still stock).
The first was just a blinking light for a few seconds. A week later if came on steadily as a 302 and 304. A week and a half later it came on steadily and was just a 304. All three of these experiences happened within 3 mins of starting the car.
I have no clue what is causing this. Corporate Subie says that it is the header and also maybe the intake.
Any ideas of how to remedy this? My local Subie garage says that it really isn't all that bad since the car isn't running roughly. They think that the ECU is just too touchy. They also said that the ambient temp might have something to do with it. Personally, I would like to know how to fix it because I get an ulcer when the light is on.
Let me know.
stikboy
stikboy is offline   Reply With Quote
Old 04-23-2003, 04:31 PM   #87
sir_aspen_white
Member#: 32358
2000 2.5 RS
"Stormtrooper"
Code: Defintion P0440- EVAP EMMISSION CONTROL SYSTEM MALFUNCTION
Year/Make/Model MY00 Subaru Impreza 2.5RS Coupe
Mileage: 50 Grand
Fix for problem: Was a solid CEL. Gas cap wasn't tightened all the way. The CEL didn't go off immediately after putting gas- in fact, the CEL went off with about 1/10 of the gas left in the tank. Solution was to fill tank with gas, re-tighten the cap, go to the local parts store, borrow the OBDII scanner and confirm it is a P0440 CEL code, go home, take negative battery terminal out for 15mins, press on brake for a few seconds, re-connect battery, and voila! note: the 'erase' function on the OBDII scanner doesn't clear the CEL. You have to re-set the ECU by dissconnecting battery to get rid of the CEL...
I still don't understand why a CEL has to go off with a simple loose gas cap. Why couldn't they make the gas light go off instead? Kinda freaked me out when the "CHECK ENGINE" light goes out in the middle of the highway... Not to mention dealers, Pepboys who wants to charge $40, $79.99 (respectively) to tell you that you have a loose gas cap.
sir_aspen_white is offline   Reply With Quote
Old 04-23-2003, 04:46 PM   #88
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
When the gas cap is loose, the evap system test performed by the ECU will fail because the tank cannot be pressurized unless the cap is tight. As a result the code will set. The ECU has no way of knowing that the reason for the leak is a loose gas cap, it could just as well be a leak in a hose or other component. So there is no specific code for "loose gas cap", it's just that a loose cap will create an evap system leak.
If the CEL is indeed due to a loose cap and the cap is then tightened, there is no need for a reset. As long as the condition that caused the CEL to set has been corrected the CEL will go off by itself after three subsequent driving cycles without the problem being detected.
And the scanner should be able to clear the CEL, either they have a very cheap one or they just didn't want to do it for some reason. My scanner will do this and so will most other generic OBDII scanners.
Old 04-23-2003, 04:56 PM   #89
my2000rs
Member#: 20218
00 impreza rs
CEL Code-P0440 Evap emission control malfunction
Mileage-47000
Mods-Stock
this is the code i hate the most. Well i had this code about 9-12 times. I reset the ecu or clear the codes myself. It just keeps on appearing. It appeared again today.
When this first came on i took it to the mechanic and they said they can't find any problems with the car. Took it them about 3 times whenever the light came on
I took it to the dealer about 3 times and they charge alot to just take a look at it. They have changed the o2 censors and some hose and replace the gas cap.
Well, the car to run fine. No problems with anything, but the lights just comes on once in a while and i just clear the codes.
To: sir_aspen_white
Can you tell me if your CEL comes on again or is it fixed. I want to know how to get rid of this cel. I have reseted the ecu about 3 times before, but it just comes back on and now i just clear the
my2000rs is offline   Reply With Quote
Old 04-24-2003, 11:32 AM   #90
Susie's Suby
Member#: 21370
01 Impreza RS 2.5
Blew-ridge Pearl
Question
Well, our CEL has gone off & on about 3 times now over a period of about 3 months. It started about 10K ago. Has gone off for a few days and then come back on. Right now it's been off since Monday (natch, the day I finally called the Dealer to make an appointment...)
As reported in earlier post(s), it's a 2001 2.5 RS, 72k, code is P0420, or was last week when I had it read.
Anyone have a similar experience with the light going out for a few days & then reappearing?
Inquiring minds want to know!
Susie
Old 04-24-2003, 02:03 PM   #91
War2.5RS
Member#: 9962
2000 Impreza 2.5RS
Blue Ridge Pearl
Default is there a list???
My friend was telling me he printed out a complete list of CE codes for his WRX I don't know if the codes would be the same for my 2000 RS. Does anyone know of a list for us and if so how I can find it. I tried a search and came up empty handed (probably didn't type the right thing in the right place)
Wayne
War2.5RS is offline   Reply With Quote
Old 04-24-2003, 05:07 PM   #92
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Susie-
Don't worry about the CEL going off, as long as nobody does a reset the code will remain in memory in the ECU so the dealer will be able to find it. As I said previously you probably need a new cat and it may be marginal at this point so sometimes the 0420 will set and sometimes it will go away. Just take it to the dealer as per your appointment and it should get taken care of. Post back here afterward and let us know how it turned out.
Old 04-25-2003, 11:57 PM   #93
my2000rs
Member#: 20218
00 impreza rs
Default Re: is there a list???
Wayne
They are the same. Look in here
http://www.northursalia.com
Click on Tech Docs and informational pages. Scroll down and you'll find OBD II Trouble Diagnostic Codes
Old 04-26-2003, 03:27 PM   #94
War2.5RS
Member#: 9962
2000 Impreza 2.5RS
Blue Ridge Pearl
Thanks my2000rs I appreciate it.
Old 04-28-2003, 03:52 PM   #95
sir_aspen_white
Member#: 32358
2000 2.5 RS
"Stormtrooper"
MY200rs,
I am keeping my fingers crossed. The CEL hasn't gone off since I reset it a week ago. I have also put gas in it twice, so far, so good.
I hope it's just the cap (it was indeed loose when I checked it when the CEL came on). I drove it for two days and the CEL didn't dissapear.
I will keep you posted should anything happen.
Old 05-03-2003, 04:35 PM   #96
Hank
Member#: 14824
2004 Cobra
Code: P0546 - Exhaust Gas Temp. High (Bank 1)
Year/Make/Model: 2002 Subaru Impreza WRX
Mileage: 38,000
Fixes tried: I have reset the ECU, only to have it come back. I have full exhaust, hks headers, and a manual boost controller set to 16psi. The exhaust/headers were installed a year ago. The MBC was installed a few months ago. The CEL showed up a little after the MBC was installed. Not making any assumptions, but would 16psi from an MBC be causing all of this? The connections are tight on the exhaust and egt.
[UPDATED FIX: Put 2.2k, 0.5 watt resistor ($0.99 from Radio Shack) in the EGT connector plug, and left the EGT in the exhaust. CEL eliminated, and no side effects. Thanks Mulder]
Hank
http://www.rufridr.com/wrx.htm
Hank is offline   Reply With Quote
Old 05-03-2003, 04:49 PM   #97
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
This code (P0456) actually indicates a high circuit input from the EGT rather than high temp. High circuit input in this case means high resistance and is usually caused by the sensor having gone bad and becoming electrically open (infinite resistance) or open wiring between the sensor and ECU.
High resistance from the EGT sensor corresponds to low EGTs, lower resistance indicates higher EGTs. The sensor is a thermistor which lowers its resistance with increasing temperature.
Most likely your EGT sensor has gone bad and caused this code to set. If you have a catless uppipe you can safely remove it, replace it with a bolt and install a 2.2K resistor in its place to eliminate the CEL.
Old 05-05-2003, 02:07 AM   #98
DJ 9iron
Member#: 11349
2011 2013 Peterbilts
White, Black
Edit: I got the 463 and 420.
Would my cat be going this early?
I have 48k on my car and no mods except pulleys.
What could be the explanation for this?
DJ 9iron is offline   Reply With Quote
Old 06-02-2003, 07:49 PM   #99
Norris
Member#: 3146
00 Impreza TS
Blue Ridge Pearl
In regards to CEL #P1507 - Idle control system malfunction (fail-safe), I've had this one pop up 3 times (I suspect my current, yet to be checked CEL is the same thing).
Now, I called my dealer and they told me that Subaru of Canada (this may apply to the States too, I don't know for sure) has issued a goodwill warranty repair on the computer to rectify this as they've got lots of complaints about this code popping up. My car is currently out of warranty, but they tell me SOC is picking up the tab on this one.
I have a threading going at http://forums.nasioc.com/forums/...post3998098 about it and figured this info might apply to you too.
Hey, it's worth checking out, right?
Brian
Norris is offline   Reply With Quote
Old 06-09-2003, 09:50 PM   #100
Dr. J
Member#: 31009
2002 impreza wrx
my car has a p0463 and a p0106
P0106 Pressure sensor circuit range/performance problem (low input)
P0463 Fuel level sensor circuit high input
my fuel gauge does not work. what do i need to do to fix this
Dr. J is offline   Reply With Quote
The Subaru 360 Thread SIL01 Member's Car Gallery 29 09-19-2006 10:21 PM
Subaru impreza CEL thread dominiond Service & Maintenance 3 04-25-2004 02:00 AM
The Subaru Upscale Thread SUBE555 News & Rumors 46 10-18-2003 10:16 AM
