Old 01-11-2003, 04:01 PM   #1
Davenow
Member#: 23676
Default NICE! STX guys do NOT have to sweat the STI or EVO8
Both have made the STX exclusion list.
Old 01-11-2003, 04:01 PM   #2
Davenow
Member#: 23676
then again, I guess I do, since I cant see where else, other than SM they will go.
Old 01-11-2003, 04:24 PM   #3
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
I figured neither would not be allow in STX. Both would take the class. I mean, a STI with 300hp, with a good set of coilovers and it's controlable center diff and with the potential of having more HP with STX rules, would mop up the class.
It will not be legal Divisionally or Nationally for stock class until 2004, because it's a 2004 model. Unless, they do the same thing they did you the 2002 WRX and allow it in one year early. This is the same for all other classes, which it will have in SP, P but not sure about SM. As for local events. That is up to the local region.
Pat L.
Patrick L is offline   Reply With Quote
Old 01-11-2003, 05:29 PM   #4
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I never really thought about the STi not being in a stock class for this year, but it's possible. It's not going to be available until well into the 03 season, like late May or early June. Probably just throw it in ASP which I think they did with the 03 Cobra. The WRX was at least available in March of 01 before things really got started. The STi is above the engine limit anyways, but I'm glad the EVO is excluded as well since it would own the class without much problem in stock form.
The STi isn't a bad car for SM in stock form. Imagine it with a bigger turbo and TMIC, which is maybe $2k in expense and some nice wide tires.
Old 01-12-2003, 02:05 AM   #5
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
No. My car with a STI drive train and 275 R-compound tires would own the planet.
How do I check timing belt for EJ25D? Do I have to remove the cover, or better way? kirbykirb Legacy Forum 2 11-05-2009 01:15 AM
do not try to d0rift0 the carts at sams culb or homedepot hotshot172 Off-Topic 23 04-11-2006 09:02 AM
Do I have to remove the IC all the way to install Oil Temp in Front Gallery? Irishman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 10-11-2004 11:27 AM
Do I have to trim the STI V2 lip because of my FMIC? 516_WRX_V2 Interior & Exterior Modification 3 08-05-2003 09:50 AM
Do I have to remove the IC to get the turbo heat shield off? Snowphun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-31-2002 02:38 AM
