Old 04-25-2001, 08:59 AM   #1
edkwon
Member#: 453
2014 Audi S4 B8
Porsche Cayman GTS
Post Question about intake systems on MY99 RS (MAF system)
I know this topic has probably been beat to death ad nauseum, but i'll ask it again. Are there good aftermarket intakes for the MY98-99 RS that use the MAF and not the MAP sensor systems or will i need to get something like an APex AFC to supplement an intake for a 99 car to make the A/F balance work well?
Ed
edkwon is offline   Reply With Quote
Old 04-25-2001, 09:05 AM   #2
bratmantlz
Member#: 3231
88 626 Turbo
white
Thumbs up
not that i know of since you get rid of the plumbing that keeps it from tweaking the A/F slightly... i use a jcsports intake although i have been considering a rallispec... not sure yet
Brian
bratmantlz is offline   Reply With Quote
Old 04-25-2001, 09:33 AM   #3
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post
I just did the snorkusectomy which is about as far as you can go without pissing off the MAF. At least I *hope* it doesn't die on me.
Very annoying little thing.
YMMV, if you can find an intake that works without costing you $400 a pop for MAF sensors then all the more power to you!
remarcable is offline   Reply With Quote
Old 04-25-2001, 01:46 PM   #4
Eric Gagnon
Member#: 46
2001 Jetta 1.8T
Post
On the 99 if you replace the whole intake tract (both filter boxes) you will need a fuel controller of some sort. A Apex-i SAFC or Field SFC both will work fine.
I am running the Rallispec intake w/ Field fuel controller. If you do not use a fuel controller you will run lean at 5500rpms and up.
Intake will run you $350 and fuel controller will cost you approx: $300
Eric
Eric Gagnon is offline   Reply With Quote
Old 04-25-2001, 01:50 PM   #5
bratmantlz
Member#: 3231
88 626 Turbo
white
Post
my maf is fine i have had my intake for along time now i do have a S-AFC too
Brian
Old 04-25-2001, 05:18 PM   #6
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
The only time you need fuel adjustment is at WOT at 5500 rpm and up. At part throttle at the same rpm the MY99 will run rich.
So, if you don't want to install an AFC or FPR, install a piece of wood under the accelerator to keep from going WOT.
Revision is offline   Reply With Quote
Old 04-25-2001, 10:10 PM   #7
NA Impreza
Member#: 4267
1999 rs
white
Post
i have an air filter in my car without the bend that eliminates the second airbox but i took out the filter in the second airbox and replaced it with the air cleaner gasket (bought from ISR) this basically eliminates the 2nd airbox....so i was wondering if my car would run lean at WOT? thanks
NA Impreza is offline   Reply With Quote
Old 04-26-2001, 03:48 AM   #8
Narso
Member#: 1442
1999 2.5 RS
Cool
The ISR approach seems to be the best compromise. Replace the first air box with a cone filter (Kartboy makes a nice adapter) and keep the second air box intact (replacing the second filter with a gasket). I cobbled together an intake from Pipercross (filter) Kartboy (adapter) and ISR (pipes and MAF brace) about 7,000 miles ago. Nice improvement in power, no need for the AFC and retains the second air box to preserve low end torque. ISR has sold many my99 intakes and has not had a single MAF failure. Keep in mind that this is a compromise. If you want all-out power and have a good chunk of change to spend, then go with Rallispec and an AFC system. That, along with all wheel drive dyno tuning will cost you over, say, $750.
YMMV
Dan Z.
Narso is offline   Reply With Quote
Old 04-26-2001, 05:17 AM   #9
Revision
Member#: 242
MY05 PSM GGA !STOCK
Post
NA Impreza, unless you get something with higher flow (ie get rid of the 2nd air box,forced induction) don't worry.
Old 04-26-2001, 07:15 AM   #10
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
I have an ISR set up on mine...no problems so far, but I do carry a spare MAF in the trunk just in case...
STiShawn is offline   Reply With Quote
Old 04-27-2001, 12:37 AM   #11
edkwon
Member#: 453
2014 Audi S4 B8
Porsche Cayman GTS
Post
Ok, thanks for the suggestions guys.
Ed
quick question about sti rims on a rs bnr34rb26dett Newbies & FAQs 33 03-05-2009 07:16 AM
Injen CAI on MY99, checked Maf, still won't run weezil99RS Normally Aspirated Powertrain 17 05-09-2005 03:17 PM
question about intake and exhaust on 99 GC8 pearlblack2.5rs Normally Aspirated Powertrain 16 09-11-2002 11:20 PM
Question about Intake system wrx182 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-19-2001 10:44 AM
Rear brake pads on MY99 RS are dead, where do I get new ones ASAP! STiShawn Brakes, Steering & Suspension 6 05-15-2001 11:39 AM
