Old 05-08-2001, 06:50 PM   #1
Bohanan
Member#: 722
I'M DEBT FREE!!
04 WRX Wagon/01 Odyssey
Question Rough running engine the result of a custom exhaust?
I need some help from all the experts out there. I've got a '99 RS that is basically stock except for the Amsoil filter in the stock air box, second air box gasket, and a custom 2.25" cat-back exhaust with a Flowmaster Deltaflow 50 series muffler (p/n 942451). The car has 37,000 miles, but the exhaust has only been on for a few weeks.
I've started noticing a funky problem a couple of weekends ago. I drove from Houston to College Station (about 2 hours) and had the cruise set at 70-80 at various stretches. The problem also occured again this weekend, and today it was more pronounced.
The engine seems to run rough or hesitate. It almost acted like it wanted to come out of cruise. I turned cruise off and held the speed steady at various speeds for several minutes at a time. 65, 70, 75, 80, it didn't seem to matter. The car would be fine then act up. I don't want to call it a hiccup because the car doesn't backfire. It's also not thrown a check engine light yet. I've watched the rpms while this happens and don't notice a major fluctuation.
Has anyone had a problem like this after installing a 2.25" cat-back system? I'm thinking of taking the car into the dealer and see what they can find. Do you think the muffler could be having an adverse affect on the back pressure to cause this? I didn't have this problem back when I had the Rallispec 2.25" system with the dual tip muffler, so this is kind of a surprise.
Any ideas, or suggestions would be appreciated. Thanks.
Adam
[This message has been edited by Bohanan (edited May 08, 2001).]
Bohanan is offline   Reply With Quote
Old 05-08-2001, 07:16 PM   #2
kaos200
Member#: 2692
Post
how far back is the custom exhaust?
does it affect o2 sensor placement?
kaos200 is online now   Reply With Quote
Old 05-08-2001, 07:45 PM   #3
Skylab
Member#: 4263
Arrow
Your car has a bad 02 sensor. I got mine replaced (on a minivan) and it cured the problem.
My van had the same problem your describing...the car wouldn't cruise reliably at any speed above 55 mph. Half throttle it would start to stutter and hiccup and exhaust would pop. WOT there was no problem though.
Anyways, got the O2 sensore replaced and problem solved for $165.
Skylab™
*hope that helps*
Skylab is offline   Reply With Quote
Old 05-09-2001, 06:06 AM   #4
Bohanan @ work
Member#: 836
Post
kaos, it's a cat-back. The new pipe was welded to the original flange. It doesn't affect the O2 sensor placement.
Thanks Skylab. I went ahead and dropped the car off at the dealer. Hopefully they'll come back and say it's something simple like that. But, the problem is also showing at full throttle too.
Adam
Bohanan @ work is offline   Reply With Quote
Old 05-09-2001, 06:33 AM   #5
skeletor25rs
Member#: 1844
1970 Scout
Gold, Tan, Rust, Primer
Post
Thats what mine was doing when the coil-pack went bad. One of my plugs was arching to the engine block. It got worse and worse, until on the way to West Houston it would only go about 50mph.
skeletor25rs is offline   Reply With Quote
Old 05-09-2001, 09:50 AM   #6
Bohanan @ work
Member#: 836
Post
Just received word from the dealer. The coil pack went out and managed to fry the number 2 spark plug wire. He said they could see the sparks arcing across the wire while it was running. Hopefully I should have the car back today.
Thanks for all the input. I had a list going of everyone's ideas. I appreciate it.
Adam
Old 05-09-2001, 11:19 AM   #7
KoKo
Guest
Member#:
Post
Bohannan, Ever seen me on the road in College Station, or on the way there from houston??? I'm there almost every weekend visiting my girlfriend. I drive a silver '00 RS with Apex N1. What were you doing in College Station anyway? That place is the pits.
Old 05-09-2001, 08:20 PM   #8
NateDogg
Member#: 6467
1999 Impreza 2.5 RS
Post
quick question.....what did you do with your rallispec exhaust, if you still have it im willing to buy it
NateDogg is offline   Reply With Quote
Old 05-10-2001, 12:24 AM   #9
Bohanan @ work
Member#: 836
Post
Hey Ko Ko! I may have. I was up there for an autocross out at the Riverside Annex. I don't get up there much, except for the occasional race.
I do go out to Conroe quite a few times a month. Of course, I live in Spring, so it's not like a major drive any way. I'll keep my eyes open for you. I have a white '99 with Speedline wheels. Later!
Adam
Old 05-10-2001, 05:22 AM   #10
Bohanan @ work
Member#: 836
Post
Sorry, but I've since sold it to Aubrey (skeletor25rs). The resonance inside the car got so bad on extended road trips that I had to get rid of it. It was pretty sweet looking though. Polished S.S. resonator and dual tip muffler, S.S. piping, excellent workmanship. I believe it was the first dual tip they put together.
Adam
The start of my custom exhaust CenCali07sti Factory 2.5L Turbo Powertrain 107 06-17-2008 10:36 AM
Rough running engine from 4500 RPM. lowsize Factory 2.0L Turbo Powertrain 2 05-04-2008 12:15 PM
rough vibration under the center of the car HELP All4bSpinnin Transmission (AT/MT) & Driveline 1 06-17-2006 10:04 PM
Engine knock and rough running engine Chi_San Legacy Forum 1 07-23-2004 11:57 AM
Result of GReddy EVO exhaust for MY02 2.5RS windfactory Normally Aspirated Powertrain 6 05-11-2002 11:44 AM
Message Board Statistics All times are GMT -4. The time now is 04:07 PM.
