Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 01-10-2003, 08:47 PM   #1
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
Default Will my trans swap put me automatically in Street Mod?
I current have a MY00 RS with a 4EAT. This spring I plan on converting it to a 5 speed that I have from a 99 RS. Will this put me in street mod because it is a trans swap, even though it is the same as a stock MY00 RS?
-Wes
RebelINS is offline   Reply With Quote
Old 01-10-2003, 09:08 PM   #2
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Put the 5 speed in it and no one ever know if you don't say a anything. If you ran in STS, that would come under the update/backdate rules.
Patrick L is offline   Reply With Quote
Old 07-19-2013, 11:05 AM   #3
Leafy
Member#: 330625
2006 WRX
I think this is just a package conversion assuming the MY99 trans is the same as the MY00. Just be sure to follow the factory procedures. And use stock/stock replacement parts where anywhere you arent allowed modification for your class. IE in ST you can do non-stock trans mounts and shifting linkages.
Leafy is offline   Reply With Quote
Old 07-20-2013, 10:37 AM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
THIS:
Old 07-22-2013, 12:28 PM   #5
Boxologist
Member#: 21118
This isn't update/backdate. This a factory option if you are using the oem stuff, same part #s, so good to go in Stock. Just don't toss in a tranny w/ the wrong ratios or the cable clutch setup.
Just to let u know, 2nd gear in my L goes to 60mph.
Boxologist is offline   Reply With Quote
Old 07-22-2013, 05:16 PM   #6
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Why did you bump and try answering a question that is 10 years old?
BeBop86 is offline   Reply With Quote
Old 07-22-2013, 05:24 PM   #7
Leafy
Member#: 330625
2006 WRX
It showed in my new threads list. Forum glitch?
Will my trans stand up to... Gocasen Transmission (AT/MT) & Driveline 1 01-20-2008 06:57 PM
My supervisor has put me in a compromising position BGPunk2001 Off-Topic 16 01-18-2008 03:16 PM
will WRX trans swap for STI? thejoka Transmission (AT/MT) & Driveline 2 11-28-2006 09:52 PM
How long will my motor swap take! HalfBaked Off-Topic 8 12-02-2004 11:30 AM
Well my doc is putting me on clonazepam. entropy111 Off-Topic 25 12-18-2002 12:14 AM
