Old 01-10-2003, 08:04 PM   #1
Ultralight
Member#: 29366
1990 Miata
white & 2003 sonic yellow
Default How does the WRX fuel pickup behave?
What is the minimum fuel needed in the tank to prevent starvation in long sweepers? How about in rapid transitions such as slaloms?
Ultralight is offline   Reply With Quote
Old 01-10-2003, 09:41 PM   #2
Dussander
Member#: 4798
2002 #61 STX or F125
I ran 26 AutoX events last season. I only had fuel starvation once after I had been running a couple runs with the Empty light on. It was always on a tight left turn.
So, I'll guess that most everyone will be safe as long as they keep off the light.
Dussander is offline   Reply With Quote
Old 01-10-2003, 11:34 PM   #3
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I will second and say that as long as the light isn't on you won't get starvation. It has a higher threshold than alot of other cars.
Old 01-10-2003, 11:49 PM   #4
KC
Member#: 442
16 SS
00 S2000
Nationals... 2 gallons for 3 runs. No Starvation.
If you can get it where the light just comes on for 3-4 60 second runs, you'll be fine. It's simply amazing if you ask me.
--kC
KC is offline   Reply With Quote
Old 01-11-2003, 05:47 PM   #5
Ultralight
Member#: 29366
1990 Miata
Thanks for sharing the information. I know we would have figured it out after a few events but it helps to not start with so many unknowns. My wife and I are going to campaign the WRX heavily (DS) this year and go to nationals if we don't embarrass ourselves at the divisionals and national tour events. Glad to hear the WRX does well will little fuel. I thought I was spoiled by the Miata, which due to an unusual shaped tank will autox with about a quart of gas.
Old 01-11-2003, 06:14 PM   #6
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
I know a lot of locals in Houston that had problems with anything less than 1/4 tank. I personally had many runs close to E or with the light on and no issues. One thing to take into account was the regular track has many undulations for water drainage which may lead to more starvation problems than one would normally expect.
Orion is offline   Reply With Quote
Old 01-12-2003, 12:01 PM   #7
GoodFinder
Member#: 8943
2006 MINI + Corvette
Both Blue
I'm jealous of all you folks who are not experiencing fuel starvation at low levels in the gas tank! I consistently encounter this problem if I'm taking a long right hand sweeper aggressively and I've got less than 1/3 to 1/4 tank of gas. It's such a bother and concern that I'm gonna do a fuel reservoir ("surge tank") setup sometime soon. But, maybe I need to get the shop to take another look at the upgraded fuel pump installation in the tank.
GoodFinder
GoodFinder is offline   Reply With Quote
Old 01-12-2003, 12:08 PM   #8
KC
Member#: 442
16 SS
00 S2000
GoodFinder
Drive smoother instead of jerking the wheel. Hehe.
--kC
Old 01-12-2003, 12:43 PM   #9
enduroshark
Member#: 24058
I've had fuel pickup problems with a gallon left in the tank.
enduroshark is offline   Reply With Quote
Old 01-12-2003, 12:54 PM   #10
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
I usually start an autox with the light. Never has a problem.
trhoppe is offline   Reply With Quote
Old 01-12-2003, 01:52 PM   #11
GoodFinder
Member#: 8943
Both Blue
--kC
Keith,
Thanks for the advice
But, seriously, this is good to know, that it's not really an issue with the WRX. That gets me going on the right track (pun intended) since my issues may be more to do with the Walbro GSS341 pump and/or the installation particulars
GoodFinder
Old 01-12-2003, 03:42 PM   #12
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
GoodFinder,
it DEFINITELY has to do with your fuel pump. jmott couldn't run at AutoX's with less 1/2 tank to start.
Orion
how does the wrx/sti 2.5 engine hold up? idklol Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 04-02-2010 05:37 PM
how does the WRX RA differ from just a WRX? suberdave Subaru Conversions 12 03-12-2008 09:40 AM
How does the WRX (All versions) compare to M Roadster (Z3) & Mazdaspeed Miata? wormser General Community 29 08-25-2006 08:00 PM
2004 USDM STi fuel pump and WRX fuel pickup screen: $60 shipped StiDreams Private 'For Sale' Classifieds 4 05-03-2004 12:28 PM
How does the WRX "instantly" react to IC changes? makofoto Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-02-2003 11:13 AM
