Old 05-08-2001, 09:03 AM   #1
ImprezedRS
Member#: 2771
2003 BMW Z4
Post Reason for Engine Knocking!
Well just got it back from the dealership and they said that the knocking noise was from a noisy flywheel. Well where is this flywheel located, i didn't think autos had flywheels, any body else have this problem?
ImprezedRS is offline   Reply With Quote
Old 05-08-2001, 09:04 AM   #2
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
Old 05-08-2001, 10:57 AM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
automatics do not have a flywheel... they have a thin, light flexplate that is bolted to the torque converter.
at low rpm the torque converter freewheels in the ATF and achieves the same purpose as a flywheel, keeping the engine spinning at a relatively constant speed even though it is accelerated abruptly each time a cylinder fires.
ColinL is offline   Reply With Quote
Old 05-08-2001, 11:01 AM   #4
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
Then what is this flywheel they are rplacing then? Is it in the engine or something?
Old 05-09-2001, 06:14 AM   #5
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
bump
Old 05-09-2001, 03:21 PM   #6
mhj
Member#: 3057
Post
The big gear like thing(the teeth are for the starter to turn it) that is bolted to your torque converter is still called a flywheel, i guess since it resembles the flywheels in manual transmissions.
mhj is offline   Reply With Quote
G35 engine Knock vs WRX STi engine Knock... BBBsti LTD General Community 6 03-21-2007 01:40 AM
Weird Knock noise, dont think its engine knock mlotek Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-14-2006 09:12 PM
Main reasons for engine failure cr125r General Community 15 05-13-2006 09:50 AM
Tuners: Reasons for knocking west_minist Engine Management & Tuning 22 12-31-2005 08:29 AM
How much is reasonable for a timing belt job for the 2.2 engine. Dealer Xing Tri-State Area Forum 5 12-09-2002 08:09 PM
