Old 01-10-2003, 12:37 AM   #1
Stubaru
Member#: 2073
07 Volvo S60R
Cthulhu Gray
Default Copper Gasket Questions
What are the downsides to copper head gaskets, is it true that they can alter compression ratios?
Thanks,
Stu
Stubaru is offline   Reply With Quote
Old 01-10-2003, 02:17 AM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Copper head gasket is best when used on an o-ringed block, i.e. in boosted cars
I'm told even a very thick one may only drop CR by 0.2 - 0.3
ImprezaRS dot com is offline   Reply With Quote
Old 01-10-2003, 11:29 AM   #3
Stubaru
Member#: 2073
07 Volvo S60R
Cthulhu Gray
Are the a good option for correcting constant head gasket issues. Like in the 98 EJ25 DOHC engines? Or are they strictly for boosted engines?
Stu
Old 01-10-2003, 01:20 PM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
they suck, they leak, they never seal....DO NOT USE THEM
Old 01-10-2003, 02:25 PM   #5
Stubaru
Member#: 2073
07 Volvo S60R
Cthulhu Gray
Hummm....you sound pretty sure. If they are indeed so bad why are they around?
Stu
Old 01-11-2003, 03:25 AM   #6
ImprezaRS dot com
over boosted again
Member#: 1458
you want an o-ringed block to use them to prevent leaks, sorry I didn't clarify that in my 1st post.
Old 01-11-2003, 03:38 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Stu
because they are for race use only, copper does not expand at the same rate as alumnium causing them to constantly leak, they are designed for use on vehicles where the heads are on and off constantly, you can re-use a copper gasket about 4 times depending on the original thickness of the material. I would NEVER and i mean NEVER use one ever again in a street driven vehicle, 4 copper head gaskets, 4 leakers.
jeremy
Old 01-11-2003, 09:09 AM   #8
Stubaru
Member#: 2073
07 Volvo S60R
Cthulhu Gray
Ok, that all makes sense to me, thanks fellas.
Stu
Crucial Racing copper gaskets dbrier Car Part Reviews 6 09-17-2008 10:04 PM
Copper Gasket Maker for the Hard-to-Find Single Port Gaskets. Hites Normally Aspirated Powertrain 7 09-06-2007 02:18 PM
Copper Gaskets vs. OEM Gaskets scoobydrew06 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-27-2007 04:59 PM
Crucial copper gasket and gasket spray questions athakur999 Newbies & FAQs 4 12-23-2005 01:04 AM
Copper Gaskets Stubaru Normally Aspirated Powertrain 13 06-28-2004 08:20 AM
