Old 01-11-2003, 09:40 PM   #1
RawCode
Member#: 3115
2002 Impreza 2.5RS
Talking Auto peoples: Ever pop in the FWD fuse?
Well I was bored and decided to pop in the FWD fuse to see what happened. Well I live in Alaska and Snow and ICe are the norm..
Holy lack of Traction Batman! I could hardly get away from a light with Studded Hakka's. Man that is when I realized that 50% of the performace of the car in bad conditions is AWD.
I guess I just forgot how much I hated the one wheel peel.
RawCode
RawCode is offline   Reply With Quote
Old 01-13-2003, 01:54 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I tried before, the only thing it was good for was to sit and spin the tires honda style.
Old 01-13-2003, 03:18 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Try driving a FWD subie regularly
Legacy777 is offline   Reply With Quote
Old 01-14-2003, 10:59 AM   #4
RossWRX
Member#: 19808
2005 WRX STI
Obsidian Black Pearl
coule we use this to dyno our cars on a 2 wheel dyno?
Just put the transmission in "2" and do a run?
RossWRX is offline   Reply With Quote
Old 01-14-2003, 01:38 PM   #5
Legacy777
Member#: 4800
I have a friend that has done this.......it's probably not the best idea.....
However if you have a WRX... I don't think it will work regardless.....because it uses an actual center diff.
The older trannies used a rear extension housing and rear clutch pack.
Josh
Old 01-14-2003, 01:45 PM   #6
Siper2
Member#: 1134
2007 BMW 328xi wagon
Too bad it's not a RWD fuse instead.
AutoX, here I come!
Siper2 is offline   Reply With Quote
Old 01-14-2003, 01:48 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
Even with the FWD fuse inserted the Rear wills STILL MUST TURN!!! The car may be in FWD mode but you still have contact. The way to dyno pre WRX-VDC cars is to float the rear wheels and stick the front on the dyno.
Old 01-14-2003, 06:40 PM   #8
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
i hear ya buddy!
scoobyimprza is offline   Reply With Quote
Old 01-14-2003, 10:08 PM   #9
SubaruWRC
Member#: 11063
2001 Impreza 2.5 RS
and bye bye Turtle :(
what size fuse do you put in
Jiffycool:
SubaruWRC is offline   Reply With Quote
Old 01-15-2003, 09:25 PM   #10
SubaruWRC
Member#: 11063
2001 Impreza 2.5 RS
Old 01-15-2003, 09:41 PM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
15?
Hmm, while looking in the service manual it states the FWD fuse is
"also used to adapt the vehicle to FWD tester roller."
Hmm, sounds like 2wd dyno to me.
Old 01-15-2003, 10:32 PM   #12
Legacy777
Member#: 4800
Fuse....use whatever you want.....there's extras in the fuse box...any one of those would work.
Ciper......I think you'd be alright running it on a 2WD with the fuse in. It basically disables fluid pressure going to the rear clutch pack. I'm assuming the duty solenoid will stay open and all the fluid will just bypass the clutches........I see no harm that can be done.....assuming it works like that.
Old 01-15-2003, 10:52 PM   #13
Bolster
Member#: 22290
2002 WRB WRX Wagon
COOL! I'm gonna try it on my wife's legacy.
Bolster is offline   Reply With Quote
Old 01-16-2003, 08:41 AM   #14
Legacy777
Member#: 4800
Just to re-itterate......what I described is for the pre VTD auto tranny cars.
I'm not sure if the VTD trannys have a FWD fuse holder or not......so I can't comment whether putting the FWD fuse holder in and goin on the dyno would be a good thing.
But it should be fine for the pre VTD auto trannys.
Old 01-16-2003, 09:50 AM   #15
Bolster
Member#: 22290
2002 WRB WRX Wagon
Well, my wife's is a '96, so that may not work out.
Old 01-16-2003, 10:18 AM   #16
Legacy777
Member#: 4800
It'll work. The VTD first came out in the H6 models & the WRX. Everything before that had the same auto tranny setup with rear extension housing.
Josh
Old 01-16-2003, 10:45 AM   #17
Bolster
Member#: 22290
2002 WRB WRX Wagon
Well, I just learned something new. This setup (non-vtd) runs full time AWD by using an electronically controlled clutch pack, right? If so, and this may be SO yesterday's news, couldn't you rig up a controller that lets you setup the bias, a la, DCCD? -Bolster
Old 01-16-2003, 12:36 PM   #18
DaveM
Member#: 4503
2012 Imp Sport Ltd
Camellia Red
See Torquemada: Development / Status Thread
DaveM is offline   Reply With Quote
Old 01-16-2003, 02:18 PM   #19
Legacy777
Member#: 4800
Yup.....actually you can rig a switch inline with the duty c solenoid.....I think if you short the circuit....it will default to full line pressure, which gives you 50/50 torque split.
The ideal way would be to take measurements on the duty c solenoid when the gear selector is in the "1" position, because the trans is supposed to be 50/50 split at that time. Once you get your measurements.....mimic that same signal some how to get your torque split.....aka the torquemada.
If you need help visualizing the whole thing, take a look at these.
http://www.main.experiencetherave.co...er_system1.jpg
http://www.main.experiencetherave.co...er_system2.jpg
http://www.main.experiencetherave.co...er_system3.jpg
Josh
Stupid Question: Can you use the FWD fuse to drive the car every day? Koss Normally Aspirated Powertrain 21 12-11-2012 01:02 AM
Clunk/Pop in the rear after Tein install trhoppe Brakes, Steering & Suspension 19 05-27-2003 11:56 AM
is my car supposed to snap crackle and pop in the winter? WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-31-2001 06:59 PM
Does it ever snow in the Portland area? Turbo4me North West Impreza Club Forum -- NWIC 3 01-09-2001 09:39 AM
Less popping in the rain... wtf? HRE | giulio Technical Forum Archive 22 07-27-2000 06:08 AM
