Old 05-08-2001, 04:34 PM   #1
dandbest
Member#: 1885
2015 Evo
Post
Just follow the spark plug wires... they all end on the coil.
Danny
dandbest is offline   Reply With Quote
Old 05-08-2001, 04:55 PM   #2
r1racing
Member#: 6333
Post
Which one is the "ignition -" wire?
bob
r1racing is offline   Reply With Quote
Old 05-08-2001, 05:13 PM   #3
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Post
The 4 black wires that run, 2 each, from the holes in the large metal covers on each side of the engine? Isn't this in the owner's manual?
Are you asking what ignition wires are?
Ben
bsquare is offline   Reply With Quote
Old 05-08-2001, 05:31 PM   #4
tulit
Member#: 338
09 STi
Post
I think he's asking whats the negative input signal for the ignition pack (presumably for installing a aftermarket tach?)
tulit is offline   Reply With Quote
Old 05-09-2001, 12:03 AM   #5
r1racing
Member#: 6333
Post where is the ignition coil?
can anyone tell me? thanks...
bob
Old 05-09-2001, 12:25 AM   #6
jeffg
Member#: 2958
2001 WRX (GC8)
Post
The subaru boxxer engine does not have a "coil" in a conventional sense. They use a coil "pack" If you look at your engine bay.. right on top of the intake manifold there is a little black thing. Your spark plug wires connect to this. That is the coil pack. It uses a signal from the ECU to trigger each spark.
jeffg is offline   Reply With Quote
What/where is the ignition fuse/relay for 05 sti? snowcrzy Electrical & Lighting 4 07-13-2009 04:26 PM
where is the ignition coil? greenleg88 Legacy Forum 3 11-01-2008 04:13 PM
Noob question: Where is the ignition harness gthing Electrical & Lighting 1 05-12-2007 07:31 PM
No Spark. Where is the igniter? 2002 WRX codered Electrical & Lighting 1 06-05-2005 08:00 PM
('93-'01) Where is our ignition coil? BrysImpreza Impreza Forum 1 08-17-2001 11:27 AM
