Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Old 04-23-2001, 10:59 PM   #1
E'scubi
Member#: 4984
Post what is that chirping on the rally cars?
I just got done watching the Swedish Rally, and my curiousity was bugging me. So does anyone one know what that chirping noise is that all of the rally cars make?
E'scubi is offline   Reply With Quote
Old 04-23-2001, 11:11 PM   #2
brandonl
Member#: 3341
04 STi
track rat black
Post
the chirps are the BOV... the popping (small backfires) is the anti-lag system.
brandonl is offline   Reply With Quote
Old 04-23-2001, 11:17 PM   #3
SubaFast1
Member#: 5787
Wink
I think you are talking about the anti-lag systems that keep the turbo spooled up during shifts...
Basically an amount of fuel is allowed to pass through the engine off throttle so that when it hits the red-hot exhaust it combusts flowing more gas and therefore spooling the turbo very quickly! Then you have instantaneous boost when back on throttle...
BUT the downside is turbo repair/replacement very often and very harsh on other parts as well!
That is the "jist" of it, there is more info available online about it though...
SubaFast1 is offline   Reply With Quote
Old 04-23-2001, 11:19 PM   #4
SubaFast1
Member#: 5787
Post
Brandon is right (I forgot you said chirping) the chirps are probably the blow off valves
but the flames and gun-like repititions are the ALS kicking in...
[This message has been edited by SubaFast (edited April 23, 2001).]
Old 04-23-2001, 11:36 PM   #5
popnGEAR
Member#: 4616
1999 2.5RS
RBP
Post
speaking of rally sweden, burns didn't look so friendly when he was yelling at the spectators to help, hehe.
popnGEAR is offline   Reply With Quote
Old 04-24-2001, 12:07 AM   #6
Buck-O
Guest
Member#:
Post
Why does everyone think the chirping is a BOV...if you have a BOV on a car with antilag, they preaty much cancel each other out.
Its the wastegate, not the BOV.
Not untill someone shows me a technical drawing proving otherwise.
Old 04-24-2001, 06:42 AM   #7
Damon
Member#: 2902
89 gmc work truck
08 jeep rubicon unlimited
Post
well i woundnt be to happy either. i was watcing the last race they showed, (was it monte carlo?) and when the former subie driver that now drives the Focus RS (cant remember his name) broke down on a turn, about 3 people came down to "help". that would bother me too. some of the fans over there are pure itiots. they should stay OUT OF THE ROAD and on the side where they belong. (end vent )
Damon is offline   Reply With Quote
Old 04-24-2001, 07:41 AM   #8
WRXRob
Member#: 3087
Post
Well, on a street car, that chirping noise occurs when the blow off valve fails. It is caused by compressor surge, in that when the throttle plate is closed under boost, the pressurized air hits the plate, then the wave ricochets back to the turbine and then back to the t-body, etc. creating pretty much the exact same chirping noise. The noise itself comes from the pressure wave hitting the turbine wheel. You can destroy a turbo this way in not too much time.
Not sure if this is what is going on in the rally car.
WRXRob is offline   Reply With Quote
Old 04-24-2001, 08:04 AM   #9
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Post
Thanks for the clarification on that subject I have been wondering what that sound is as well.
As for Burns yelling at the fans I think that he was just extremely frustrated which you could see by the expression on his face. At least there was a Subie in the top six.
Later Z
Zephyr is offline   Reply With Quote
Old 04-24-2001, 09:09 AM   #10
jeffg
Member#: 2958
2001 WRX (GC8)
Post
You guys are all wrong...
The chirping sound is the back-up squirel drive system.
I think it is the mechanical thingy that regulates boost pressure when the throttle is closed. Is this a wastegate or a BOV?
jeffg is offline   Reply With Quote
Old 04-24-2001, 09:15 AM   #11
UCI_Scott
Member#: 5088
Post
Chirping = Blow Off Valve
UCI_Scott is offline   Reply With Quote
Old 04-24-2001, 09:29 AM   #12
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
Post
like WRXRob said, the chirping is due to a compressor surge. Typically race cars do not run a BOV. It's just another place to leak boost and another part to break.
If you are feeling really stupid, and have a MBC installed, you can re-create that chirping by building mad boost with the MBC. It's not that good on the turbo, but sounds really cool.
ChrisW is offline   Reply With Quote
Old 04-24-2001, 09:32 AM   #13
T-WReX 2.5RS
Member#: 5105
2000 Impreza
Post
Suspension is what is causing it
T-WReX 2.5RS is offline   Reply With Quote
Old 04-24-2001, 09:39 AM   #14
tomrichardson
Member#: 2672
1973 Porsche 914
Porsche Red
Post
I don't know the answer myself... but I don't think any of you know what it really is.
tomrichardson is offline   Reply With Quote
Old 04-24-2001, 09:45 AM   #15
UCI_Scott
Member#: 5088
Post
Engine RPM up, car in gear, lift throttle.
Turbo still making pressure but with throttle closed where does the pressure go?
Blow Off Valve.
Leak? Hardly!
--scott
Old 04-24-2001, 10:45 AM   #16
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post
I usually hear a couple different chirping sounds, or sounds that could be described as chirping.
Hardened tranny/suspension/engine mounts? I know those things are noisy as hell on bumpy roads if you don't lube them up.
remarcable is offline   Reply With Quote
Old 04-24-2001, 10:49 AM   #17
brandonl
Member#: 3341
04 STi
track rat black
Post
Its the BOV. All grp WRC, A and N cars use them.
Old 04-24-2001, 11:02 AM   #18
SubEd
Member#: 717
Post
Geez, I can't believe all the misinformation that is being presented here!
The chirping you hear is the cruise control manifold when it is being turned off so the driver can take manual control of the throttle. That's all it is! And I know, so don't bother arguing!!
SubEd is offline   Reply With Quote
Old 04-24-2001, 11:20 AM   #19
lobstertail
Member#: 729
98 Impreza RS
Red
Question
Is this chirping sound the really high pitched whine that you hear inside the cabin?
I noticed that during the outside shots you can't hear the highpitched whine, but inside the cabin the whine is very prominent. I'm wondering what that whine is. Is it the same chirping sound you describe or something different? I'd like to know.
lobstertail is offline   Reply With Quote
Old 04-24-2001, 11:38 AM   #20
JaiMak
Top Scoob 004
Member#: 697
1999 Top Scoob #4
Satin White Pearl
Post
Could it be the chattering of the differentials through the turn?
JaiMak is offline   Reply With Quote
Old 04-24-2001, 11:42 AM   #21
Prog
Member#: 1473
2005 Legacy GT 5MT
Satin White Pearl
Post
the whine inside the car is just the turbo and the high strung engines remember that their gears are very short so it revs extremely fast
the chirp sound AFAIK is the blowoff valve going off mixed with the anti lag system, the ALS gives off a series of backfire explosions, coupled with the bov's normal psheeeeeeshhh sound ...
you can hear it all well here, check out how the "chirp" sound goes off when they let off the throttle, so basically it goes off when the antilag and bov go off...
http://www.pr-roadracing.com/22B.mp3
[This message has been edited by ProgWRX (edited April 24, 2001).]
Prog is offline   Reply With Quote
Old 04-24-2001, 11:47 AM   #22
UCI_Scott
Member#: 5088
Post
The sound to which the original poster is referring sounds like rabid squirrels on helium. A whole bunch of them. Always at the entrance to corners/lift throttle. Sort of sounds like tires slightly breaking traction but the pitch and rhythm is too consistant for that. chi-chi-chi-chi-chi-chi-chi-chi
<FONT SIZE="+3">It is the Blow Off Valve</FONT>
Old 04-24-2001, 11:47 AM   #23
DammitBevis
Member#: 3569
2006 STi
AW
Post
Sounds like suspension squeaks to me.
DammitBevis is offline   Reply With Quote
Old 04-24-2001, 11:58 AM   #24
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Even more specific, it is the HKS Super-Sequential blow-off valve.
Old 04-24-2001, 02:06 PM   #25
Buck-O
Guest
Member#:
Post
THANK YOU ANDREW!!!!
Someone from the rallying comunity that KNOWS what he is talking about.
Think about it people, what does a BOV do? Regulat boost presure, and bleed excess boost presure.
What does anti-lag do? Keeps the turbo spooled during throttle lifts, reducing turbo lag, and keeping boost levels up.
Now, why would you run a system to keep boost presure up, only to bleed it all away into the atmosphere and have it do NOTHING for you?
Again Andrew i thank you for providing your profesional oppinion.
As for the high pirched whining sound in the cockpit. Thats from the gear box. The gear box is all straight cut gears, and are cut to VERY close tolerances, so the the transmission is VERY tight. As the gears spin, becuse they are so tight, they make a whining sound.
What is that thing on the 2009 Forester hood? EJ25RUN General Community 52 11-26-2011 07:38 PM
What is that Chirping Noise from Front engine on a 2007 Wrx Sti bluesti888 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-09-2010 09:23 PM
What is that number in the back of people's cars? tk_1971 Southern California Impreza Club Forum -- SCIC 12 08-14-2003 03:29 PM
Newbie question, what is that switch on top of the steering colum? anant369 Newbies & FAQs 6 05-10-2002 08:01 PM
what is that number on the race cars called? represents? FuJi K Newbies & FAQs 10 12-19-2001 01:29 PM
