Old 04-28-2001, 07:51 AM   #1
Willis
Member#: 424
2005 WRX STI
Post clutch problem - need help
Hey guys/gals,
I'm hoping you guys can help me solve a clutch problem with my 98RS. It seems that my clutch is not fully disengaging. The initial 3-4 inches of travel on the clutch pedal is all play. Also I can only shift into gears when the car is not running. And when the car is idling in gear with the clutch pedal down to the floor, the car moves.
I have an ACT clutch which has been installed for a year now. This problem didn't occur gradually. It just happened as if something broke, so the clutch probably doesn't need adjustment.
I've checked the clutch fluid - that's ok. I'm going to play with it some more. But hopefully some of you know exactly what the problem is. Maybe its my simple knowledge of cars but I'm guessing that the problem is centralized around the clutch pedal - like spring fell off or something. I dunno. Please donate some of your knowledge. Thanks.
Willis is offline   Reply With Quote
Old 04-28-2001, 02:00 PM   #2
Scooby do
Member#: 1217
2005 9-2X
Artic Silver
Post
I can't help you on the problem but my friend has an ACT clutch on a MY00 RS and it just broke or something. It shifts fine when driving but it does not release all the way. Does anyone know why it would do this? The car was stored during the winter and worked fine last fall. Anyone?
Thanks
Bob
Scooby do is offline   Reply With Quote
Old 04-28-2001, 03:26 PM   #3
Willis
Member#: 424
2005 WRX STI
Post
It's strange, but the clutch is working fine now. And all I did was let it sit over night. This leads me to believe that the problem occured because the clutch fluid overheated and stopped working, just like brake fluid does at times. Does anybody know if this is possible? Its funny because just recently somebody posted how they have never seen this and it most likely would never happen.
I should replace the fluid since it is slightly more brown than the brake fluid. The service dept probably forgot to do it at the 60k tune-up. What would be the root cause for this problem - too much moisture in the fluid?
Scooby do, it sounds like your friend has the same problem as mine. So, maybe he should start off by changing his clutch fluid like me.
Old 04-28-2001, 03:32 PM   #4
Scooby do
Member#: 1217
2005 9-2X
Artic Silver
Post
I will mention that to him. I will post the outcome.
Thanks
Bob
Old 04-28-2001, 07:06 PM   #5
bill harvey
Member#: 10
2005 Legacy Gt wagon
Garnet red pearl
Post
willis the clutch isn't in fluid the tranny has fluid but i doubt that would cause this i think kc or paul had this problem with the stock unit but i am not sure it sounds like linkage to me but give them a shout.
bill harvey is offline   Reply With Quote
Old 04-28-2001, 11:25 PM   #6
jhuang76
Member#: 1284
2005 Legacy GT
Royal Blue Pearl
Post
Note: The Imprezas have a hydraulic actuated clutch, which uses brake fluid. So yes, you may have overheated the fluid causing it to "boil"! Do a search in the "Archive: Technical" since I remember a few members who had similar problems. They bled the clutch and put in synthetic brake fluid and they said it made a HUGE difference.
Hope this helps,
Joe
jhuang76 is offline   Reply With Quote
Old 05-03-2001, 08:15 AM   #7
Willis
Member#: 424
2005 WRX STI
Post
I didn't have time to bleed out the clutch until yesterday, so the clutch problem kept occuring after long drives. But ever since I bled the clutch fluid using valvoline brake fluid, the problem is gone. In fact, the clutch pedal feels stronger. Thanks for your replies guys.
Old 05-03-2001, 10:20 PM   #8
jhuang76
Member#: 1284
2005 Legacy GT
Royal Blue Pearl
Post
Good to hear you've got the problem fixed!!!
Old 05-04-2001, 06:11 PM   #9
pottsie350
Member#: 6110
98 Impreza L
Red
I've seen similar problems with hydraulic clutches, particularly on motorcycles. Hydraulic master and slave cylinders aren't usually built to the same exacting tolerances as braking system units. This means that they clutch units are more susceptable to foreign matter interfering with sealing. Changing the fluid usually flushes out any foriegn materials, and the problem goes away. I think if you did manage to heat your clutch fluid up to boiling temperature, something would really be wrong. Chances are your engine would be on fire.
pottsie350 is offline   Reply With Quote
MY02 Wagon: New clutch...problems...need help bwawuz Transmission (AT/MT) & Driveline 6 11-17-2006 09:32 PM
Detailed description of my clutch problem need help Norcalrallyist Subaru Conversions 1 10-04-2006 08:59 AM
Clutch problems, need help pinter Transmission (AT/MT) & Driveline 6 07-14-2005 05:52 AM
('93-'01) Clutch problem need help dvs81n Impreza Forum 0 04-24-2001 06:13 AM
('93-'01) clutch problem, need help. Scooby25 Impreza Forum 3 04-14-2001 02:58 PM
